Question about Coby TF-DVD7107 Portable DVD Player
I have a coby vzon that says wrong disc but reads cds then when cleaned and blown loads up mp2 instead of dvd or says wrong disc still please help.
  • 635 Answers
All DVD players use a dual laser pick up. One laser is for CD/VCD/MP3 and the other laser is only for DVD. If you have watched more DVD and less CD's you could be having a problem with the DVD laser. Must have become week and the system cannot read the disk. Change of the lens unit will solve your problem.
Posted on Mar 10, 2011
    New Friend:
DVD PORTABLE COBY (VZON) w/ T.V Tuner
- no power
- with or w/o battery
-even direct in charger no POWER
- battery POP
Posted on May 04, 2011
SOURCE:
Coby dvd-514 reads wrong disc
Coby DVD 514 Instruction Manual Page 24
use a dvd player cleaning disc,,make sure the disc is supported,it is NOT a blu ray player,only a dvd player,make sure the discs are clean and not scratched
May 09, 2015 | Coby Televison & Video
How to repair dvd player v zon says wrong disc
Hi Vzon DVD Player,
Before you fix anything, you need to troubleshoot the problem first to know what needs fixing. Since DVD players can play different kind of media formats like Audio CD, VCD, mp3, etc, please try the following
1. Turn on the DVD player and set the program to DVD. some player needs to be setup due to multiple functionality (can play mp3 on flash drive, etc..)
2. insert different Media CD as mentioned above if your player will play them. (if they play, try to insert the DVD you want to play)
3. Try different DVD disc
4. If all the above don't work, try to clean the laser head using the standard disc cleaner.
5. retry the DVD disc
6. If the player still don't play your DVD, probable issue would be the laser head or the disc motor.
7. Please bring them to you nearest Electronic repair shop for further assessment.
Good luck and thanks!
Aug 20, 2011 | Coby TF-DVD7107 Portable DVD Player
Dvd player says loading then wrong disc
If it is disc made with a computer, you may need to convert the format to one that the DVD player is compatible with so it will recognize the disc contents.
Sep 22, 2009 | Coby TF-DVD7005 Portable DVD Player
Coby DVD shows Invalid Disc HELP PLEASE
Did you make the disk if you made the disk your computer has to give it a digital signature so the DVD player can read it if you're using a regular DVD then I would very carefully using rubbing alcohol and Q tip clean the actual laser I would be very careful doing this if too much rubbing alcohol is on the Q tip it will ruin the laser you can also try resetting the DVD player by taking out the battery and unplugging it from any power source and leave it that way for at least 20 seconds to a minute if that doesn't work you might have something else wrong
Jul 18, 2009 | Coby TF-DVD7005 Portable DVD Player
No picture
I gave up on the cheap Coby unit and upgraded to a more expensive toshiba one.
Sep 07, 2008 | Coby DVD-224 DVD Player
Wrong disc
If this model displays Wrong Disc even when you play all kinds of CDs, you may want to buy a CD/DVD laser cleaner for it.
Does this solve the problem?
Aug 03, 2008 | Coby TF-DVD7005 Portable DVD Player
Coby vzon portable dvd!
Maybe it's for the different region?
Feb 26, 2008 | RIM BlackBerry Pearl 8100
Wrong disc problem
This is a known problem - there is no fix - if you call coby customer service they will tell you to try a dvd lens cleaner -this will not fix the problem. Best advise - throw it away.
Feb 26, 2008 | Coby DVD-224 DVD Player
WRONG DISC
it is the internal lazer light. if you communicate with coby they will fix it . it seems to happen quit often ed
Aug 02, 2006 | Coby DVD-224 DVD Player
Coby TF-DVD7107 Portable DVD Player Logo
405 people viewed this question
Top Coby Televison & Video Experts
Steve Allison
Steve Allison
Are you a Coby Televison and Video Expert? Answer questions, earn points and help others
