Question about IBM ThinkPad R52 Notebook
Problem installing ram
I am trying to install some ram into my thinkpad. I already have the 512 that came with the system, and it supposed handle up 2028 megs (or somewhere in that area).
The ram i bought is 1 GB 200pin DDR2 sodimm - which according to specs should be more than compatible with my system.
When I install the ram and turn on the computer, i hear a series of beeps (like 1-2-3 (pause) 1-2-3), then the screen stay blank and nothing happens from there, I remove the new ram and everything starts up fine. I have tried this multiple times, defragging before installing, disk cleanup, running virus/spyware scan etc... but to no avail.
Any suggestions?
Thanks.
Oh, I'm running windows XP home edition.
  • stellarsound Aug 01, 2008
    OK, I read your reply and did some research using the link you provided as well as your knowledge.
    After doing some homework, I had a feeling that the possible bad memory slot you mentioned might have been the culprit. So I took the laptop apart, took out the factory 512 chip, and installed my 1 gig ram, put it back together and powered up and... she worked.
    So I just ordered a single 2 gig ram chip to replace the new 1 gig chip in the factory slot so I can get all the memory out of this thing that I can as I use it for lots of editing, photoshop/website design & music editing etc...
    I thank you for your help as I might have decided to take this for service. Instead, I found some good advice and the got nerve to take this machine apart, learn something new and save some money at the same time.
    Genius:
  • 2,028 Answers
You have the wrong memory chip. The beep code you hear indicates that there is no memory or incompatible memory. The memory you need is PC4200, Which is a 533mhz chip. Memory has a frequency rating that is matched to the processor and motherboard. Not just any DDR 200 pin memory that fits will work, the frequency has to match or it won't work. The new chip should be labeled, make sure it reads PC4200 or 533mhz, if it reads anything else it's the wrong chip. If it is the right frequency chip, then you may have a bad memory slot, the chip is bad, or mislabeled. Here's a link to a memory configurator that gives the memory specs for your machine.
http://patriotmem.com/configurator/modelp.jsp
Posted on Jul 31, 2008
  • Ryan Rogers
    Ryan Rogers Aug 01, 2008
    You're welcome. You should also keep in mind that in some machines each individual slot will only hold a certain amount of memory, if your machine only shows 1g after installing the 2g chip then you will know why. I hope the 2g chip works out for you, if there's anything else feel free to ask, and don't forget to rate me (fixya). Thanks
    Pyrhyc
Installed 512mb pc133 ram memory and it wont boot up
The laptop needs pc100 not 133 ram. it may be able to work on 133 but if you already have a pc100 stick in there it wont boot up. but all the recommended ram is only pc 100 and the Maximum it supports total is 512 mb
May 14, 2011 | IBM ThinkPad T22 2647 Notebook
RAM chip sets
It is OK to mix chip (SODIMM) capacities in the 2 slots in your notebook.
The best system performance will be when you have 2 x 512MB but for now if you install 1 x 512MB, you could even leave the old chip in the other slot, it'll be fine.
Oct 19, 2007 | IBM ThinkPad R31 2656 Notebook
Hello Sir, I had 512 MB 533 MHz DDR2 RAM(Dynet). Now I have bought 1 GB 667 MHz DDR2 RAM(Dynet). My system has 2 slots. In one slot, I have 512 MB RAM and in another slot, I installed 1 GB RAM that I have...
The Intel D102GGC2 uses a Dual Channel Memory Architecture meaning that both slots need to be running at the same speeds. I would suggest getting another 667 MHz RAM card and installing it along side your current one, just as I reminder this motherboard only supports 2GB RAM Max so don't get one that is above 1GB.
Mar 28, 2011 | Intel D102GGC2 Motherboard
Can I increase the ram in my think pad?
Hello
Memory Upgrade for IBM ThinkPad R32 2658-xxx Laptop, the IBM ThinkPad R32 2658-xxx Laptop takes the PC2100 DDR SDRAM SODIMMs Memory Type, and comes installed with 128 or 256 MB (removable) of Memory. You can upgrade your IBM ThinkPad R32 2658-xxx Laptop to up to a maximum of 1.0 GB Memory, the system has 2 sockets to install Memory, already with 128 or 256 MB (removable) standard Memory installed. For best Laptop performance use the maximum amount of allowed Memory per slot for your Laptop.
good luck and do rate the solution if helps.
Dec 22, 2010 | IBM ThinkPad R32 2658 Notebook
Hello i can't install a AGP 512 videocart I bought
your computer needs more than the video card ram amount to use a particular video card. if you do not have at least 512mb of system ram, that may be your problem. if you have sufficient ram, then you do not have a powerful enough power supply for the new card.
Nov 22, 2010 | EliteGroup KV2 Lite (V1.0) Motherboard
What is the maxium upgrades that I can give my Thinkpad T20 Series 2647, from speed to memory and possible going from a Pentium 3 to a 4?
You can't upgrade the processor: it's already at almost maximum and you can't change models - different socket. The maximum RAM you can install in it is 512 MB of PC100 SODIMM-SDRAM so the speed difference will be negligible.
Oct 09, 2010 | IBM ThinkPad T20 2647 Notebook
I would like to nwom how much of memory this laptop support
The Thinkpad is installed with 128 MB SDRAM is standard, and is expandable to 512 MB
There are two memory slots, to expand it to 512 Mb you need two 256 Mb RAM modules and throw away the 128 Mb RAM module, but if you don't throw away this module and you insert a 256 Mb RAM module in the 2nd memory slot then your total memory would be 384 Mb.
Nov 20, 2009 | IBM ThinkPad T20 2647 Notebook
I am supposed to have 512 mb ram but my system shows 384 ram even when I am doing nothing why
128MB of your RAM is dedicated to the video port. Low end pc share the installed rams to run video streams instead of having its own dedicated ram. No matter how much ram you install, the system will always deduct 128mb for video.
C2Solutions
Aug 13, 2009 | eMachines EL1210-11 PC Desktop
Increase ram
You can use two 512Mb sticks which will equal 1024Mb or 1Gb.
Hope this helps.
DS
Mar 14, 2009 | HP Computers & Internet
System won'n boot if i installed two RAMs
Is the old ram working if installed alone? If yes then maybe got error or grounded if both ram inserted. Try to blow air the ram slot in the board to eliminate dirt and then try to interchange the position of the ram and then try it again.
Hope this will work.
melnavz
Feb 12, 2009 | ASUS P5RD1-VM Motherboard
IBM ThinkPad R52 Notebook Logo
107 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
