Question about Olympus Cameras
My C-740 will not re-format the memory card. I can not reveiw any pic's on the card. Was working fine last week when I used it.
  • k5dyy Jul 31, 2008
    I have already tried to low level format from the menue,
    NO JOY !
    I have re-formated from the menue
    but it will not let me get past re-format in the low level menue.
    Your answer has not solved the problem.
    Master:
  • 382 Answers
Try the following steps to reformat your card!!,
  • Press the power button on the camera if the camera is not already on.
  • Switch the mode dial to My C-740 will not re-format - 740playbackmode.jpgand press the Quick View button 740monitor.jpg if the LCD display is not on.
  • Press the menu button .
  • Press the right arrow button to select the "Mode Menu."
  • Use the up and down arrow buttons to select the CARD tab, then press the right arrow button.
  • Press the right button again to enter the CARD SETUP menu.
  • Use the up and down arrow buttons to select YES in the FORMAT option screen and press the OK button.
  • Press the up arrow button to select YES, then press the OK button.
    • This will permanently erase all your unlocked pictures, including your locked files. You will not be able to get them back later.
    • A bar appears showing the progress of the reformatting. Do not press any buttons on the camera during this time..
HOpe this helps you..!!!
Kind Regards!!...
Posted on Jul 31, 2008
  • 6,487 Answers
Format the memory card of the camera using a card reader and format it on your computer then connect it back to the camera and see if you can format it using the camera's menu..
Hope that helps.......
    Genius:
  • 2,028 Answers
These memory cards do go out, they are basically a flash drive. If the card just flat refuses to format, then the card has a bad sector, and will need replaced. Unfortunately, you will most likely lose any pics that were on it. There are some recovery programs out there, but few if any will have the result expected. Most of the time they just recover garbled images.
  • 2 more comments
  • Ryan Rogers
    Ryan Rogers Jul 31, 2008
    There is really only one way to format this card, whether you use the camera or a computer, the format process is the same. If the card will not format, then the card is bad, gone out, crashed, what ever you want to call it, and a bad card will not work or format no matter how many times you try or how badly you want it to. Replacement is your only option.
  • Ryan Rogers
    If you have access to another card, from a freinds camera or somebody you know, see if the camera recognizes and will format their card. Be sure they back up their pics first. This will confirm that the card is dead and needs replaced.
  • Ryan Rogers
    Ryan Rogers Aug 02, 2008
    Did you try a different card?
  • Ryan Rogers
    Ryan Rogers Aug 06, 2008
    Just wondering if you found the problem?
    Master:
  • 497 Answers
Then try it with a Pc.. make sure to select FAT from the drop down list of file system types, provided your card is not larger than 2GB. Otherwise, Windows will default to FAT32, which is not compatible with a lot of cameras.Then, I'd suggest formatting it with your camera's menu choice for format before using it again.All the best!
Thanks for using Fixya
    Guru:
  • 1,894 Answers
Use a low level format in the menu options and format the memory card.
  • dewan nafees ahmed Aug 01, 2008
    ok do as i say
    when you are not able to format the card i think your card may be locked. please check that the lock tag is not in lock position.
    if this is not the problem then try to format the card in your computer and then format it in your camera.
    if even this does not solve your problem then sorry to say this is a problem in your camera firmware.
My Kodak M530 had been working alright since I bought it on December 2010 but suddenly stopped reading the SDHC card about a week ago. The card is fine because I can read the content from my Mac....
Using the internal memory locks some cameras into that mode. To get your card to work again, do this...with no card in the camera, go into the menu and find "format" and follow the on-screen instructions to erase the internal memory. Then, re-insert the card and it should work.
Jul 21, 2011 | Kodak EasyShare M530 Digital Camera
Have a SDHC 8gb Kodak card that won't format in Z1285
It's suggested that you use any SD Memory Card formatting Software to format the SD memory card. You can download any such Software from the address given below:
https://eww.pavc.panasonic.co.jp/support/jp/sd/sdfv2003.exe
Download the software from the above link and install in your computer and then format the memory card using it. After formatting the memory card, insert it in your Camera and use it normally.
