Question about GE Monogram ZE2160SF Convection / Microwave Oven
Monogran convection oven ZET938SF3SS
Door handle on the oven has come loose. Does repair require a service person or can this be done by me? If I can do it can you describe how to get inside oven door?
    Problem Solver:
  • 20 Answers
For door service is little more complecated, kindly try to get good service engg from your plase. pl dont take risk.
G.K.mahendran
9791055855
India
Posted on Aug 01, 2008
I need to replace the Glass Door and Plastic handle on my Table Top Convection Oven
OK, so please do a google search for terms
Parts, Make and Model of your unspecified table top convection oven
You may search in those websites for your parts and may contact them asking for specific parts.
Also, you may look for one near your area, if you may visit them personally.
Oct 10, 2015 | Microwave Ovens
How to replace the door handle on a whirlpool MH2155XPQ micro wave
The screws that hold on the handle are inside the door assembly. Here is the way its done but its not for the average person. On the inside of the door is a plastic frame all the way around the door. It is held in place by plastic tabs. You have to gently pry off that frame with something like a putty knife or small screw driver. If you are not careful you end up breaking off some of the tabs. Once that frame is off you should have access to the 2 screws holding on the handle. Remove screws---replace handle---and push plastic frame back on.
Jun 26, 2015 | Whirlpool MH1150XM Convection/Microwave...
Door handle has broken loose at bottom of handle and needs to be replaced. How can this be accomplished?
The door handle can easily be replaced on MOST microwave ovens by removing the inner door panel that goes around the perimeter of the glass. The following link explains how to access and replace the door handle:
http://www.fixya.com/support/r3696942-microwave_oven_door_handle_replacement
The average cost for a replacement handle (if required) usually runs about $20 - $40. Replacements may be purchased at the websites listed in the link I provided.
The door handle is a simple repair that can be done with the door in place, or with the door removed. You do not have to uninstall the oven if this is an over the range model.
NOTE: If you wish to remove the door, all you need to do on most models is open the door all the way and lift straight up at the hinges. You may have to remove the grille cover located above the door on some models to accommodate being able to lift the door.
If you have any questions, please post back and let me know. I hope this helps you.
Nov 10, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
The handle of my Advantium 120 has broken off. Can this be repaired and can be done by us or a service repair man?
It can be replaced by either a repair person or if you can source the part, yourself as it is part of the frame and not the high voltage electrical stuff inside.
Oct 23, 2010 | GE Advantium 120 Convection/Microwave Oven
My handle broke on me ge microwave spacemaker xl
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
You can find handy exploded views and order parts by model number here.
Oct 08, 2009 | GE Advantium 120 Convection/Microwave Oven
Outside glass dooor on Whirlpool oven fell off, what do i do?
Sep 15, 2009 | Whirlpool MH1150XM Convection/Microwave...
To remove inner door cover
The door handle can easily be replaced on most microwave ovens without the assistance of a repairman. This is a common problem with some microwave oven doors.
To access the door handle mounting screws on MOST microwave ovens, you have to remove the inner door panel that goes around the perimeter of the glass. You can use a small screwdriver to carefully pry the plastic up and work your way slowly around the perimiter of the glass. Most microwave ovens also have grooves in the panel that you can insert the screwdriver into. Use care not to pry against the glass. The glass is tempered and also has an RF shield that prevents harmful microwaves from potentially harming the consumer. If you break the glass, you will need to purchase a new door.
The door handle screws are located behind the inner panel. Simply remove the broken handle and install the new one. Re-insert the inner door panel carefully and gradually work your way around the perimeter of the door glass and make sure it snaps back into place.
This repair can be done with the door in place, or you can remove it for easier access. If you decide the remove the door, simply open it all the way and lift straight up at the hinges. The door will lift off of the hinge pins. Place on a hard flat surface with some towels under it for padding. This protects the door facing from scatches.
NOTE: Some ovens have a small hinge pin that will have to be removed in order to remove the door.
If you have any questions, or require additional assistance, please let me know. I hope this helps you.
Aug 29, 2009 | GE Advantium 120 Convection/Microwave Oven
The door handle on my GE Profile ADvantium 120 Microwave is broke
appliancepartspros.com. part number AP3187809 $56.40 plus shipping
Apr 27, 2009 | GE Advantium SCA1001SS Convection /...
Microwave not heating
You need to replace the whole door latch with an original part.
If it is working but not heating, then test the high voltage capacitor,the rectifier diode.or the magnetron. If all this are fine, test the control board.If turntable is not running check also the door switch.
Remember that microwaves are potentially dangerous devices if not repaired properly, the job must be done by a competent person.
A microwave energy leakage test must always be performed when the oven is serviced for any reason.
Regarding parts, contact the seller here to purchase parts.
You can also order from MicrowaveSvc , they also provide parts.
Mar 18, 2009 | GE Advantium SCA1001SS Convection /...
How to Replace Broken Handle
Sorry but the chat system seems slow and hard to work with.
Page 28 & 29 of the service manual tell you how to remove the door and take it apart to replace the handle.
The service manual is here.
And you can watch a YouTube video (not a video I made) that demonstrates how it's done.
Jan 22, 2009 | GE Advantium 120 Convection/Microwave Oven
GE Monogram ZE2160SF Convection / Microwave Oven Logo
179 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
D. E. Hev
 Larry
Larry
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
