Question about DeLonghi CF210 Portable Air Conditioner
Delonghi parts i bought a used delonghi cf210 unit...it's missing the window bracket and the exhaust hose...where can i get these parts? thank you angie
  • Anonymous May 05, 2009
    Need to find exhaust hose
Hardware stores would be a cheaper way in the plumbing section
Posted on Dec 04, 2009
Error code e6 what does that mean air conditioner will not start
DeLonghi CF210 Portable Air Conditioner Error code e6 ...
www.fixya.com > ... > DeLonghi CF210 Portable Air Conditioner
DeLonghi CF210 Portable Air Conditioner, error code e6 related issues. Get free help, solutions & advice from top DeLonghi experts.
Error e6 displaying on single split model one - Fixya
www.fixya.com/.../t4492271-error_e6_displaying_single_split_model
Apr 5, 2010 - Question about DeLonghi CF210 Portable Air Conditioner ... then the code error display E6 and the error code is Communication malfunction.
DeLonghi fix e6 error Air Conditioners Questions & Answers ...
www.fixya.com > Forum > Tags > fix e6 error > Air Conditioners
DeLonghi air conditioners fix e6 error related questions and answers. ... DelonghiFX400eco error code I Have the above air con unit 18 months old the cooling ...
DeLonghi CF210 Portable Air Conditioner Error code e6 split
Jan 01, 2016 | DeLonghi Heating & Cooling
I just bought a used DeLonghi Pinguino PAC 02. It seems to cool ok but the exhaust hose gets very warm. Is that normal?
Yes, that is normal. It's exhausting the heat from the compressor out the window.
Thanks for choosing FixYa.
Sep 09, 2011 | DeLonghi Pinguino PAC-02 Air Conditioner
What is the maximum length of exhaust venting that one can use
According to the manual the longest run of pipe that can be used is 78.7" (6'6.7"), but the maximum termination height is 51.2" (4'3.2"). Hope this helps
http://www.delonghi.com/delonghi/data/int/usa/libretti.nsf/d43b2a60086dfe93c1256a47004ad1f5/37974a66fe82678885256f1200671bfa/$FILE/CF210.pdf
Jan 18, 2010 | DeLonghi CF210 Portable Air Conditioner
How do i connect the air hose?
Shuld have been a connector with unit. Just slip the hose over the connector and use a large ziptie to tighten it down. You can also use some duct tape also but I always use a zip tie. Rus
Nov 07, 2009 | DeLonghi CF210 Portable Air Conditioner
Air exhaust hose gets extremely warm
The Pinguino's exhaust pipe has to be attached to the window bracket to direct the air hot air out of the room, otherwise the room can't cool properly.
The owner's manual has several troubleshooting remedies for you to try:
1)  If the window is open, close the window. 2)  If there is a heat source in the room (burner, lamp, etc.), eliminate the heat source. 3)  If the exhaust hose is detached, connect the exhaust hose.  (My recommendation is to connect the exhaust hose to the window bracket and direct the air outside.) 4)  If the air filters are clogged, clean or replace the filters.
Remedies that aren't mentioned in the manual, but you might find helpful:
1)  Make sure that there are no kinks in the hose, and that the hose either remains straight or has a gentle curve when directing it into the window bracket.
2)  A sunny window reduces the maximum power and efficiency of the unit.  Placing it in a sunny window reduces your BTUs by at least 600, which means the maximum square footage of cooled space is reduced.  Cooling a kitchen requires at least 4,000 BTUs alone, which is nearly half of the unit's BTUs.  Try to place the unit by a window that receives minimum to no direct sunlight.
Finally, stating the obvious, if the room isn't cooling, the room is too large for the unit.  The PACL90 cools up to 400sqft.  Bear in mind that the air from these portable air conditioners cannot move around corners very well, so try to set it by a window in the central part of the room.
Jun 13, 2008 | DeLonghi Pinguino PACL90 Portable Air...
Extension cord is black delonghi cf210)
well , yes , it could be fixable , but first the adapter is a three prong to two prong adapter ? if so , for your safety I recommend to plug A/C UNIT wheres a three hole outlet , using the adapter eliminate the UNIT to be grounded , there for causing problems like cord getting hot. hope this helps
Apr 27, 2008 | DeLonghi CF210 Portable Air Conditioner
Need AC for Server Room
I find it amazing that in this day and age IT manager will still scrimp on there server room environmental systems! It must not be that critical! Anyways you'll be better off with a split type unit correctly sized for your server room. Toshiba now have small units that can pump up to 50 meters away if needed. the key is to have it correctly sized!
Nov 10, 2007 | DeLonghi CF210 Portable Air Conditioner
DeLonghi CF210 Portable Air Conditioner Logo
349 people viewed this question
Top DeLonghi Heating & Cooling Experts
Paul Carew
Michael Youngman
Michael Youngman
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
