Question about HP DeskJet 960c InkJet Printer
Broken Paper Guide
The Inner Paper Guide support is broken and the whole piece needs to be removed and repaired or replaced. Are there step by step disassembly instruction that will get me to this point? Everything I try to disassemble the printer seems to be ineffective.
  • Anonymous Mar 27, 2014
    Problem Solver:
  • 10 Answers
Better not try it on your own Approach any Authorized Service Cenetr for repairs...sodeep
Posted on Mar 21, 2009
Paper tray 2 is stuck -- cant move in or out
the paper lifting rack plastic tabs one of them is broken and the metal that is showing is catching on the guide so the lifting rack is not lowering into place, turn the printer around, remove the door that hides the back of the paper tray, grab the paper size tab and pull it out as far as you can, now get a flash light and either a ruller or a long screw driver and push the lifting rack down into the tray flat and then push the tray out of the printer. once this is done you can examine the broken tab on the lifting rack and call hp for a part number, get a whole baggie of the pieces because they break all the time!!! you can use some fabric medical tape to make a quick and temporary repair. but it will ware out and you will have to do it again. good luck.
Microapex Computer Systems and Printer Repair Center
Feb 02, 2011 | HP LaserJet 3600n Printer
The threaded part on the intake of water has broken off, how can I replace this and remove the remaining peice inside.
Howdy, hwile I don't have the whole picture yet, you can likely remove the broken off piece with an inside wrench kit; it is a cam wrench that fits inside the pipe and grips the inner wall when turned. Now, if you tell us what sort of intake and the size and type of pipe you have, we can help you with the rest of your issue, too.
regards, Farmerbear
Sep 09, 2010 | Plumbing
Need to replace broken right hand mirror on a 2008 dodge caravan.
Could be screwed on from inside the door and might have to remove inner door panel for access. OR there may be some screws on the outside - if nada maybe the cover can be carefully pried off to expose the screws. If you google this I am sure you will find something re how to. Just be careful since you do not want to damage the paint job on door.
Aug 26, 2017 | 2008 Dodge Grand Caravan
The washer clunks during spin cycle. I removed the back and found some pieces of plastic from the outer drum enclosure. Other than that, everything seemed to be intact. The "shocks" or feet were not broken...
If the inner basket has broken off on one of the three braces on the back side where it is welded to the main spindle shaft that goes through the outer shell and bearing, you will need to replace the spindle and probably the inner basket. Some come together, some can be bought seperately and bolted. Not sure which yours is. Most people go out and replace unit rather than attempt ths repair because of cost if done by a appliance business. It is a complete tear down, and part or parts are expensive.
If you grab the inner basket and try to move it side to side, it should be solid.. The whole tub assembly can move while your doing this, but the inner basket should be solid in the back bearing
Just one idea..
Jan 13, 2010 | Frigidaire Washing Machines
I need to replace the handle. Can you give step by step help?
To access the door handle mounting screws on MOST microwave ovens, you have to remove the inner door panel that goes around the perimeter of the glass. You can use a small screwdriver to carefully pry the plastic up and work your way slowly around the perimiter of the glass. Most microwave ovens also have grooves in the panel that you can insert the screwdriver into. Use care not to pry against the glass. The glass is tempered and also has an RF shield that prevents harmful microwaves from potentially harming the consumer. If you break the glass, you will need to purchase a new door.
The door handle screws are located behind the inner panel. Simply remove the broken handle and install the new one. Re-insert the inner door panel carefully and gradually work your way around the perimeter of the door glass and make sure it snaps back into place.
If you have questions, please let me know. I hope you find this information helpful.
Jul 07, 2009 | GE JVM1650 1000 Watts Microwave Oven
Using HP 1100d Office Inkjet printer. Can't get 'out of paper' light to turn off. I have added paper, pressed the reset button, but light stays on, and printer will not operate.
Please read over the following information and follow step by step.
Issue Either before or during a print job, the message ' Paper Jam ' appears on the product control panel display. The product does not output paper or complete the print job. Solution Follow these steps to resolve the issue. Step one: Remove any loose paper
  1. Remove any loose paper from the paper tray and output tray. CAUTION: Do not remove jammed paper at this stage.
  2. Press the Cancel/No button on the product control panel to clear the paper jam message.
  3. If the paper jam message cleared, try the print job again.
  • If these steps resolved the issue , there is no need to continue troubleshooting.
  • If the issue persists , continue to the next step.
Step two: Clear the jam from the back of the printer
  1. Press the Power button (c01345237.gif ) to turn off the product.
  2. Unplug the power cord from the back of the product.
  3. Remove the rear access door: Turn the knob one-quarter turn to the left and pull the door away from the product. Figure 1: Remove the rear access door c01489996.gif
  4. Gently pull the paper out of the rollers. CAUTION: If the paper tears when removing it from the rollers, check the rollers and wheels for torn pieces of paper that might remain inside the device. If any torn pieces of paper remain inside the device, then more paper jams are likely to occur.
