Question about Samsung HCL4715W 47" Rear Projection Television
The Tv will not turn on
It was working ok....did turn it self off one or two times in the last 2-3 weeks.
  • Anonymous Aug 17, 2008
    Every time i click on the tv button it don't come on .
  • RyanW1 Sep 07, 2008
    Hi. I realize that this is a little late but I'd like to ask a
    question. I recently purchased one of the HCL4715W Samsung TV's used,
    stated that the TV worked, but the power cord needed replacement. I
    simple clipped a cord from an old 13" TV and wired it in. I can hear a
    high pitched whine and a few clicks, then a quick mild pop in a
    speaker, then the unit stops. No picture, and the front light blinks
    several times. I tried reversing the cable, thinking I mismatched
    ground and lead, but no dice. Do you have any advice on what I should
    do or anything that usually goes wrong with these units? I'd like to
    have it/repair it myself, but I'm not sure if the tubes are any good,
    so I'd rather not drop a large amount of $ right off the bat until I
    can see the picture. Catch 22 I guess. Anyway, I don't think I can
    remove the box with the components in it, so I will have to transport
    the entire unit to the repair shop, if so, I will probably just sell as
    is. Anyway, thanks for reading, if you can help I'd appreciate it.
  • Samsung Master
  • 8,617 Answers
That model is quite famous for the deflection board going bad . They arent that exspensive to replace. If you need more info just respond to this same post.
Posted on Jul 31, 2008
No picture
can you please mention your tv model
Jun 12, 2008 | Sony FD Trinitron KV-32HV600 32" TV
Will Not Turn On
First you need to do a self test diagnosis and then if it comes up with:
SELF-DIAGNOSIS ERROR 23 OR 24. CHECK SOLDER CONNECTIONS AT CONNECTOR "DY" ON THE YOKES. 2. SHUTDOWN AT POWER WITH SELF-DIAGNOSIS ERROR 23 OR 24. CHECK C411 2200 UFD 35 V AND C412 10 UFD 50 V, BOTH LOCATED ON THE MAIN PCB
Do self test by pressing Input/Device and Menu at the same time for 5 sec. the set will show a 2 digit seq. first blinks followed by a short pause then the second.
Dec 29, 2007 | Mitsubishi WS-65807 65" Rear Projection...
Have a p50h401. In last week a few times, power
yes you have some few fan in the if they doesnt work it will hover heat thats could from the fan power voltage from the prower supply or the fan it self
you can try an external fan and blow the air on
the back panel in the aeration notch if it stand
thats your problem the circuit came over heat
hope that will help
regards Alan
Jun 07, 2010 | Hitachi P50H401 50 in. Plasma HDTV
PROTRON 26 TWO YEARS OLD
Symptoms of a Defective or dying Power supplies on LCD TVs.
1. Light(s) on the front panel are behaving not normal example, blinking, amber color or not steady, fainting, etc.
2. TV not turning ON properly.
3. TV turns OFF by itself.
4. Needs to be unplug to many times to make it work.
5. Humming or high pitch noise heard through speakers or at the back of the TV.
I repair these power supplies. Write to jah2mil@hotmail.com
Jan 20, 2009 | Protron PLTV-26 26 in. HD-Ready LCD...
TV Picture does not come on
Dec 15, 2008 | Audiovox FPE3205 32 in. HD-Ready LCD...
How much time to leave on self cleaning...clock does no work
Depending on the condition of the oven, it could take up to 4 hours.
I ran the auto self clean on my oven last week for the first time and it set automatically for 3 1/2 hours. (It stunk, but it worked.)
A couple things to remember is: (1) Make sure you do not turn the light on inside the oven. The clean cycle should disable it. (2) Lock the door if it does not lock itself. (3) Do not open the door during the clean cycle.
Remember the self cleaning temperature is extremely high. Do not allow children in the area while doing it.
Dec 15, 2008 | GE Profile JTP18 Electric Single Oven
Runs rough then clears up &runs great
found waste gate on turbo sticking freed up ok now
Sep 21, 2008 | 1991 Volvo 940
No channel available
Unplug it for 10 secs and plug it back in then wait 10 more seconds and turn it on with the on/off switch. Unplugging makes it reload the firmware, but on/off does not. If that doesn't work try a factory reset. For my Panasonic you do this. Open front door to get at the buttons. Turn TV off. Press and hold the OK button and at the same time press and HOLD the on/off switch for about 3 secs. You should get a self check screen that will last a little while and then the TV will go to the menu screen.
Sep 06, 2007 | Panasonic TH-42PX500U 42 in. Plasma...
Samsung HCL4715W 47" Rear Projection Television Logo
Henry  Thomas
Henry Thomas
