Question about Sony FD Trinitron WEGA KV-32FS120 32" TV
Half a screen
Turned television on to find only picture showing in the bottom half of the screen on Sony 32" flatscreen. Any ideas?
  • 125 Answers
Problems on the vertical section I can do it for $ 180
we need to replace the vertical integrated circuit and poblably some caps
Posted on Aug 06, 2008
My 32 inch westinghouse digital flatscreen lcd tv appears to be broken, I can turn it on from the remote but the screen does not show, it can even go to sleep but where is the picture?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Dec 26, 2015 | Westinghouse Televison & Video
Sony model kv327fv310 tv only bottom half of picture shows
Vertical scan output section fault. Contact any service technician, to replace the damaged component/s. To get some details, http://electronicshelponline.blogspot.com/ Pull up older posts.
Dec 09, 2013 | Sony FD Trinitron WEGA KV-32HS510 32" TV
Hi, I have a Sony Trinitron flat screen television that was working at 5:30am, but all I get are clicks when I try to turn the power on...thoughts..is it time to upgrade or is it an easy fix?
There are two IC's that need to be replaced they are on the D Board, One is used in the power regulation and the other is for HV Regulation, cost to repair this plus parts should not cost more then $150.00..
Please leave comment.. THKs
Oct 05, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony tv picture blinks on and off
examine main board solder connections-preffeably with 10X magnifiers or is it just me lol--look for ring cracks in main power area and regulator chips,also flyback area-- good luck )
Jul 20, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
New flatscreen Sanyo tv. Picture is to big for the screen
use the picture button to change the shape, Most likely you have it set to picture 3 which would cause that.
Jul 04, 2009 | Sanyo DP32648 32 in. LCD TV
Blackout area on screen
Make sure the TEXT and CAPTION options are turned off.
I am not sure about the Sonny's, but on my Toshiba a black box appears when I inadvertently leave one of the close captioning (CC) on for text or captions on (such as CC1, CC2, etc.).
Feb 15, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony trinitron 32 " purple area on screen
Check any magnatic device near TV which causes purple color on screen. That device can be Speaker, Electronic toy, Watch like that carring piece of magnet inside. Remove that device and turn OFF your TV for half a hour, then power again. Hope the color will be fine n normal on entire screen.
May 31, 2008 | Sony FD Trinitron WEGA KV-32XBR400 32" TV
Half screen picture
This is commonly caused by failing capacitors in the vertical deflection amp area and sometimes with the output drive devices.
An experienced TV tech can troubleshoot your set and service it for you.
Jerry G.
May 17, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Half Picture
I have seen this caused by 2 different problems. The vertical output IC could be bad but it is usually the CXA jungle IC that fails to cause this. Either way the set should be serviced by someone experienced in repairing Sony TV's.
Aug 09, 2007 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Picture separated on 1/2 of screen
This sounds like a convergence problem. This is a common problem that is usually fixed 98% of the time by re-placing the STK392-020 ic or STK392-110, and check the fuse devices on the covergence PCB. I'm sure the actual parts numbers depend on the peticular brand. Good Luck!
Nov 09, 2006 | Toshiba TP43H95 43" Rear Projection...
Sony FD Trinitron WEGA KV-32FS120 32" TV Logo
91 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
