Question about HP Computers & Internet
I cannot load the new printer all in one until the old is uninstalled. i do not ahave the disc to do that. i need to install the new 7780 and uninstall the 7410 hp printer
    Novelist:
  • 202 Answers
Just put the model number on google .com u get links to it and download it and install
Posted on Aug 01, 2008
1300 printer will not accept my install disc
Please try this approach:
  1. Uninstall your existing printer driver. On your computer, go to Start menu > Programs > Lexmark 1300 Series folder > Tools > Uninstall. After the uninstall process, reboot your pc when prompted.
  2. When your pc turns on, check if your Windows 7 is running on 32-bit or 64-bit operating system. On your computer, go to Start menu > right-click on Computer > click on Properties. Take note of the System Type.
  3. Use the link below to download and re-install the corresponding printer driver for your operating system:
Simply follow the instructions on your computer screen to complete the installation.
Feb 04, 2012 | Lexmark Office Equipment & Supplies
I just got a new lexmark and disc. i have to disconnect the old lexmark from my computer before i install the new lexmark. how do i disconnect the old printer
Once you have physically unhooked the old printer and all of its cabling and moved it out of the way of your computer, cick on Start > find the Control Panel and click on it > in the Control Panel look for Add/Remove Programs OR Programs/Uninstall Programs. Once you are in there, look for anything related to your OLD Lexmark printer - select it - and click remove/uninstall.
After removing every piece of software related to the OLD Lexmark printer, restart your computer. You should then be able to install your new printer without any issue.
Jun 14, 2011 | Lexmark Office Equipment & Supplies
I am trying to install a new computer which previously had a different HP3015 printer. How do I get the computer to recognize the new HP3015?
Before you start the installation it would be best to uninstall the old printer driver. Then connect the new printer, put in its disk, wait until that starts to load, and when it prompts you, turn on the new printer. If this helps, Please Rate me! :)
Jul 14, 2010 | HP LaserJet 3015 All-In-One Printer
Do you have to uninstall old printer before installing new one
yes and make sure you diconect the usb cable first after you uninstall it re start your pc then install the other one do not connect usb cable until prompted during installation
Jul 26, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Hello here! i have tried to install my lexmark x5150 to my compacq laptop, and cant get it to print, i have installed the disc countless times wiyh out any progress can you help?
Try this:
first uninstall the disc's software
than restart the laptop
if correct it will automaticly detect your printer and ask for the disk.
cancel the installation.
Insert the disk and cancel the automatic running program for installation.
go to start, printers, add new printer and follow the steps from there untill it says "have disk" click on have disc and brose to your CD drive. It will automatically indicate which program it requires, search on the disc that program and click OK and continue the steps.
Reason: automatic installations from manufacturers sometimes do not install all files needed by windows, installing via windows itself it will automaticcaly pick the correct files from the disc.
Jan 28, 2009 | Lexmark X5150 All-In-One InkJet Printer
C++ Runtime Error for Dell Photo AIO 962 printer dlbxmon.exe
I had the same problem and was able to fix it by following the instructions in this link:
http://forums.cnet.com/5208-7590_102-0.html?forumID=67&threadID=300180
Apparently, the regular uninstall procedure does not completely uninstall the software drivers. Then, if new drivers or software are installed, a conflict is created between the old drivers and the new drivers. You have to first run the DellXPCleanUpUtility to completely clean out the old software drivers. Then, you can install the new drivers successfully.
Jan 02, 2009 | Dell 962 Photo All-In-One InkJet Printer
Unable to install Lexmark 8300 printer
You can find the set-up manual of your printer here.....www.lexmark.com/publications/eng/8300/index.html
I need you to make sure that the driver you are using to install the LEXMARK 8300 is compatible with VISTA.
you can download them at, www.driversplanet.com/device.php?id=107349
Before installing the new driver you have to uninstall the old one. If the system is not permitting to uninstall the driver, then try installing the new driver by the following steps:
ensure your printer is connected to your computer and the power is on
 1.) click start / right click computer and select properties
2.) click device manager
3.) Click View then show hidden devices
4.) right click on the printer and click uninstall
5.) Unplug your printer usb from your computer
6.) RESTART
7.) INSTALL THE PRINTER WITH THE VISTA DRIVERS YOU DOWNLOADED..
 REMEMBER NOT TO PLUG IN YOUR PRINTER UNTIL THE SETUP SOFTWARE TELLS YOU TO DO SO.
Hope my info will solve your problem, Thanx for using fixya, Good luck.
Sep 29, 2008 | Microsoft Windows Vista Ultimate Edition
Can not scan from printer to computer
Version 7 Disc sent with the printer has been updated. New version is at HP Website 8.0.2 I think, you need to uninstall software through installation Disc then download new software to load.
Yes it wasted a lot of my time too.
May 01, 2008 | HP Office Equipment & Supplies
PC won't detect MFC-210C Printer
TRY THIS, remove or uninstall the printer from your computer and turn it off.
Now, before you switch back ON the computer, remove the USB connection of your printer.
When the computer is done loading. Install the Printer using the CD that comes with the printer.
When the installer ask you to insert the USB connection of the printer,
that's the only time you should insert it to the USB port... switch ON the printer... Installation should proceed smoothly until completed.
That should solve your problem
Jan 21, 2008 | Brother MFC 210C All-In-One InkJet Printer
Computers & Internet Logo
20 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
