Question about HP Pavilion dv9000t Notebook
Wireless networks is not working - HP Pavilion dv9000t Notebook
  • zaher el siddik
    zaher el siddik May 11, 2010
    i can not help you with this : please specify your problem , what do you mean not working?
  • 1,335 Answers
Is the wireless button on the front left of the laptop on (blue light on)?
Posted on Jul 31, 2009
Wireless router woks if wired won't work wireless
Wireless router works if wired won't work wireless
Sep 21, 2012 | Linksys Wireless-G Broadband Router
Wireless adapter not working
Network Key (WEP, WPA, WPA2 Encryption key)To connectyour computer to a wireless router, you click the Refresh networklist, then Choose your wireless network and then click Connectto your secured Wireless Network, it will asks for a Network Keybefore allowing you to connect into your wireless network. This NetworkKey is either the WEP, or WPA or WPA2 Encryption key that is used toconfigure the Wireless Router. The Passphrase is an alternate way tosetup the Encryption key.
When you are requested for a Network Key, you can just enter the Passphrasethat was used to configure the Encryption key in the wireless router. information on securing your wireless network,configuring the wireless router and configuring the wireless card in thelaptop/computer, please click on this link and follow my instructions :-
May 01, 2012 | HEWLETT-PACKARD Pavilion Slimline s5304y...
The wireless network is not working
> the wireless network is not working
1. Look for an ON/OFF switch on your PC laptop, which will enable/disable the wireless device.
2. Look for a key-sequence (FN/function-plus-F-something) to enable/disable the wireless device.
3. Take another wireless device (iPod Touch, or iPad, or a different laptop) and see if it can connect to your wireless network.
4. Click "View Available Wireless Networks". Is the SSID of your network listed?
5. Do you have a "system administrator" (your job-location or your school) who can check that the wireless network is working?
Jan 05, 2011 | Computers & Internet
Dell axim x51 will connect to to wifi hotspot i need detailed instructions to get it to work
Hi, follow the steps found in your owners manual. That can be downloaded at this link.
Using Wi-Fi (802.11b)
Wi-Fi provides your device access to WLAN (Wireless Local Area Network.)
Short for wireless fidelity, Wi-Fi refers to any type of 802.11 network,
whether 802.11b, 802.11a, or dual-band. Wi-Fi certified products from
different manufacturers are interoperable.
NOTE: Mid and High configurations of the Axim have Wi-Fi 802.11b built in and the
drivers factory installed. For a Low configuration device, you must purchase the
802.11b SD card, insert it in your device, and load the drivers.
NOTE: The default Wireless Networking Client utility for your device is the
Dell WLAN utility. The following configuration steps are for the Dell WLAN utility.
Configure wireless networking for your device in one of the following
• Network Card is set up
• Wireless Network is broadcasting SSID
• Wireless Network is not broadcasting SSID
If the Network Card is Set Up
Normally the internal wireless card is already set up. There are times when
you must choose the network card. On the Axim X51/X51v configurations
that have built-in wireless, the network card is associated with the enabled
wireless. If wireless is not enabled or you are using a socket card for
wireless connection, then choose the network card:
1 Tap Start → Settings → Connections.
2 Tap Network Cards.
3 Choose either Internet or Work from the menu.
4 Choose the network card to connect to the network. For the
Axim X51/X51v with built-in wireless, choose Dell Axim X51/X51v
WLAN Wireless Adapter.
5 Choose whether the network card assigns an IP address or receives an
IP address automatically.
6 Enter the Server IP addresses if required and tap OK.
If the Wireless Network is Broadcasting SSID
1 Press the wireless button to enable wireless capability. The green LED
in the right top corner of the device indicates that the wireless
is functional.
2 Tap Start → Settings → Connections.
3 To add, edit, or delete a profile, select the corresponding action and
tap Network Cards.
4 In the Configure Wireless Networks window, select one of the available
network names and tap OK.
If the Wireless Network is Not Broadcasting SSID
The Configure Wireless Networks window only shows wireless networks
that broadcast a Network Name (SSID) and those that have been added.
Add the network if it is not listed. Contact your network administrator for
the following information:
• SSID (network name)
• Authentication
• Data Encryption
• Keys (if the key is not provided automatically)
• Log in if necessary
To configure the wireless network:
1 From the Configure Wireless Networks window, tap Add New.
2 Provide the Network Name (SSID).
3 Select either Internet or Work in the Connects To box.
• Selecting Internet allows you to connect to your network but you
will have to manually start a VPN connection, if needed.
• Selecting Work automatically starts a VPN connection any time
you connect to the network.
• If you are having trouble connecting to your network, change the
Connects To box to Internet.
4 Tap the Network Key tab.
5 Enter the Authentication and Data Encryption information. If a key is
required, enter the network key.
6 Select the 802.1x tab.
7 The Authentication and Data Encryption chosen on the previous
screen determines whether this screen is available. If available choose
the EAP type used on the network.
