Question about Whirlpool Duet GHW9150P Front Load Washer
F21, 5d, and now not working
I had a f21 error. so I opened the bottom panel and cleaned out the drain. I drained it and all went well. Then I did a rinse spin cycle and got a 5d error message. That luckily resolved itself within a few minutes and the machine started again. It worked for another few loads last night, but then this morning we got another 5d error. This has not resolved itself. I put the cycle on drain spin and now the machine doors lock but nothing else happens after that. Can you help me?
  • bradthebike Aug 02, 2008
    I have same problem... what the cost to repair it? can you do it yourself if you get the parts?
  • Anonymous Mar 30, 2014
    Started with an f8e1 error
    Now control panel is frozen
    Unplugged unit over night when I plugged it back in the drain motor is running and won't stop, panel still frozen
I had to call the Whirlpool service man. He came and concluded that the control panel was the culprit. He said it could be that the contacts were bad, but he didn't want to unstack the washer/dryer (dryer is on top of washer) to check it. He was suppose to call me to day with a price for another control. I'm just going to go and buy another machine. Can you recommend a reliable front loading washer?
Thanks for all your help!!!
Judy
Posted on Aug 01, 2008
Samsung vrt nd or nb error code
ND is not draining, the washer probably has water in it and won't open. In which case you need to open the little tiny panel on the front of the washer and pull out the little hose and drain the washer and then clean our the filter next to the hose. NB means not balanced and the clothes have become unbalanced, move the clothes around and start it back up. If it happens a lot the washer is not on even ground and needs to be leveled.
Feb 18, 2015 | Samsung 3.5 cu. ft. High Efficiency VRT...
F2 fault
F2 is a drain error in your washer, if the unit is unable to drain then after 4 minutes it will display F2. The first thing that should be done is cleaning the drain hose and the drain pump filter, you can take out three torx screws from the bottom front panel and then clean the area completely, lift up the cap to clean the filter. If the error returns then check the drain pump if it is not working then replacing the pump is recommended repair.
Jan 21, 2013 | Siemens Washing Machines
My bosch washing machine model WFVC6450Uc/19 FD 9002/901476 has E:13 flashing. i was able to drain the water manually but now the door locked there is beeping sound when i try to start it. how to fix it
Hello & Welcome to FixYa
E13 error in your Bosch WFVC washer is a drain error and is displayed when the drain time exceeds & the washer is unable to drain so the door won't open sometimes when this error is displayed. You will have to clean the drain trap in the bottom right hand corner. You can stick a straighten paper clip in the access panel located inside the front bottom panel through the whole and then turn the access panel counter clockwise to unscrew the plastic drain cap behind it. After everything is cleaned and the error returns then replacing the drain pump is recommended repair. Please get back to me if you have any other questions.
Kevin
Oct 08, 2011 | Washing Machines
E:13 Error on our Bosch 500. I threw a load of wet towels (from swimming) and turned it on. About a 1/2 hour later I heard it beeping, so I went to check on it. The soap was still in it, which tells me the...
E13 error in your Bosch washer is a drain error and is displayed when the drain time exceeds & the washer is unable to drain so the door won't open sometimes when this error is displayed. You will have to clean the drain trap in the bottom right hand corner. You can stick a straighten paper clip in the access panel located inside the front bottom panel through the whole and then turn the access panel counter clockwise to unscrew the plastic drain cap behind it. After everything is cleaned and the error returns then replacing the drain pump is recommended repair. Please get back to me if you have any other questions.
Kevin
Jul 31, 2011 | Washing Machines
Bosch E13 error on washer - shows e-13 and door will not open.
E13 error in your Bosch WFMC washer is a drain error and is displayed when the drain time exceeds & the washer is unable to drain so the door won't open sometimes when this error is displayed. You will have to clean the drain trap in the bottom right hand corner. You can stick a straighten paper clip in the access panel located inside the front bottom panel through the whole and then turn the access panel counter clockwise to unscrew the plastic drain cap behind it. After everything is cleaned and the error returns then replacing the drain pump is recommended repair. Please get back to me if you have any other questions.
Kevin
Jul 30, 2011 | Bosch Nexxt 300 Series WFMC2201UC
F2 error code flashes and machine wont finish the drain cycle
F2 is a drain error in your washer, if the unit is unable to drain then after 4 minutes it will display F2. The first thing that should be done is cleaning the drain hose and the drain pump filter, you can take out three torx screws from the bottom front panel and then clean the area completely, lift up the cap to clean the filter. If the error returns then check the drain pump if it is not working then replacing the pump is recommended repair. Please get back to me if you have any other questions.
Kevin
May 30, 2011 | Siemens WXLP1460 Front Load
Washing machine flashing oe
OE = Drain Error • Not fully drained within 10 minutes.
Check and clean the pump filter. The access panel is located on the front, bottom left of the machine. Place a towel under the front of the pump filter access panel opening before opening to catch any water that may flow out.
Check drain hose on the back of the machine for any kinks or blockage.
Dec 18, 2010 | LG WM1814CW Front Load Washer
Kenmore Oasis Washer won't drain. "Ld" code during
Hi
Error code LD means long drain. This error appears when the washer takes more than 5 minutes to pump out the water till point where pressure switch resets. To resolve the issue you'll need to clean the drain hose, inspect if the drain hose is plugged. If the hose is fine, then remove the front kick panel and access the drain pump and filter, if you are unable to find the pump and filter remove the back panel as well and trace the drain hose to the bottom of the tub. There is a drain filter connected with the drain pump. It usually gets clogged, and needs to be cleaned every 6-8 months or so. The drain filter is a small white filter connected to drain pump with a hose. If it still doesn't work then you'll need to check the connections of the drain pump, check the electrical connections with a multimeter. Hope this helps... Please post back for more information.
Daniel
Nov 26, 2010 | Kenmore 4.5 cu. ft. Oasis Canyon Top Load...
Haier washing machine E2 error
normally pump filter is the best place to start it could be jamed with a coin or hair clip if you take machine outside and empty it then lay it on its side you can access the pump take it off then stand up the machine and pour hot water into the soap draw check water should run out of bottom freely taking any fluff or bits with it now take apart the pump and clean it all out dry all components before reasembly if the machine still doesent wory could need a new pump
Sep 07, 2008 | Haier XQG50-11 Front Load Washer / Dryer
Whirlpool Duet GHW9150P Front Load Washer Logo
451 people viewed this question
Dan Webster
Dan Webster
Sal De
