Question about Adapters.com Video to Monitor HD-15 Converter, Watch any Video Source on your Computer Monitor (XVIEW1)
SCSI vs. SATA vs. PCI Controllers
I have a five year old DELL Dimension 4600 w/3gb of memory and an 80gb hard drive.
Since my HD is about 50/50 used/free space, I have decided to purchase a larger HD.
Now to my problem: I talked to a DELL technician that I had been shopping for a new internal hard drive. I had previously purchased a unit but upon opening it, I discovered that the i/o cabling connections were different from the one that connects my HD to the mother board. Mine is ribbon cabling. A DELL professional (Ha! Ha!) said that was not a problem and suggested some that I could purchase which would fit physically and electronically. I purchased a Wester Digital 500gb internal hard drive from DELL and guess what. It does not support my ribbon cable connections.
Is there a universal mod kit on the market to solve this problem or should I return the unit to DELL?
I also have a 500 gb external HD manufactured by Western Digital. I had wanted to boot it up as my main HD and use the internal as backup. I am getting conflicting information about the ability to do this.
I would greatly appreciate your assistance.
Harold Estep
1280 Cloverdale Drive
Clarksville, TN 37040
  • 781 Answers
To use your external hard drive as boot drive you will need to set bios to boot from it if the bios allows you to
i do not know which section of the dell bios it is but it will have boot order or similar you will have to follow instruction to set it the main problem having extenal boot is windows will not install to USB devices
As for the hard drive from dell it could be a sata drive they sold you you need the standard one
Hope this helps your dilemma
Posted on Jul 31, 2008
2 Suggested Answers
Yazz226
  • 497 Answers
SOURCE: Computer Cabling
http://eshop.macsales.com/item/Newer%20Technology/U2NV2SPATA/
hi...plz do check this link if it wud fit the purpose
Thanks for using Fixya
Tc
Upgrade hard drives on 670
There is a 2TB limit with MBR (Master Boot Record), but even a larger drive can be partitioned. So a single 4TB (biggest on the market) drive will look like several drives.
External drives that are bigger than 4TB are really several physical drives combined by an array.
RAID 1 requires optional SCSI drives, cables, and even software?
http://support.dell.com/support/edocs/systems/ws670/en/ug_en/before.htm
Add on SATA 3 cards to PCI are not a good idea if you are looking for speed. They just bottlenecks the throughput.
Oct 22, 2012 | Dell Precision Workstation 670 PC Desktop
WHAT CAN USE TO REPLACE A MAXTOR 7Y250MO HARD DRIVE? IT IS IN A 6 1/2 YEAR OLD DELL DEMENSION XPS GEN 2 TOWER RUNNING WIN XP. THE OS CAN NO LONGER FIND THE DRIVE AND WILL NOT BOOT UP. I WOULD LIKE TO...
The Dell Dimension XPS GEN2 has support for both, IDE and SATA standards. Your Maxtor is SATA drive, you can use any SATA drive as replacement. You mentioned that the OS no longer find the drive, make sure that you load SATA drivers at your Windows XP reinstallation, maybe your old drive is not defective only not recognized in the installation process. You can download the floppy image with required drivers here, see SATA drivers section. When you start Windows installation, at the Windows Setup Screen you should see, at the bottom of the screen, a message saying "Press F6 if you need to install a third party SCSI or RAID driver." At that point press the F6 button and when the next screen appears press S key to specify an additional device. Select the drivers from the provided list(to load all drivers from the disk, beacuse I don't know which is yours as I don't know the content of the disk, repeat steps to specify additional device), after drivers load your hard drive should be recognized and you can continue installing the Windows XP operating system. Ignore these steps if your hard was already tested and confirmed that is defective. Good luck!
If this is the solution for your problem, please rate my post, otherwise give us more details.
Regards,
Andras
Sep 26, 2010 | Dell Computers & Internet
Connect ide or sata drives to a dell poweredge 2600 for additional storage
Yes and No..
The standard machine only allows SCSI, (no IDE or SATA or SAS connectors...