Step three: Clean the rollers While the rear door is removed from the product and the power cord is disconnected, clean the paper rollers.
  1. Wipe the paper rollers with a lint-free cloth that is lightly moistened with distilled or bottled water. Rotate the rollers with your fingers to clean all the way around. Figure 2: Clean the paper rollers c00246512.jpg
  2. Allow the rollers to dry completely.
  3. Replace the rear access door. Gently push the door toward the product, and then lock it in place by turning the knob one-quarter turn to the right or locked position.
  4. Reconnect the power cord to the back of the product.
  5. Press the Power button (c01345237.gif ) to turn on the product.
Step four: Reload paper and test the printer Load a stack of plain white paper in the paper tray and try the print job again.
  1. Press the Cancel/No button on the product control panel to clear the paper jam message.
  2. Lift the output tray.
  3. Pull out the front paper guide on the paper tray and slide the side paper guide as far to the left as it will go. Figure 3: Slide out paper guides c01489992.gif 1 - Front paper guide 2 - Side paper guide
  4. Load a stack of plain white paper, print-side down into the paper tray. Make sure the paper stack is no higher than the top of the front paper guide.
  5. Adjust the side and front paper guides to fit snugly against the paper stack. Figure 4: Adjust the side and front paper guides c01489993.gif
  6. Lower the output tray.
  7. Disengage the photo tray: On the output tray, pull the slider (visible through the output tray) away from the product until it stops. Figure 5: Disengage the photo tray c01489994.gif
  8. Try the print job again.
Step five: Service the printer If you have completed all the steps listed above and are still experiencing a problem, service the product. Have a good day,
Jun 18, 2009 | HP Inkjet 1100d Printer
Timing, jams or prints off bottom of page
Hi hotpress:
Try these steps.
Print transfer jams
If a piece of paper is trapped in the paper preheater, try pushing out the paper by
inserting a stiff piece of cardstock into the paper preheater.
2. Using diagnostics, test the paper preheater sensors. If the test fails, replace the
paper/drum heater assembly.
3. Check to see if the upper feed roller drive belt is broken or slipped off of its pulleys. In
such a case, the upper feed roller does not rotate when the lower feed roller rotates.
4. Check that the feed rollers rotate smoothly and that the front cover is fully closed and
5. Check the paper-eject path for obstructions. Ensure no small pieces of paper are
trapped around the stripper fingers or rapid release guide.
6. Ensure that the transfix roller rotates during the transfix process. See SF168 and
7. Test the sensors in the paper path. Look for damaged or non-operating sensor flags.
8. Check the transfix solenoid and its cam. Ensure they operate correctly and are properly
lubricated. If lubrication is needed, apply a dab of grease to the contact point between
the cam and the latch and the cam and the cam-advanced spring. Refer to
"Lubrication" on page 6-177.
9. A stripper finger, or rapid release guide, jam can occur because of broken teeth on the
small section of the back-side of the compound gear. The root cause of this may be also
be due to a lack of transfix cam grease. If you find broken teeth on the compound gear,
check for proper lubrication of the transfix cam. Be careful to ensure that no grease
touches the Y-axis belts. If the belts get contaminated with grease they must be
replaced. wipe off any excess grease to prevent it from dripping onto the belts.
Hope this helps
May 23, 2009 | Xerox Phaser 850 Printer
Broken handle on dishwasher
TURN OFF POWER TO UNIT. Open door, remove all torq screws from door panel, separate inner and outer door panel. latch assy is able to be removed, place black wire connector and white white connector back respectively, place inner part of door back and replace the torq screws. Then turn power back on for unit.
Jan 09, 2009 | Maytag Dishwashers
is the piece of paper removed? or there parts of the paper w/c was nt removed? if the whole paper was removed already, try to use this steps..step 1. remove the power cord of the printer. step 2. press the power on/off of the printer while plugging the power cord. and wait for 10 seconds before releasing the on/off button..then put on your printer. but if some pieces of broken paper inside the printer try to clear it first then try printing.
Jan 02, 2009 | Canon I960 InkJet Photo Printer
Key is broken off in the ignition switch
You'll have to take the whole ignition piece out in order to remove the broken key. I apparently jammed a bunch paper clips in my parents van when i was a kid and they had to take it to some place to get the whole thing removed.
Dec 03, 2008 | Chevrolet Classic Cars & Trucks
HP DeskJet 960c InkJet Printer Logo
144 people viewed this question
Ben Johnson
