Computers & Internet Logo
Posted on Mar 10, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I want to get ptvkfeed new code - Computers & Internet
Anonymous
Level 3:
Brigadier General:
  • Master 8,909 Answers
  • Posted on Mar 10, 2011
Anonymous
Master
Level 3:
Brigadier General:
Answers
8909
Questions
Helped
1541664
Points
28391
If you type ptvcode into google search, the choice is yours.
Set combination for paragon lock & safe
TO SET UP OR CHANGE A USER CODE
1. With the door open, locate the red button on the back of the door near the hinge.
2. Press the red button and listen for the beep.
3. Immediately enter your new pass code (3-6 digits long)
4. Immediately after entering your new pass code, press the "A" or "B" button on the keypad. Your new user pass code is now stored.
NOTE:
This safe stores up to 2 pass codes (a user code and a manager code). Entering a third code will erase the
first pass code entered.
SETTING UP OR CHANGING A MANAGER PASS CODE
1. Open your safe with the pass code you wish to change and leave the door ajar.
2. Press the "0" button on the keypad twice. Press the red button, listen for a beep and then enter your new user pass code.
New user pass codes may be 3-6 digits long.
3. Immediately after entering your new code, press the "A" or "B" button on the keypad. Your user code is now changed.
http://www.paragonlockandsafe.com/manuals/mastermanual.pdf
Change the combination on a DHo74E
The SentrySafe electronic lock is shipped with a factory set master & manager code (777777).
You should set the lock to your own unique master & manager code immediately.
Please keep your codes in a secure location. You may also register your codes on our website at www.sentrysafe.com.
A single signal (LED flashes and beeps once) response from the lock indicates valid entry.
A double signal (LED flashes and beeps twice) response from the lock indicates an invalid entry.
• If three incorrect entries are entered in a row, the keypad will shut down for a period of five minutes. During this shut down period you will not get a response from the keypad.
Changing the Master Code
(Code length: 1 to 10 digit code) Always perform this operation with the door open.
1. Enter: # - Existing Master Code - #
2. The set light will stay orange for ten (10) seconds.
3. Enter: 1 - * - New Master Code - # - New Master Code - #, before the orange light disappears.
If a mistake is made during the change, wait thirty (30) seconds and repeat steps 1 thru 3.
Test the new code several times before closing the door: Enter: * - Code - #
• The lock will indicate a valid code change with a single signal.
• The lock will indicate an invalid code change with a double signal and the old code is still valid.
Changing the Manager Code
1. Enter: # - Master Code or Manager Code - #
3. Enter: 2 - * - New Manger Code - # - New Manager Code - #, before the orange light disappears.
Activate user codes
3. Enter: User ID Number (3-7) - * - New User Code - # - New User Code - #, before the orange light disappears.
If a mistake is made during the activation, wait thirty (30) seconds and repeat steps 1 thru 3.
• The lock will indicate a valid code entry with a single signal.
• The lock will indicate an invalid code entry with a double signal and the old code is still valid.
Example: # - Master Code or Manger Code - # - 5 - * - New User Code - # - New User Code - #. This will activate User Five (5).
Changing the user code
1. Enter: # - User Code - #
3. Enter: New User Code - # - New User Code - #, before the orange light disappears.
The Master and Manager can also change the user codes by following the "Activate user codes" section steps 1 thru 3.
Deleting user codesAlways perform this operation with the door open.
3. Enter: User ID Number (3-7) - * - # - #
Programming your lock codes
I want to change the combonation
The SentrySafe electronic lock is shipped with a factory set master & manager code (777777). You should set the lock to your own unique master & manager code immediately.
Activate user codes
SAMSUNG S5233 WHY THEMES IS NOT DOWNLAOD ?
Tired of memorizing new PIN codes? We show you how to change your SIM card's various PIN and PUK codes in less than 5 seconds.
Although most people remember their primary SIM PIN code, those other codes - used for various verification purposes - are never to be found when needed. Below we've included a set of short codes which, when entered on a handset's standby screen, will let you easily change PIN and PUK (short for Pin Unlock Code) codes - but keep in mind, they may not work with all handsets and mobile operators.