However SCSI drives are not cheap.. so
To overcome the power issue (you will notice there are no 4 pin molex connectors, or sata power connectors). However there is a 4 pin molex socket on the SCSI backplane. You can use one of those molex adaptor cables (one connector to many) to get power, from the molex you can use a 4 pin to SATA power connector.
Next step is to decide the drive you want to use. I personally use SCSI, SATA, SAS and IDE in mine (overkill I know).
Cheapness says use IDE or SATA. You can get a pci IDE/SATA controller card on ebay dirt cheap (PCI cards are compatible with the large PCIX slots), they dont take the entire "socket" up but they work (be carefull here, there is one 5v pci socket on these machines, and 6 pcix sockets, the pcix sockets will accept 3.3v pci cards (look at the notches).
Next you have to mount them, with a bit of jiggery pokery you can feed the IDE/SATA cables past the SCSI backplane into the hot swap bay. (If you dont have any empty caddy's pick them up off ebay), just remember you cant just pull em out like you can with the SCSI's!) - or use one of the 5 1/2 media bays.
Plud the other ends into the appropriate controller card (as installed in the PCI bus).
Load up the OS, install drivers (if needed - these should come with the pci card(s), use the disk manager to initialise/first format the drives etc.
All done.
I have done this myself running a 2600, with 2X U320 72gb SCSI (on Raid) 1 x IDE CD/DVDRW in Media bay, DAT 27 SCSI (channel B) in the second media bay. 2x 146gb SAS on a DELL SAS pcix card (in 2 of the hot swap bays) and an old 160gb IDE HDD (Funilly enough theres a bit towards the back of the two fans on the SCSI backplane that if you press the 3 1/2 drive against seems to fit perfectly in this place and stay there! (I think thats fluke to be honest).
All done :)
Jan 04, 2010 | Dell PowerEdge 2600 Server
Does the dell dimension 3000 pc have sata data and power cables/connections? I am trying to put in a disk drive with sata.
It does not. You can get PCI SATA Controller cards that work nicely though. Adaptec is always nice, but Promise offers a cheap, decent alternative. If you are just installing one drive you do not need RAID, which will cut your costs considerably.
Jan 02, 2010 | Dell Dimension 3000® Pentium® 4...
A blue screen comes up that says a problem has been detected and windows has been shut down to prevent damage to your computer. UNMOUNTABLE_BOOT_VOLUME ***STOP: 0X000000ED (0X86F85C08,OXC0000006,...
Dear friend first Check the Ram try with another one. if it is not
2. May problem with Your Hardware like pci cards, hard drivers. remove those pci cards then try again.
3rd possibility is Your IDE or SCSI or SATA cables ARE DEFECTIVE OR PROPERLY NOT CONNECTED.
4th Possibility is Check Your hard disk
Jul 01, 2009 | Dell Dimension 4700C PC Desktop
Hello sir, I got Power Edge 2600 used not new from a friend, It works fine but its hard drive is damaged. so I was wondering if i can install SATA drives with 7200 rpm to the system? and if so, will it...
This system does not support SATA, personally I would get a 10000 or 15000 rpm SCSI drive.
If really want to use SATA, you can get a SATA controller that plugs into one of the PCI slots. You can probably pick up one for under $50.
Jan 03, 2009 | Dell PowerEdge 2600 Server
Dell dimension 3000 hard dirve what type do i need to install a sata pata or ide
Hi
Dell Dimension 3000 accepts IDE hard drive. Any modern IDE drive should be fine
Check out Dell Dimension 3000 Service Manual for spec and how to remove and install parts.
Mike
Aug 21, 2008 | Dell Dimension 3000® Pentium® 4...
Replacement HD
Do you know if it is SATA or IDE? If you look at your hard drive, an IDE will have a wide cable connected to the back of it. If it is SATA, it will be a small cable that connects it to the motherboard. I think it is SATA. But nonetheless, depending on the size of the hard drive you want, you can get decent hard drives in the $60 range at www.tigerdirect.com.
Thanks and please take a moment to rate as fixya. Thank you.
Jul 12, 2008 | Dell Dimension 2400 PC Desktop
Televison & Video Logo
413 people viewed this question
Top Adapters.com Televison & Video Experts
Are you an Adapters.com Televison and Video Expert? Answer questions, earn points and help others
