Question about HP LaserJet 9500n Printer
Wrinkled prints hp9500
About 1 in every 10 pages comes out wrinkled. the 9500 is fairly new so i am hesitant to buy new feed rollers for it and someone suggested buying a new fuser. but is there anything i should look for first? ellen
  • ellenp Jul 31, 2008
    thanks - i appreciate your answer and will make a call. ellen
  • HP Master
  • 2,794 Answers
If its wrinkling, it's usually the fuser section. It sould be looked at be a technician.
Posted on Jul 31, 2008
Intermec PX4i label printer. Paper/Ribbon loaded correctly, but ribbon is 'rippled' meaning barcode label being printed has white lines across it. Any ideas?
Ribbon Wrinkle as it called can be caused due to the main feed rollers (that touch the ribbon or the label) being slightly worn. Even if you have a sligh gradient on the roller(s) it will pull ever so slightly to one side. If you need the parts then please do not hesitate to contavct me. Jack Woodworth - Codeo UK, 01179064587
Oct 19, 2011 | Intermec PX4I Label Printer
Problem with paper feed - all sheets come out wrinkled with smeared ink print
Sounds like your fuser is bad, ink is not adhering to the paper and building up on a roller that is causing the paper to wrinkle.
Oct 21, 2010 | HP LaserJet P3005n Printer
Every page printed has a wrinkle pressed into the paper
Its or moisture issue or wrong pressure between fixing roller and press roller.
Jun 30, 2010 | Office Equipment & Supplies
FIRST printed page is quite wrinkled, the rest are fine
Hello sir;Try to print one page, when the paper process half way then stop the machine, remove the cartridge, check the paper is wrinkling, if yes ,that's meanspaper feed roller dirty or registration roller slipply, ortherwise, check the fusing unit, need to replace presure roller. The 2nd issue, you need to replace paper stop roller or rubber pad.
May 12, 2009 | Brother HL 5250DN Laser Printer
Paper printing with wrinkles on hp 4100 laser
Pressure roller is worn. But the whole fuser assembly could probably stand to be replaced.
Mar 28, 2009 | HP LaserJet 4100n Printer
Z4MPlus Ribbon wrinkles causing lines diagonally across label.
Could be down to tension on the ribbon roller/spool. Check to see if you have pulled out the end part of the spool (black bit) that should ensure there is back tension on the ribbon.
Mar 27, 2009 | Zebra Z4M Printer
Paper feed problem Canon PC25 copier
check where exactly it wrinkle .it is most likely to be from the fuser unite.i.e where the paper comes out .if the fuser rollers is having mark or the paper sepration finger ontop of the roller is bend or loses its springing ability
Oct 07, 2008 | Office Equipment & Supplies
Paper feed problem
i disconnected turned upside down and started shaking it and believe it or not the roller starting working it prints fine!
Feb 03, 2008 | Canon MX300 Office All-In-One Printer
Crumpled pages
Damp paper is a common cause (concerina in fuser assy) as is lower heat roller being wrinkled (orange roller in rear)
Dec 31, 2007 | Brother HL-2040 Laser Printer
Phaser 7700GX Color Printer prints wrinkled pages!
when this occurs the problem is most of the time with the transport roller, fuser / fixing assembly roller.question is the image still toner only and not fused to the paper.
In these areas there is offen a jammed and not removed piece of paper dislodged in the paper path or jammed in the fuser or the transfer rollers teflon coating has perished inspect the areas carefully and remove any found if the unit still is faulty (fanning of paper the fuser would be the first to be replaced are past there usable life) if so then Post a reply
Sep 10, 2007 | Xerox Phaser 7700 Laser Printer
HP LaserJet 9500n Printer Logo
110 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