More importantly, when changing ones PUK codes there'll be no help to get from the mobile operator if the new codes are forgotten, so make sure to write any changes down alongside the old PUK codes. Also, please note that the codes should be entered without the spaces shown below.
Change SIM Card PIN
** 04 * old PIN * new PIN * new PIN #
Change SIM Card PIN 2 (Write down the new code)
** 042 * old PIN * new PIN * new PIN #
Change SIM Card PUK (Write down the new code)
** 05 * old PUK * new PUK * new PUK #
Change SIM Card PUK 2 (Write down the new code)
** 052 * old PUK * new PUK * new PUK #
Display Handset IMEI
*# 06 #
<a href="http://www.5starandroid.com">Android Mobile</a>
My samsung B7722, first time insert sim card, after enter pin number, error massage came out "phone freeze, sim unavailable, please contact your service provider" how to settle?
Although most people remember their primary SIM PIN code, those othercodes - used for various verification purposes - are never to be foundwhen needed. Below we've included a set of short codes which, whenentered on a handset's standby screen, will let you easily change PINand PUK (short for Pin Unlock Code) codes - but keep in mind, they maynot work with all handsets and mobile operators.
More importantly, when changing ones PUK codesthere'll be no help to get from the mobile operator if the new codesare forgotten, so make sure to write any changes down alongside the oldPUK codes. Also, please note that the codes should be entered withoutthe spaces shown below.
Change SIM Card PIN
*# 06 #
1helpful
I have an lg vu and i wanted to see what happens after the pin is gone 5 times now my screen just sayz puk blocked please need help!!!!!
If all else fails, you can use cellunlockstore.com for $1.99. Try the instructions below.
To change your SIM card's various PIN and PUK codes:
Change SIM Card PIN
Jul 19, 2009 • Cell Phones
26helpful
4answers
Enter PUK code, asked for new PIN code, but then get "code error"
my phone puk code got locked. i can unlock the puk code but it says enter new pin code. and when i verify it it says code error
5helpful
2answers
Trilogy dl 2700 serries digital lock program managers code
First you need to know if you have a standard 2700 or the new enhanced version, it makes a big difference. Press any 2 buttons then star, if you get no response it is a standard version, if it beeps several times it is the new version. If it is the standard version, disconnect the battery and press any button. Now you are at factory default. Reprogram the master code, remember the master code and the operating code must b e the same length. 12345 A 1 A new master code A new master code. The master code is the only code that needs to be entered twice during it's programming. To set a manager code press; master code A2A new manager code, to set a new user code; enter master code or manager code A11A new user code. The programming must be done during the lock's unlock window so write down the procedure you intend to use to make things go quicker, if you need more time you can change the unlock window, it is probably set at the factoy 5 seconds. Press master code A45A4, this will give you a 20 second window to program the lock, when you are finished change the lock back to 5 seconds, press; master code A45A1, keep the open window short to conserve batteries.
Door key pad, won't unlock door
  1. Enter the permanent factory remote keyless entry (RKE) keypad code.
  1. Press the 1/2 button within 5 seconds to activate the programming mode associated with the memory position 1 settings. Holding the 1/2 button for more than 2 seconds after activation erases the stored personal code.
  1. Within 5 seconds, enter the new 5-digit RKE keypad code. The door locks lock and unlock to confirm the new code is programmed and associated with the memory position 1 settings. Entering any new personal code automatically erases the old personal code.
  1. Press the 3/4 button within 5 seconds to activate the programming mode associated with the memory position 2 settings. Holding the 3/4 button for more than 2 seconds after activation erases the stored personal code.
  1. Within 5 seconds, enter the new 5-digit RKE keypad code. The door locks lock and unlock to confirm the new code is programmed and associated with the memory position 2 settings. Entering any new personal code automatically erases the old personal code.
  1. Press the 5/6, 7/8, 9/0, 7/8 and 9/0 button within 5 seconds to activate the programming mode or allow the system to timeout.
  1. Within 5 seconds, enter the new 5-digit RKE keypad code. The door locks lock and unlock to confirm the new code is programmed. Entering any new personal code automatically erases the old personal code.
Grand Canyon Tech
Grand Canyon Tech