8 Tap OK.
9 If more than one network is listed, tap and hold the stylus on the
network name you want to connect to. A pop-up menu appears.
Tap Connect. After a few seconds you should see Connected next to
the wireless network you selected.
Thank you,
Mar 09, 2010 | Computers & Internet
It does not connect
Wireless Adapter is a device that will receive the wireless signals and will make your computer wireless adapter. without the wireless adapter you can not use the computer to connect to the wireless network. Now a days all the laptops and desktops are equipped with the built in wireless adapters.
First check whether you have a wireless adapter on your computer ?
Right click on MY COMPUTER ==> properties ==> Device Manager ==>
you will see Network adapter ==> under network adapter you will see the wireless adapter ==> Right clink on the wireless adapter ==> properties => Check whether it says the Device is working properly or not ?If it says working properly then that's great !
WIN VISTA/ Windows 7
Click START ==> Control Panel ==> In the right hand side at the top you will see " Classic View "
Switch to classic view ==> you will see Device Manager ==> Under Network Adapters you will find your wireless adapter listed . Right clink on the wireless adapter ==> properties => Check whether it says the Device is working properly or not ? If it says working properly then that's great !
If you do not see wireless adapter in the Device manager , then either you do not have the adapter or the wireless adapter is not working .If you see "yellow exclamation mark" on the wireless adapter, that means the drivers are not installed for the adapter or not working. Reinstall the drivers.
Once your adapter is working properly , try to connect to the wireless network.
If you are installing the external wireless adapter to the computer and if you are using Windows 2000 or Windows 98 , ME, then you will have to connect to the wireless network using the utility of that adapter.
If you are using Win XP then you can use windows to connect to the wireless network or you can use other utility.
In case of Win VISTA, you will use windows to connect to the wireless network.
Click Here for more info
Dec 09, 2009 | Dell 1450 (D1450U) Wireless Adapter
What are the steps to hooking up your xbox 360 wireless network adapter
Plug the wireless USB adapter into the USB port on the back of the Xbox 360 console.
Turn on your Xbox 360 console.
The console will recognize the wireless adapter and will walk you thru the wireless network setup. Be sure to have your WEP key (if encryption is used) for your router before you start this process.
This adapter works well - I am using one and regularly play Modern Warfare 2 with multiple chat sessions. There is no noticable difference between my wired network connection and this wireless network connection.
Happy gaming!
Dec 02, 2009 | Microsoft Wireless Network Adapter Xbox...
Cant get wireless router to work on laptop
First, try to connect your laptop hardwired to the router, if it works fine, its just the wireless configuration. Make sure you are using the correct wireless network key to connect to your wireless network. Go to the Control Panel > Network Connections > Right-click Wireless Network Connection > Properties > Wireless Networks Tab and delete all the names listed under Preferred Networks box. Click Ok. Right-click on Wireless Network Connection again > View Available Wireless Network > Choose your own network and click Connect. If it asks you to type the network key, type in your WEP or Wireless Network Key and press connect. That should do it.
Oct 06, 2009 | Computers & Internet
How does the pc wireless adapter work for laptops with embarq equipment. currently using dsl with embarq.
pc wireless adapter will work then if you have also another network like wireless router or another PC or Laptop with wireless adapter, if your going to use this wireless adapter network in pc to pc is you are going to setup by adhoc to adhoc connection, itself detect for sharing a network without any router needed, but if you do such simple network connection use wireless router, its definitely work easily. Aumatomaticall detect wireless router on your wireless adapter network.. Good luck!
Jul 18, 2009 | 2wire (1000-100016-002) Wireless Adapter
I can't get it to work.
To view the wireless network connection dialog box, follow these steps:
  1. Click Start, Run, and type ncpa.cpl, and then click Ok.
  2. Right-click the Wireless Network Connection icon, and then choose Properties. (Or you can right click the Wireless Network Connection icon and choose View Available Wireless Networks from the shortcut menu.)
  3. Click the Wireless Networks tab.
  4. Under Available networks, click the View Wireless Networks button.
From the wireless network dialog box, you can refresh the network list. This performs another scan of wireless networks within range. The wireless network connection dialog displays the following for each detected network. The following shows the new connection box.
When the wireless network adapter displays the detected networks, you'll able to select a wireless network name and attempt to connect to it. The antenna icon indicates an infrastructure mode wireless network. The icon that shows two wireless client computers indicates an ad hoc wireless connection.
The lock icon and the "Security-enabled wireless network" label indicate that the wireless network has security enabled. The gold lock means you need a network key in order for you to connect to a wireless network. If it's not security enabled, you'll be able to connect to the network without a network key.
Apr 28, 2009 | Airlink AWLH3026T 802.11g/b Wireless...
go to my computer right clik it then select properties.
then go to device manager go to network adapters.
in there u see device or devices right clik on them and enable all one bye one .
thats it
Sep 29, 2008 | Dell Latitude C610 Notebook
HP Pavilion dv9000t Notebook Logo
70 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
