Question about Ericsson Cell Phones
The phone will not turn on, the led light flashs 6 times
It says puk blocked
Posted on Jul 31, 2008
How do i turn on my Polaroid Shuffle 4GB MP3 player?
There is a led light in the upper right corner of the front. The controls are on the large round button in the center. To turn in on, press in the center of the button; the device will turn on and playback will begin. To turn it off, press AND HOLD the center of the button until the LED light flashes several times and then turns off.
To play, press the center of the button and the LED should come on and stay solid. To pause, press the center and the LED will blink once a second Press again and playback will resume.
Think of the big button as a clock face. Press at 12 for volume UP. Press at 3 for next track; HOLD for fast forward. Press at 6 for volume DOWN. Press at 9 for previous track; HOLD for rewind.
For shuffle, press at 12 and 6 together and hold for 2 full seconds. The LED will flash 4 times to show you are in shuffle mode. To go back to normal playback, press at 12 and 6 together for 2 full seconds and the LED will flash 2 times to show you are back to normal mode.
Jul 15, 2014 | Polaroid Audio Players & Recorders
How do i get the PMP80-4 to shuffle through the songs. Is there an instruction manual?
Feb 22, 2014 | Polaroid Shuffle MP3 Player
Automatic door lock 1999 toyota prerunner
hi jerome
I have the procedure for Toyota auto lock, is worth to try it
AUTOMATIC LOCK SETTING
1) Step in the vehicle and make sure that all doors are closed completely
2) Insert the key into the ignition key cylinder.
3) Wait for more than 5 seconds.
4) After turning the key to the ACC position, turn the key from the ACC to the
ON position 5 times within 10 seconds (Last position : ON).
? Status Monitor LED will illuminate for 30 seconds.
Note : In case you implement 6 times or more by mistake,
action steps 6)-8) you made will be canceled.
Please retry from step 2).
5) While the LED is illuminated :
• Open and close the driver's door 2 times.
• Turn the key to the ACC position.
? LED will continue illuminating.
? Indicator lights will flash 2 times.
Ignition controlled door lock ON :
6) While the LED is illuminated:
• Open and close the driver's door 1 time.
• Turn the key ACC-ON-ACC 1 time (Last position : ACC).
? Indicator lights will flash 1 time.
? LED will extinguish.
Ignition controlled door lock OFF :
6) While the LED is illuminated :
Jan 28, 2014 | Toyota Camry Cars & Trucks
I have a th-42pd60u and the screen is off and wont turn on. the red led light flashes 6 times
The Sc board or the D board has blown which is indicated by the 6 flashes of the led. You need to replace one or both
Mar 03, 2011 | Panasonic TH-42PD60U Television
I have a golden companion scooter and it wont move it flashes a green light but i haave no info on where to obtain the trouble codes
The L.E.D. located on the tiller
dashboard will indicate with flash codes what problem is occurring.
L.E.D. Flashes 1 time and pauses, 1 time and pauses…. Batteries are low,
scooter will still operate.
L.E.D. Flashes 2 times and pauses, 2 times and pauses…. Batteries are very
low, scooter will not operate.
L.E.D. Flashes 3 times and pauses, 3 times and pauses….Over voltage to
controller.
L.E.D. Flashes 5 times and pauses, 5 times and pauses….Brake is in the
freewheel position or connection to brake is open.
L.E.D. Flashes 6 times and pauses, 6 times and pauses….Paddle or speed
potentiometer problem.
L.E.D. Flashes 7 times and pauses, 7 times and pauses….Paddle or speed
L.E.D. Flashes 8 times and pauses, 8 times and pauses….Motor
disconnected or faulty.
L.E.D. Flashes 9 times and pauses, 9 times and pause….Controller fault.
I hope this helps they are pretty standard codes I got this from Golden Tech Web Site
Aug 17, 2010 | Golden Technologies Golden CompanioN II -...
THE TV IS CUTTING OFF BY ITSELF AND THE OPC LIGHT IS BLINKING
This problems very common on Sharp Tv.Do ur tv LED power light turn on solid first.Few mins,than LED,OPC flahes.Power LED,OPC flashes,push power button again,do this at leat 5 or 6 times somtimes the backlight will come back on and work.The power LED,OPC light flashes,turn off/on more than 5 or 6 times don't work.Ur Tuner signal board is dead,must replaced.
Mar 30, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Red led light flashes 6 times and tv won't turn on
Hi friend,,,,,,
it is an indication of an error code ,,,,,,normally 6 blinking code refers to an power set up problem,see incoming voltage with an multimeter.......
thank u,,,,,,,,
May 03, 2009 | Panasonic PT-53WX53 53" Rear Projection...
PFM-42b1e LEd flashing 6 times... 1 sec. picture with green stripes... and then it turned to standby
I have a sony tv PFM-42B1 when I turn it on it go to standby an a red light flash I count count 14 time but I heard that it only support to flash 1 to 6 time how do count the flash
May 06, 2008 | Sony PFM-42B1 42 in. HD-Ready Plasma...
Hdtv won't turn on
Can you count how many times it flashes ? It might flash like 6 times and pause for 2 sec and flash 6 times again. THen call a service comany and tell them this info and they might tell you what part inside is bad. They are not telling you this for you to replace but they might say something like oh 6 flashes is a Y board and we will have to order it.
Hope this helps
Aug 29, 2007 | Televison & Video
Cell Phones Logo
24 people viewed this question
Top Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Are you an Ericsson Cell Phone Expert? Answer questions, earn points and help others
