Question about Philips Televison & Video
I have a 2002 Phillips Big Screen. Model#50P8341AA and Serial# 72874764. It has been losing color, sometimes you can see a color but it is a lighter color and sometimes the screen almost looks like a black and white. Any suggestions? Thanks
  • kbeck0019 Mar 08, 2009
    I have the Phillips 60PP9202, and the picture quality has slowly deteriorated. What can I do to fix this ?
  • Philips Master
  • 8,617 Answers
A common fault with phillips is the CRT coolant needs to be replaced about every 5 to 6 years. If you need more info please respond to this same post
Posted on Jul 31, 2008
Phillips big screen tv is red and gren colors and a double picture when cut on....how do you fix it
Replace the two convergence ICs and the 6.8 ohm resistors. The DPTV305 - DPTV345 convergence repair kit from www.tvrepairworld.com works for your model and contains the cd with instructions
Oct 28, 2010 | Philips 55PW9363 55" Rear Projection...
The color on my Phillips 60 rear projection big
that means that the phone needs to be unlock by the network provider
Mar 13, 2010 | Philips 60PP9202 60" Rear Projection...
Need to know what is the fuse number for the cigerette lighter on the ford taurus 2002 model. Bought car used with no manual.
check these fuses in the passenger compartment fuse box
#13 20A Power point
#18 20A* Cigar lighter
#17 20A* Cell port
20 Amp fuses are yellow in color.
Dec 09, 2009 | 2002 Ford Taurus
Magnavox big screen has dull picture and colors are not clear. Cloudy picture and has a green film of color over screen. this ia a 64inch big screen. What can
This is especially common with Phillips/Magnavox - A foggy image usually suggests that the coolant in the picture tube(s) (1or all 3) has become discolored and needs to be replaced. The only way to check this is to look directly into the crt faces (disassembly required) to see the condition of the fluid (coolant).
It's a relatively big job that shops charge between $300-400 - Get an estimate. See link for Kit
http://www.tvrepairworld.com/crt_coolant
Nov 06, 2009 | Philips Magnavox 27MS343S 27" TV
Want to know how to change the colors on my big screen without the remote, I have a Phillips big screen tv
you need to supply a model number the crystal ball is all out of guessing gas!
Aug 17, 2009 | Televison & Video
Phillips 52 in big screen screen has a red tinge other colors come though but not very bright
Replace the coolant in the CRts a very common problem with phillips. The colors will get very dim and red will become domintae as red seldom needs replacement where as blue and green get congealed and the set will get dim hard to focus and you will see a glowing around green and blue objects. Heres a link to the coolant kit for a phillips which contains the replacement coolant and step by step instructions on CD with pictures on how to replace the coolant.
http://servicemanuals.vstore.ca/product_info.php/pName/phillips-crt-coolant-replacement-kit/cName/repair-kits
May 06, 2009 | Televison & Video
PHILLIPS BIG SCREEN TV IS BUTTERFLIED
Are the colors out of alignment and unable to converge back? If so its the convergence ICs need replacing. If the convergence isnt out of alignment you have whats called a pincushion problem. If you would like a link to where you can obtain the service manual for this model let me know.
Mar 17, 2008 | Televison & Video
I need the color adjusted
1)Remove rear cover..clean RGB lens with soft cloth....
replace cover...........
2)Remove front speaker grill & access panel.....
locate RGB screen control block.....slighty adjust RGB
for best color mix.......check B/W tracking by reducing
customer color control to minimum....does pix look gray ?
touch up RGB screen again.....then increase color to middle
of range.....how is that ?......................................T.
Feb 21, 2008 | Televison & Video
Phillips Magnavox Rear Projection Tv screen too dark
The high voltage is failing. The LSB board is about $200 from partstore.com.
Dec 28, 2007 | Philips Magnavox 51MP392H Rear Projection...
Televison & Video Logo
99 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
