Best platform to find great help on quick basis, Keep it up!!!
https://www.onsiteassistances.com/magicjack-customer-service
Very Helpful Information, I like it Very Much.. Thanks for this post
http://www.dating-advisors.com/silversingles-support-number
Check the lamp cooling fan of your projector. maybe its has some problem. its not running at the correct RPM. that's why the lamp get over heated and the temp lamp flashes.Do
one thing, Remove the fan from the projector. In the fan there will be a
specification sticker. Remove the sicker. now u can see a hole in the
center. its the bearing part of the fan. put one drop of oil in it. u
can use any type of lubricating oil. rotate the fan leafs with finger
for some time. after that re-stick the spec sticker. insert the fan in
the projector. power ON the projector and watch.
Also try to reset the lamp hour of your projector. you can see the option for reset the lamp hour in the menu. Please not one thing lamp reset is recommended only after replacing the lamp.
ok
Please dont forget to vote if you liked my answer
thanks
