Magic Chef CYE2000 Electric Commercial Dryer
Problem for Magic Chef CYE2000 Electric Commercial Dryer
HELP
By cheathamdavi on Jul 31, 2008
ok my dryer wont turn but it heat up what do i do
Best Solution
posted on Dec 12, 2008
Very Helpful)
futureloginn
Rank: Guru
Rating: 89%, 383 votes
i am sending you all the possibilities for your problem, check either of these causes ----and than let me know if it is solved----
Power from the house
Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse
On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring
A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Was this helpful?
Yes
No
Popular Solutions for Magic Chef CYE2000 Electric
Questions and Unsolved Problems for Magic Chef CYE2000 Electric
Do you recommend Magic Chef CYE2000 Electric Commercial Dryer?
Answer
Answer
i have A AMANA DRYER AND IT WANT SAT IN MY 220 PLUG ,DO I NEED TO CHANGE THE ADAPTER OR WAT SHOULD I... (More)
Answer
My magic chef 2000 electric dryer wont start is the power controlled by the button that is... (More)
Answer
CYE2000AYW Magic Chef dryer. Replaced heating element and associated t-stats a few years ago. ... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Magic Chef CYE2000 Electric...:
Top Dryer Experts
Rank: Guru Guru
Solutions: 14935
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Dryer Experts
Top Washer & Dryer Repair
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
