Question about Epson CX4200 Stylus Color All-In-One Printer
Terrible grating sound when trying to print!
I know how I caused the problem, now I'm hoping there's a way I can fix this...
When trying to clear a paper jam using a pair of tweezers, the print-head suddenly moved. I fumbled, dropped the tweezers, and the print-head ran over the tweezers twice.
Two things then happened: the next print was striped with white lines. I then proceeded to clean the print-head to fix the problem (via the utilities menu). But when the print-head cycled through, it suddenly made the most awful grating noise!
I switched the printer on and off twice, but both times the grating sound came at the end of the cycle, then I get a flashing E on the display.
Did I totally ruin my printer, or is there something I can do?
Thank you very much for your help! Bettina
There was a tiny bit of paper stuck in the far left, under the carriage belt...
I pulled it out, and the printer is back, working beautifully.
Thank you so much for your quick response!
Bettina
Posted on Jul 31, 2008
  • Epson Master
  • 2,794 Answers
It could be timing issue with print head or the feed mechanism. You will have to get a service manual if you want to fix it yourself.
This link here was the only site I could find that had information on getting a service manual
How do I fix the tub in the washer that has come loose and makes a terrible noise while spinning?
Hi if your tub as come loose I would find that very unusual if the washer is a few years old & used a lot you will probably find that the bearing have broken down it will sound like a grating noise & you will be able to lift the front of the drum if you google change bearings on your model of washer there should be guides out there my washer is on its third lot now 8 years old hope this helps you
Feb 08, 2015 | Washing Machines
Tip
How to fix (workaround) Terrible sounding / input on win 7 64 bit with usb sound...
Terrible sounding / input on win 7 64 bit with usb sound drivers
looked for drivers from logitech - none besides setpoint - which didnt help
some fixed issue with a hub - tried - this didnt work either
workaround found
set output quality to lower than 44.1 16 bit - and sound clears right up.
thought i would let you know in case you came across the same thing <3
namaste
on Feb 04, 2014 | Logitech USB HEADSET H390
The gray grates on my 1991 GE XL44 gas range are terrible; can I find replacements?
That is not that hard to fix and you can easily buy the parts yourselfonline...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
heatman101
Feb 20, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
HP PSC 2350 all in one printer Is not feeding properly and message reads paper jam. Paper feeds almost until it should have finished the job, but no printing at all has been done. It started making a...
This may not help everyone that I send it to, but it is worth a try.
I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press
the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer.
The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Oct 15, 2009 | Computers & Internet
My printer has suddenly started printing terrible quality photos
It's possible that your cartridges are leaking into the printhead and cross polluting the other colours or there is a problem with the parking pad where the printhead "rests" when not in use.
I'd recommend removing your cartridges and checking for any ink leaks on these and/or puddles of ink in the printhead.
Then check the parking pad for any puddling of ink...
Given that you have a CX6600, which is now quite an old model, you may have a clogged waste ink tube and this is causing cleaning cycles to expiate ink into the parking pad but not actually draw it away, thus soiling the underside of the printhead.
Resolving this is not easy but involves a suitable inkjet cleaning solution (ammoniated windex is recommended in the USA) and leaving this in the parking pad to work at any clogging. It's likely to take a few days and repeated application of cleaning fluid but if a clogged waste pump is the issue this should eventually clear it.
One other possible cause is a dead pump.. If that's the case, it's time for a new printer as it's just not worth fixing.
Hope that gives some ideas.
Feb 14, 2009 | Epson Stylus CX6600 All-In-One InkJet...
Jamming paper
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Dec 30, 2008 | HP Photosmart C6180 All-In-One InkJet...
E120 won't print. Orange toner light is on - but the toner is nearly new ...
This problem is caused by an imitated toner............ All you need to do is change it to the old cartridge and see if the light will not be stable. Well the solution i guess is simple............. just go to get a new original toner and it should work well. Hope this helps.
Sep 19, 2008 | Lexmark E120n Laser Printer
Terrible noise when printing
turn off, remove the cartridge and turn back on, do you hear the noise? if no then it's the cartridge
hope this helps
Jan 07, 2008 | Samsung CLX 3160fn All-In-One Printer
Epson CX4200 Stylus Color All-In-One Printer Logo
99 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
