Question about Dell Inspiron 1501 Notebook
1992 honda The pressure switch is a dual pressure switch. I have not seen any kind of adjustment screw but i ll look. I knew the vehicle was r12 originally but the 134a fittings on the lines is what got me and no conversation sticker. from my understanding the parts i converted over on the car are r12 and 134a combatable. I dont know. If thats true then i thought about emptying the system, blowing it all out, pull a vacuum on itand refill it with r12 and see if it returns closer to normal. But i don't know for sure if i should. I figured the door ajar lights weren't tied into this problem, but with foreign engineering, you never know. I will try crimping the high end hose also. I'm going to try everything i possibly can before i replace the compressor or take it to someone. and i have no idea why the dell computer **** is on all these messages.
  • yadayada
    yadayada May 11, 2010
    Yes many systems allow the AC cycling switch to be adjusted, there is a screw under the connector, but not all have this feature, also you need to know if the system charge is correct, what are the high and low side reading with the engine held at 1500 RPM and the system stable for at least 5 minutes?, R134 is denser than R12, the charger amount is less than the amount the manufacturer lists for R12, about .9 lbs of R134 to 1 LB of R12 is the ratio I think but look it up to be sure.
    Genius:
  • 2,028 Answers
You posted this under the laptop category. Try reposting under automotive, you'll reach more experts in the automotive Field, and you'll get a better response. I have some knowledge to air conditioning systems. I don't have enough technical knowledge to tell you why, but the way I understand it is that if the system has been converted to 134 the 12 will not work due to the refrigerant composition, but you can try. If you're just not getting the cold air you want, you might look into the accumulator. If it's not working correctly or partially plugged this could be your problem. If my suggestions don't flip the bill, then try posting in the automotive section.
Posted on Aug 01, 2008
R12 to r134a 1996 honda accord recharge
yes, L is for low pressure side or suction, attach refrig. to this port
Jul 15, 2012 | 1996 Honda Accord
How can I determine whether or not my 1992 Honda Accord has been retrofitted for 134 refrigerant.
R12 fittings are threaded on the outside and are smaller than R134a fittings which have no threads on the outside.
Jul 26, 2011 | 1992 Honda Accord
What type of refrig. does the AC use in a 92 dodge caravan
Unless the labels are missing from the car, it will state which type of refrigerant is used. Could be either R12 or R134a. If originally R12, it could have been replaced by R134a with an upgrade kit. The easiest way to tell if the labels are missing, is to look at the valves on the AC system. If they are Schrader valves (same as used on tires), then it is the older R12. If the caps are Red (high pressure side) and blue (low pressure side), then it is R134a. The sale of R12 to non-certified mechanics is illegal in all states as far as I am aware. R134a is available in most states and retro-fit kits are available in most states.
I have done the retro-fit on 2 vehicles with acceptable results. It is recommended to remove all the old R12 with a vacuum pump. Autozone (in my area anyway) rents these.
Good luck if you need and decide to retro-fit yourself.
Jul 04, 2011 | 1992 Dodge Caravan
My 1997 toyota tacoma needs refrigerant. Just wondering if it needs 134 or r12?
r134a was used from 1992 onward in my memory.
r12 was being phased out in the early 1990s.
The r134a system uses quick connectors which are not the same as the screw on connectors that r12 used. So, one can tell that way as well.
Oct 07, 2010 | 1997 Toyota Tacoma
I have a 1992 Honda accord EX , my brake lights will not go off. Ichecked the fuse it's good obviously! Do I need to check the brake light or brake pedal ? I need 2 fix this since it is my wife's car,...
There is a brake light switch that's adjustable. Try pulling back on the pedal, and if that doesn't help you will need to adjust the switch. It's located on the pedal arm usually under the dash. It's just an on/off type switch.
Aug 10, 2010 | 1992 Honda Accord
Where is the low pressure va for to put freon
Has your vehicle already been converted to 134a freon? If not it is R12. Don't mix.. Take to shop and have charged. Unless you are mechanically inclined and get the switch over kit.
May 03, 2010 | 1992 Honda Accord
Honda cbr 600f2 throttle adjuster?
Sounds like you were adjusting the idle mix screw on the carburetor. I think www.bikebandit.com has OEM parts, with diagrams. Also, there are many forums for different motorcycles and their owners on the internet, I would try a Google search for the right forum for your bike. Good Luck!
Nov 10, 2008 | 1992 Honda CBR 600 F(2)N
High throttling problem
You either have a vacuum leak at the intake manifold or the idle speed control stepper motor is defective.
Jul 25, 2008 | 1992 Honda Accord
Dell Inspiron 1501 Notebook Logo
35 people viewed this question
Alun Cox
