Question about Ricoh Aficio 1035 Copier
Ricoh 1035 Error code sc672
  • Ricoh Master
  • 2,794 Answers
It says communication error to control panel at station.
Turn the copier off, wait 30 seconds, and turn it back on again.
It should go away. If it doesn't a technician needs to come out and look at the problem.
Posted on Jul 31, 2008
My ricoh aficio MP3351 machine has a error problem SC672, plz kindly tell me what i can do???
SC672 occured when controller-to-operation panel communication error at startup After powering on the machine, the communication circuit between the controller and the operation panel is not opened, or communication with controller is interrupted after a normal startup.
.Controller stalled
.Controller board installed
incorrectly
.Controller board defective
.Operation panel connector
loose or defective
Make sure that the MBU is seated correctly. If not, SC672 occurs look at the picture to see what im talking about.
Sep 29, 2017 | Ricoh Office Equipment & Supplies
My copier machine comes up with functional error code sc672. can anyone help
That error code appears to indicate 'Op panel to controller problem' see here http://multifunctionalcopier.blogspot.co.uk/2012/06/ricoh-error-code-list.html
Sep 05, 2015 | Ricoh Richo KR-5 with 35-70mm f3.5-4.5...
Error code is sc672 on display ricoh mp2550n
change the bicu board and the problem will be solved
Good luck.
Apr 05, 2014 | Ricoh Aficio 1013F Copier
Ricoh Aficio 1035 gives ERROR CODE SC322. CANT TAKE ANY COPY OF IT, PLZ HELP
that mean laser unit have proplem synchro 1 can't detect do with me 2109 and 2108 via sp mode if it's not work out change it
Jan 14, 2011 | Ricoh Aficio 1035 Copier
My 2022 shows an error code SC320 and also a error code SC672 what could be the problem
CS320 polygon motor (laser), you will need to replace it, it is not expensive!
CS672 control communication on start up, to many options, from circuit board to bad connection, you will need a tech for this.
Nov 23, 2010 | Ricoh Aficio 2022 All-In-One Laser Printer
Problem with the Ricoh mp c2800 Ricoh error code sc 672,
If the model ia a MPC 2800 it a controller board issue maybe the operation panel. -carl
Nov 15, 2010 | Ricoh Aficio 1035 Copier
Fusing lamp of my Ricoh Aficio 1035 was broken 230V 650W red
Measurement the countinously of the heater lamp,check the thermistor and thermofuses nad reset the error code.
Sep 05, 2009 | Ricoh Aficio 1035 Copier
Ricoh aficio 1035 error code SC121
sc 121 is related to optics section of your machine.check the lamp is glowing .if so check the connection from optics to main board.
Jun 15, 2009 | Ricoh Aficio 1035 Copier
Ricoh Aficio 1035 Copier Logo
463 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
