Question about Fargo DTC525 ID Card Printer
Printer washes the image out. - Fargo DTC525 ID Card Printer
The problem was with Photoshop. After changing the print settings so that nothing was modifing the color settings it worked just fine.
Posted on Aug 01, 2008
Cannot reseat imaging unit in xerox phaser 6130 printer
You can find answers to your Xerox questions at www.xerox.com/support
Solution : Replace the Imaging Unit CAUTION: Do not use warm water or cleaning solvents to remove Toner (Dry Ink) from your skin or clothing. This will set the Toner and make it difficult to remove. If any Toner gets on your skin or clothing, use a brush to remove the Toner, blow it off, or wash it off with cold water and mild soap.
Do not drop or shake the Imaging Unit after it has been removed from the printer as Toner spills can occur.
Do not expose the Imaging Unit to any light source for more than five minutes. Prolonged exposure to light may damage the unit. Cover the Imaging Unit with a light shield (such as a sheet of paper). Do not touch the shiny blue Transfer Belt.
  1. Power OFF the printer using the power switch located on the left side of the printer, toward the back. Press the power switch to the OFF (O) position.
  2. Press the button on the top right side of the printer to open the Front Cover.
  3. Locate the Imaging Unit, and then turn the four twist-locks to the left to unlock the unit.
  4. Grasp the Imaging Unit by its peach-colored pull-tabs on the top edge. Pull the unit forward and up, and then out of the printer.
  5. Place the used Imaging Unit in a bag and make sure the bag is properly sealed before discarding or recycling.
  6. Remove the new Imaging Unit from the shipping container and the sealed package.
    CAUTION: Do not remove the orange protective cover from the front of the unit until it has been installed in the printer. This will protect the Transfer Belt from being touched during installation.
  7. Place the Imaging Unit on a flat surface. Hold the unit firmly with one hand and with the other hand grasp the end tab of one sealing tape and pull the tape straight out, horizontally. Repeat for the remaining tapes; there are eight tapes in total. Make sure none of the tapes have broken. Discard of the tapes as normal office waste.
    NOTE: If any tape breaks off with the remainder inside the Imaging Unit, stop the installation and contact Support.
  8. Grasp the new Imaging Unit by its peach-colored pull-tabs on the top edge and install the unit in the printer. Make sure to insert the unit into the guides in the printer, and then push the unit all the way back into the printer.
  9. Turn the four twist-locks to the right, to lock the unit.
  10. Pull the orange protective cover out and then down from the top, center of the Imaging Unit.
  11. Close the Front Cover.
  12. Power ON (') the printer. A 'Ready to Print' message will be displayed on the Display Screen.
Nov 28, 2013 | Xerox Phaser 6200N Laser Printer
Washed out look, despite low use, and consumables above 50%.
Hey Andrew I'm updating my account ran into your problem this is going to be a back and fourth effort.
iteminconline
Whit is an expert and can get you free info.
Nov 13, 2013 | Xerox Phaser 7760/GX Laser Printer
My washer has an error code 02 then blinks F is this th same type of error
Datanet Copier, Fax, and Printer Consultants
18543 Devonshire Street #222, Northridge, CA 91324
Printer Repair Pros Inc.
9180 Kelvin Ave., Chatsworth, CA 91311
Image 2000, Inc.
7510 Hazeltine Avenue, Van Nuys, CA 91405
Try the places i have mentioned above.
Jan 09, 2011 | Maytag EPIC MFW9700S Front Load Washer
My Brother MFC-3240C printer does not print crisp images. Colors are washed out and lines run though the images. I reinstalled the CD and no luck. Can you tell me what to fix?
I have a brother MFC 3240C. My Black ink stopped printing(initially printed horizontal faded lines and gradually got worse), the other colors were printing fine. I tried cleaning numerous time( 50 -100 times over 1-2 weeks ). Still no improvement. The way I print now is:
1. I go to Printer Properties
2. Change Media type from "Plain Paper" to "Inkjet Paper".
3. Change Quality to "Photo".
This takes a long time to print 1-2 minutes per page. However, this works for me since this is my Home printer and use it for printing only few pages here are there. Better than throwing the printer.
Good Luck
RK
Nov 25, 2009 | Brother MFC-3240C All-In-One InkJet...
Colour 'washes out' with multi page printing
follow the step by step solution from kodak.
Choose All-in-one printer and then Print quality and follow the further steps. I think it's a problem with your printhead.
Oct 10, 2009 | Kodak ESP 5 Printer
I bought a used Color Laser printer, the HP1600, and I have just installed three brand new color cartridges. When I attempted to print the color came out washed and very faded and you could see it being...
This could a problem with the laser scanner assembly. It gets contaminated with toner and dust so reduceing the laser intensity which in turn causes the image to be fainter and gives it a washed out appearance. You would need to remove the scanner and clean the lenses and mirrors for each toner cartridge. The laser scanner box is one unit with four mirrors and four lenses in it.
Oct 07, 2009 | HP Color LaserJet 2600n Printer
HI, I have a clp-300 and it is printing black only on the right side, but the left is completely washed out. it works fine when I use a color other than black
If you the image is faded and your toner supply is good, the problem is the developer blades in the imaging unit. During the normal use of the printer, there is a buildup of toner that sticks on the developer blade. The developer blade meters the amount of toner that gets to the drum that ultimately makes it to the paper. As the toner buildup increases on the blade, less and less toner that gets to the drum cause the image to fade.
To fix this problem you will need to disassemble the imaging unit and clean the blades or buy a new imaging unit. I have clean my blades and I have a document to show you if you are handy.
Jan 18, 2009 | Samsung CLP 300 Laser Printer
HP COLOR LASERJET 3500
Hi!
If you could possibly manage to access the machine status menu and have it print to check the drum's life, fuser life, developer, etc.. pls refer. Kindly replace the toner cartridge accordingly use the menu settings when replacing any color if needed. Please print solid image or block in each color Cyan, Magenta, Yellow and Balck. Well see if what color causing the problem. Please let me know the print result it may be; washed out or too light, too bright or black, double image, or not clean. Don't hesistate to contact me again about the result.
Best regards,
Rosener Guyano
Jan 31, 2008 | HP Color LaserJet 3500 Printer
HP LaserJet 2840 Printer
For Flexer and Guest - The Imaging Drum Assy is the 5-th consumable for your printer. U can buy it as well as any toner cartridge. U can find it in the front of the 4 toner carousel with a green plastic cover. Push it to the back of the printer and pull it out straight up. The new one has orange stripes and plastics that you should remove. The Imaging Drum's life is about 20k pages (black with 5% coverage) and 5k page (colour 15% coverage)
Dec 20, 2007 | HP LaserJet 2840 Printer
Fargo DTC525 ID Card Printer Logo
95 people viewed this question
Top Fargo Office Equipment & Supplies Experts
Safe-Card ID...
Are you a Fargo Office Equipment and Supply Expert? Answer questions, earn points and help others
