Question about Dell Dimension 2400 PC Desktop
Hard drive my old hard drive took a dump after i got a virus and now the computer sees the hard drive but it wont boot from it
    Novelist:
    Scholar:
  • 125 Answers
You will need to try a recovery disk or a working version on windows XP or Vista to boot from and repair, or format hard drive.
Posted on Aug 03, 2008
Computer says disk drive error press ctl alt del
MX6440 PC Notebook have a problem of file dumping
  • computer says disk drive error press ctl alt del to restart
  • Reastore or Reaper the OS may fix the problem
  • Or you have to Reprogram your computer by formating the System software
Dec 01, 2010 | Gateway MX6440 Notebook
I would like to replace the hard drive on my Acer Aspire 3004 notebook. The current hard drive is failing and I would like to install one that I took from another Acer computer that I threw away. The hard...
Hello lakotalisa,
Q:Where are the access panels for the hard drive and the RAM?
A: See the Bottom of your notebook. Please refer the manual for more details
Q:Am I correct in saying that once I change hard drives the virus will go with the old one?
A: Yes, You are correct.
With regards
Pankaj
Sep 22, 2010 | Acer Aspire 3004LCi Notebook
Windows xp pro will not boot with new hard drive
Its hard to tell just like this without having the computer in hand to check and test the jumpers and connection and all, but quick like this i think it might be a trojan virus that corrupted the boot sectors of the old hard drive, and when you copied the stuff from the old to the new, the virus followed and infected the boot sectors of the new one too. Try to reformat completely using the original windows install disk, and not the system restore/reinstall disk and reinstall windows after the format with the original windows disk again. If I was right, it should boot up OK with a fresh format and reinstall with the real windows CD, then install a virus scan and a spyware scan and scan and clean the old drive completely 2 or 3 times to be sure theres nothing bad left on it, then try to copy the whole disc, but skip the Windows repertory, the Program Files one too and the Documents and settings one also, cause those 3 are the ones most prone to corrupting a fresh install even if there is not any viruses in them. If it does not boot up OK after formating and reinstalling Windows though and says it's unbootable, then either there is a config error in the BIOS of the laptop, or the IDE controller that drives the disk is defective. If it's the BIOS settings, it's gonna be easy enough just changing the settings and won't cost you too much, and if its the IDE controller... then that's another story cause it's integrated in the motherboard like any other computer, so basically another computer will cost less than a new motherboard for a laptop. So if that is the case and the IDE controller is shot, you can still try to use an external USB drive to run the computer but not all computers support booting from the USB though, so before buying a brand new external drive, check the BIOS first to see if it does support USB booting.
Jul 08, 2009 | Compaq Evo N610C Notebook
MY PC WONT COME ON THE SCREEN IS BLACK
The mother board has a battery if thats the one you took out you reset the bios, Try pressing the delete simutanuosanly after turning on the computer then in the bios goto boot device priority and select your hard drive press f10 which is the save and exit. Try turning on your pc again and see if it boots off the hard drive make sure you give the computer time to re-boot itself after you change the setting in the bios.
Apr 08, 2009 | eMachines T3604 PC Desktop
No operating system found
sounds like the hard drivemag-glass_10x10.gif has either taken a dump and is not working or maybe the connection to it has been lost. Either way I think you have hard drive problems. When booting keep an eye out for where the hard drives are detected and see if the computer sees the hard drive.
Mar 29, 2009 | Computers & Internet
Hard Drive won't boot Windows
yes.. because the booting information and booting files are sored only in active primary partition of a hard drive. i.e primary drive. if you remove the primary it wont recognize the OS with out booting information. you should need to reinstall OS.
Dec 22, 2008 | HP Pavilion dv6000z Notebook
HO ZE 4400 LAPTOP
Hi there, it sound like a computer virus or trogan virus; it is a malicious program. You need to use an Anti-Virus or Anti-trogan program to get rid of it.
It could also be software problem like a corrupted file in your Operating System.
You should first format your hard drive and try it first and see what happens.
By formatting your hard drive, and re installing your Operating System, should correct the problem.
If not use the Anti-virus or Anti trogan program.
Oct 31, 2008 | Toshiba Satellite A65-S1762 Notebook
My hard drive is not working!!!!
You can access your HDD from the old computer but cannot boot your HDD from that old computer. I think you down load a file with virus, maybe your computer was infected with virus coming from that crack. Means you have to re-install your computer.
Oct 20, 2008 | ASUS P5QC Motherboard - Intel P45, Socket...
Computer isn't recognizing hard drive
Unable to see full amount of hard drive. Additional information and help with why the computer may not recognize the hard drive
Good Luck, Click on the link above follow instructions, Please dont for get to Vote, Thank You.
Dec 16, 2007 | HP Pavilion dv9000z Notebook
Computer wont boot up
hi, If it is a continuous beep then it a RAM error not a harddrive, so you try to change the ram slot if it doesn't happen change the ram thanks arun
Sep 04, 2007 | Intel SYNTAX S651M SIS651 mATX (SYNTAX...
Dell Dimension 2400 PC Desktop Logo
54 people viewed this question
Alun Cox
