Question about RCA PHD50500 50 in. Plasma Television
Need part power splay board part #261670
  • 2,326 Answers
Click here to find the power supply. A bit pricey.
Posted on Jul 31, 2008
Ford escort coil pack
check to make sure that the wires are connected properly. if they are loose there won't be a good connection. highly unlikely that it is the computer. check to make sure there are no splayed wires.
Oct 27, 2013 | Cars & Trucks
Would a short in the power supply of fuel pump be in the fuse box or close to the fuel pump?
i would recommend that you check the fuel relay. which is located in the fuse box under the hood. if that is fine then it could be a short in the power supply near the fuel pump or anywhere else along the wire. check for splays. but most likely the fuel relay if not the fuel pump itself.
Sep 08, 2013 | 2001 Saturn L-Series
HP PAVLION DISPLAY PROBLEM
yes , that NVIDA Issue , you have to refllow VGA chip-set
Mar 20, 2013 | HP Office Equipment & Supplies
Some dvd splay while others i get disk error
Try cleaning the pick up assembly! It's going bad...Or have it service by a Tech...
Sep 17, 2011 | Televison & Video
Jane powertwin splayed back wheels-rear brake plastic bracket
This sounds like some kind of excessive weight on the handle bar or a buggy board has been used, either that or too much pressure has been applied to the break bar. On the break bar, this should have a natural curve to it, if this looks wonky, then this is probably the reason. If this is the case, then the bar will have to be drilled off, straightened and re-rivetted back on.
I would suggest that you contact either your retailer for repairs advice, or www.johnstonprams,co.uk please note that this does sound like you will have to pay for it to be repaired.
I hope this helps.
Aug 15, 2009 | Jane Powertwin Azulon Stroller
My computer shutdown and im using a emachine e17t6w tft lcd flat
Hi
Dear sir,
Moniter Modale No E700,
E700 modeleprablem, Power splay prablem, but transister, Divaid all componets ok
Becouse power on that puse shout way to andstrading the prablem, please solve prablem
Mar 19, 2009 | Computers & Internet
Jane Powertwin - back wheels splaying?
I had a similar problem and I had been told to go to a bike shop as they help you (you can get spare wheels from them too)... Cheaper than from online shops.. They can sort buckled wheels which is what my problem turned out to be!!!!
Oct 09, 2008 | Jane Powertwin Azulon Stroller
Rear door speakers
It's worse than that. Those are not "tamper-proof screws", those are aluminum pop rivets. (Then again, they are even more tamper-proof than screws.) Once you get the door panel off you will see that each rivet splits into four legs that splay out to hold the speaker frame sandwiched between the grill and the fiberboard door panel. You can remove them but it took me some time with stout needle-nosed pliers to un-splay the legs, and ultimately a Dremel tool to cut them off. What a cheap PITA way to attach a speaker.
Theoretically, you should be able to replace the OEM speaker with a skinny 4" one but you will need to fabricate an adapter ring so there is something solid on which to mount the new speaker. Also, you will need to tape flat Tinnerman nuts to the back side of the panel so the screws you shoot through the grill will have something to bite into. It won't be pretty but it should work.
Sep 09, 2008 | 1991 Volvo 240
What's U2 code and method for solution
U2 can have several indications.
The most likely one is that the chip that is on the back of the toner cartridge is not seated properly or has failed.
Try with the machine off, removing and inserting the toner cartridge several times to clean the contacts, next step is to try a new toner cartridge.
There is also a connector on the back frame of the machine that may be dirty or going bad.
Jan 16, 2008 | Sharp AR-5316 Advanced Digital Imager...
RCA PHD50500 50 in. Plasma Television Logo
63 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
