Question about Whirlpool LER5636P Electric Dryer
Had 4 prong had to switch back to 3 prong, now no heat???
Hi I moved from a newer home to a older home that has the three prong plug. I put the ground and neutral on the same block as told by my electrician father. I get it to turn on and tumble but no heat. I see that this is some other peoples same problem. I was just wondering if the switching of cords could have something to do with it. It worked fine before the move and I only moved a couple of miles so that should not have been to bad on it. Would swithcing that plug have anything to do with it, or should I go ahead and try all the other trouble shooting. It's just that I dont have a voltage meter, is there anything I can do to test this without one? Thanks
  • 5,911 Answers
Take a voltage reading across the RED and BLACK terminals to ensure you have 220-240VAC. It could be that you are missing one leg of the 220 service. An electric dryer requires 220 for the heating circuits to operate, but only uses 110 for the drive motor. You can perform this check in one of two ways:
1. Unplug the dryer and check at the receptacle across the two hot sockets. This will be the longer diagonal slots in the receptacle. A reading across the terminal should read 220-240VAC. If you're only getting 110-120VAC, you need to check each one to the neutral socket to determine where you're losing the voltage.
2. Unplug the dryer and remove the access panel in the rear, where the power cord plugs into. Plug the dryer in and take the same readings at the terminal block. Taking checks in this manner will also prove whether or not the power cord good or bad. CAUTION: There is live voltage present at the terminal with the dryer plugged (even with the unit turned off). Use care not to come into contact with the terminal when taking measurements.
I hope this leads you in the right direction. Please post back if you have further questions.
Posted on Jul 31, 2008
I just bought a frigadaire affinity dryer. Well my plug is a standard plug. Is there any where I can find a plug to have it fight my outlet?
Dryers in the US come in 2 varieties.
A 3 prong and a 4 prong plug.
The 3 prong is older, the 4 prong newer. (The 4 has been made about 10 years)
A hardware store or an appliance store will sell both cords.
If you wish to order it online, you can buy one off of e-bay.
The cords can be switched back and forth from machine to machine.
To find out how, ask "fixya" after you buy the cord that fits your outlet. Be blessed.
Mar 15, 2013 | Dryers
I HAVE AN OLDER MODEL KENMORE DRYER MODEL NUMBER 86872800 AND A NEWER HOME HOME WITH 4 CONNECTORS DRYER HAS ROOM FOR THREE HOW DO I CONNECT NEW CORD
You have to replace the dryer's 3-prong cord to 4-prong. Get yourself a 4-prong cord then on the terminal block at the rear of the dryer, connect the wires of the 4-prong cord to where the same wire colors (red, black, and white) of the 3-prong cord connects to. The only modification needs to be done is on the green/yellow stripe wire that connects from the white wire terminal to the dryer's cabinet. Remove this wire (green/yellow stripe) from the white wire terminal then connect it to the same wire color (green/yellow stripe) of the 4-prong cord and you are done. The new wire configuration would then be red, black, and white on the terminal block and green/yellow stripe wire on the cabinet.
Jun 16, 2011 | Dryers
I have a dryer with 4-pronged plug and just moved to a home with a 3-pronged outlet. Can I buy a 3-pronged cord to use with my dryer?
Yes, you can convert your 4 wire to three wire.
Go to the following website for the way to hook it up, it is easy.
This is a free answer, Please rate me
http://www.selfhelpandmore.com/switch-outlet/dryer-circuit-wiring-and-hookup.php
Oct 16, 2010 | Whirlpool Dryers
I am replacing a 3 prong cord with a 4 since we have moved into a newer newer home and the dryer has a white wire attached to the frame instead of a green wire. Is the the ground and can I just place the...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that will help you with changing your dryer plug.
Dryer Cord and Wiring Dryer 3 Wire or 4 Wire
heatman101
Aug 23, 2010 | Roper RES7646KQ Electric Dryer
The dryer has a four prong male plug and the outlet is a three prong female - which do I change? the dryer cord is the easiest, but how do I connect the leads?
4 PRONG PLUG WIRING: 2 HOTS(RED&BLACK) 1 NEUTRAL(WHITE) 1 GROUND(GREEN). 3 PRONG PLUG WIRING: 2 HOTS&1 NEUTRAL. YOU MUST USE 2 HOTS & 1 NEUTRAL ON A 3 WIRE PLUG. THE GROUND WIRE(GREEN) WHICH IS HOOKED TO FRAME OF THE DRYER IS NOT USED ON OLDER 3 WIRE PLUGS. IT IS AN ADDITIONAL SAFTEY GROUND ON NEWER MODEL 4 WIRE PLUGS.
Dec 25, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
The dryer had,a 4 prong plug,but my plug in,is 3 prong,so I put my old cord on it,the dryer spins but doesn't heat.do I need too switch plug in?
The following link explains how to correctly install a power cord on your appliance:
http://www.fixya.com/support/r3575913-installing_a_220_vac_appliance_cord
The main difference is how the Neutral (WHITE) wire and Ground (GREEN or BARE COPPER) wire are terminated on the terminal block in the back of the dryer:
- In a 3-wire configuration, these two wires are connected together via a ground ******** the terminal block.
- In a 4-wire configuration these two wires are independent of each other are NOT terminated together. Neutral is terminated at the terminal block and ground is terminated to theequipment cabinet via a ground lug.
NOTE: Newer homes built after the year 2000 REQUIRE a 4-wire configuration to be in complaince with the National Electric Code. In addition, some newer appliances may not work correctly without a 4-wire power cord. You want to refer back to your installation instructs to verify your power requirements.
If you have any questions, please let me know. I hope this helps you.
Dec 13, 2009 | Amana DLE330RAW Electric Dryer
I was switching the electrical cord from a 3 prong to a 4 prong and grounded a hot wire. there was a big pop and now i cant get it to start. would i have blown it up?
WHy are you switching the cord from a 3 to a 4? If the dryer came with a 3 prong cord and its a 3 prong terminal block, then i dont think you can change it to a 4 becuase you will short circuit. DOes the terminal block where your cord was hooked up have 4 terminals. Each termial can only have one lead/wire to it. check your circiut breaker panel? Is the circiut breaker tripped?
Jul 29, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
We have a Kenmore 70 series Electric dryer and it heats just fine and stays hot, air flow is good,(checked), however the clothes are not getting dry. My husband replaced the cord to the outlet from a 3...
Did the dryer get clothes dry in your old home with the 3 prong plug?
If so, id put the 3 prong plug back on it, and switch to outlet to a 3 prong...
Jul 10, 2009 | Kenmore 63942 Dryer
Whirlpool LER5636P Electric Dryer Logo
62 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Richard Roth
Richard Roth
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
