Question about HP Officejet Pro L7580 All-In-One InkJet Printer
Not printing a fax confirmation sheet on send.
When I go to the options for fax confirmation, all it gives me is a scroll over arrow. When i scroll it gives me 3 other options for confirmations, but I can't figure out how to change the "no" to "yes" help?
  • BNA Betsy Oct 30, 2008
    My HP Color LaserJet 2840 all-in-one will not print confirmation reports after each fax and there does not appear to be a menu-based option to scroll to and select to solve the problem
When i fax there is no confirmation sheet that prints..........help!!!!
Posted on Oct 08, 2008
My HP Laserjet 3050 used to print automatically after each fax sent a call report showing that the page(s) had sent. For some reason, after a service call, now it doesn't do that any more and I have...
Hi Dear
HP LaserJet 3050, 3055, 3390, 3392 AiO Product - How to Print a FAX Confirmation Report Description By default, a Fax Confirmation report (Fax Call Report) will only print when a fax error occurs. However, this option can be changed using the printer control panel.
  1. Press the right arrow until Reports appears in the display, press the checkmark.
  2. Press the right arrow until Fax Call Report appears in the display, press the checkmark.
  3. Press the right arrow until Print Report appears in the display, press the checkmark.
  4. Right arrow to the option of choice, press the checkmark to save the change.
FAX call report options
  • Send Fax Only - a confirmation sheet will only print when a fax is sent
  • Never - no fax confirmation sheets
  • Every Error - default setting
  • Send Error - a fax confirmation prints when the fax transmission encounters an error
  • Every Fax - a fax confirmation sheet will print for incoming
Jun 01, 2011 | HP LaserJet 3050 All-In-One Printer
I need fax confirmation sheets printed when I fax from my HP Office Jet 8500. How do I get them to print?
on the printer itself --> press the setup button--> use the arrow keys on the printer and move to print report option --> press ok when you select print report--> Find out fax confirmation option and press ok --> turn it on.
If you do not find the Fax confirmation option under print report then find it under Tools option.
Press setup on printer --> press arrow key on printer and finid tools --> under that try to find the fax confirmation option.
once you switch on the fax confirmation option on the printer. every time you send a fax you will receive a fax confirmation also.
May 05, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
How do i get my fax machine to print out confirmation with 1st page faxed
go into you fax options just look for conformation send or confirmation on fax error you sould be able to find those options in the general fax setup.
Oct 12, 2009 | Office Equipment & Supplies
How do i set up the fax to print a confirmation sheet when it sends something?
Try this:
Press the Setup button (it might be the sign of a monkey range)
  1. Press the Down arrow (c00844971.gif ) to highlight Print Report , then press OK .
  2. Press the Down arrow (c00844971.gif ) to highlight Fax Confirmation , then press OK .
  3. Press the Down arrow (c00844971.gif ) to select one of the following options in the table below, then press OK
On Fax Send Prints a fax confirmation report for every fax you send. On Fax Receive Prints a fax confirmation report for every fax you receive. Send and Receive Prints a fax confirmation report for every fax you send and receive. Off Does not print a fax confirmation report when you send and receive faxes successfully. This is the default setting.
Select the one you would like to choose ;
For further help click on the following Link:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01083680&cc=us&lc=en&dlc=en&product=3204785
Regards Soumajit
Sep 21, 2009 | HP Photosmart C7280 Laser Printer
Fax confirmation sheet
Keep pressing menu button on machine until you see until you see "Reports"in screen then press right arrow and scroll through to ""send report then press enter. The report of all recent faxes sent will print from the machine.
Good Luck
Apr 06, 2009 | Samsung SCX-4725FN All-In-One Laser...
Print sent fax confirmation sheet
perform the steps below:
1. Press Setup on the front panel of the All-in-One.
2. Press 5 or scroll down or use arrows to enter in to Print Report.
3. Press 4 or scroll down or use arrows to enter in to Fax Confirmation.
Now scroll down or use arrows to find print after send fax and click on.
Jan 02, 2009 | HP OfficeJet J4580 All-In-One Laser...
Confirmation
  • Every Fax - a fax confirmation sheet will print for incoming and outgoing faxes
  • If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
    Thanks, Joe
Oct 14, 2008 | HP LaserJet 3055 All-In-One Printer
Confirmation sheet
Scroll through your menus and look for TX CONFIRMATION set it for incomplete only or never
Jul 16, 2008 | Brother MFC-8220 Fax
Fax confirmation set up
document.tlSearch.tx.value=unescape("") s.gif s.gif HP LaserJet 3050, 3055, 3390, 3392 AiO Product - How to Print a FAX Confirmation Report Description By default, a Fax Confirmation report (Fax Call Report) will only print when a fax error occurs. However, this option can be changed using the printer control panel.
Mar 31, 2008 | HP LaserJet 3050 All-In-One Printer
Fax Confirmation Sheet
Jan 22, 2008 | HP LaserJet 3050 All-In-One Printer
HP Officejet Pro L7580 All-In-One InkJet Printer Logo
815 people viewed this question
Ben Johnson