Jun 23, 2010 | Kodak EASYSHARE Z1285 Digital Camera
I can't access current photos from memory card, only old photos show up stored in built in memory. Also can not access "copy" from the menu, and nothing will download to my computer. All this worked fine...
"copy" is accessed from the playback menu. If that isn't available, decide if the pics stored in the internal memory are important. If not, format the camera with no memory card inserted to erase the internal memory. If you need those pics, then download them to your computer first...then format. Next, go into the menu and find "reset"..follow the on-screen instructions. Then, purchase an inexpensive card reader and download the pics from your memory card to your computer.(and promise yourself to use the card reader from now on...and remember that after downloading, use the "safely remove hardware" icon in the bottom right of your computer screen...don't just yank out the reader!). Finally, format the card in your camera and promise yourself never to use the internal memory again.
Jan 09, 2010 | Panasonic Lumix DMC-FS3 Digital Camera
Reinsert memory stick
Are the contacts on the card clean? Is the slide switch on unlocked?
Sep 13, 2009 | Nikon Coolpix 990 Digital Camera
4g sandisk (wont format)
I have heard of cases of SD cards just giving up the ghost and not working. If it is only 3 months old I suggest you take it back to the place you bought it
May 28, 2009 | SanDisk 4GB microSD High Capacity Memory...
Memory card erased
Take no more pics until you've recovered the photos, take the card out of the camera. Here's some freeware photo recovery software that should be what you're looking for:
http://camerarepair.blogspot.com/2007/12/recovering-those-accidentally-lost.html
You will need to use a flash card reader with this software. If you don't have one, get one, they're cheap:
http://www.amazon.com/s/ref=sr_st?keywords=card+reader&rs=172282&page=1&rh=n%3A172282%2Ck%3Acard+reader&sort=price
The reason this occurred is that you likely never formatted the card. The card will work fine in the beginning but eventually will corrupt. AFTER you've recovered the photos, format the card IN YOUR CAMERA to prevent this from happening again (dig out that instruction manual to figure out how). Keep in mind formatting will also totally erase your card, so again only do this after you've recovered the photos.
May 27, 2009 | Canon Powershot A2000 IS Digital Camera
When I go to take a pic, it won't let me because it says "write protect"
Sounds like you will need to format the memory card. This will permanently erase all the data from the card and then you will be able to use it again. To format the card: Press the Menu button - right arrow to Setup- right arrow to format option. You will see format yes or no. Choose Yes and press ok. This will clear the write protect message and the card can be used again.
Apr 20, 2009 | Olympus Stylus 740 Digital Camera
Canon S1- Camera doesn't save the pictures - What to do ???
No, it,s free. It's just that your answers are from hobbyists and knowitalls who reply when they have the time to stop by here (it's like Yahoo answers, but with geeks:).
Sounds like your memory card may be faulty. Take no more pics until you've recovered the missing photos, take the card out of the camera. Here's some freeware photo recovery software that should be what you're looking for (recommend the last one listed):
And finally, recommend formatting the card in the camera after you've recovered the pictures. Look for a "Low Level" format option in the camera's menus. The format should help prevent this from happening again.
Apr 23, 2008 | Canon PowerShot S1 IS Digital Camera
Kodak z812
I'd say definitely a card problem.
It's also best to use cards with high speed data transfer in this camera.
Especially when travelling, it's best to carry a few cards, not only for storage capacity, but as back-up in case a card develops a fault. If you rely on only one card and it fails.... you may lose all your pics, so carry a few spares... same with batteries.. and ALWAYS use lithium batts in ANY Kodak camera... they have huge problems with alkalines.
Hope this helps... happy shooting and enjoy your trip.
Jan 19, 2008 | Cameras
Problem with Sony Cyber-shot DSC-W55 Digital Camera
wll friend flash your phone with cruiser with latest version and yet it dont work change the camera lens not yet heat camera ic and finally last solution is to change the camera ic. enjoy
Aug 11, 2007 | Sony Cyber-shot DSC-W50 Digital Camera
Cameras Logo
51 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
