Question about Bissell Vacuums
I accidentally sucked up a string. The brushes stopped rotating and the suction was low. I took the frame off the brushes, and the rubber belt came out. How do I re-attach the belt/fix this problem? It is a Bissell power force turbo upright.
    Novelist:
  • 97 Answers
You'll need to replace the belt.
On uprights with rubber belts, the belts need to be replaced every 3-6 months due to the fact that since the belts are rubber, they stretch, and once they stretch out they decrease the rotational speed of the brushroll, which results in a lack of agitation.
While this is not a function of the "suction," it still will make it so that your vacuum does not pick up as well. Many manufacturers are betting that you won't replace your belt often enough, so that when you try their new machine, it will pick up better than your old one.
To replace the belt on most uprights of this nature, you'll want to remove the base plate and the brushroll. Place the belt around the motor pulley, which is the metal shaft sticking out of the main motor. Then put the other end of the belt around the brushroll pulley, and pull the brushroll into place.
Replace the baseplate, ensuring that the belt is not pinched between the brushroll and the housing.
Turn the machine on to ensure that the brushroll spins, and you're finished.
-R
Posted on Jul 31, 2008
ON THE SHARK ROTATOR PROFESSIONAL, WHERE IS THE RESET SWITCH?
do you mean how to make it run again after , example my carpet had a long string and i accidentally sucked it up well, until the machine stopped ? if this is sounding familiar try to check the brush roller remove whatever you find and it should turn itself back on
if that is not the situation please let me know i will be happy to find additional info for you if possible
Dec 06, 2016 | Shark Vacuums
I fitted a new belt. Green light is on so brush is spinning. As I lower the head the brush slows to a stop as it contacts carpet.
There are much quality differences in belts but the foot pedal with arrow is made to set the hightbecarefully because of easy broken pedals . but if the brush is setting on the deepest stand then its not rotating anymore and the brush stands still. its very easy how you can disassemble the brush and can place them in 3 differend levels in height ? on the grey bearing holders outside of the brush there are 3 different indications l and ll and lll the best is to set so that the carpet if its a thin one the brush must setting just lower then the suction mouth so that the brush are more coming out so deeper come out of this suction mouth so that the suction mouth has made a little more distance from the carpet because when the brush rotate to deep insite the suction mouth .1 the tension of the belt on the brush is lower and .2 the suction mouth sucks vaccuum on the carpet and the brush doesnt rotate because of the force of suction power, play around with the different heights you find the right level.
Apr 04, 2014 | Kirby Vacuums
The brush wont rotate on my windtunnel vac but it still has suction. Could this be a broken belt?
Yep - that's usually the culprit if the brush stops turning. However, pull off the skid plate (bottom panel) and make sure you haven't picked up any string or some other obstruction that's wrapped itself around the brush & stopped it from turning. Things like hair/string don't always end up in the bag/bin sometimes if they're long enough they just wrap themselves around the brush.
Jul 13, 2011 | Hoover Vacuums
Need to replace belt and cannot figure how to take it apart to get at the belt --- Took Screws off on the bottom but could not get to the belt
You have already removed the screws so lift the brush cover off. Then grasp rotating floor brush at both ends and lift. Clean strings,hair and other debris from rotating brush, paying close attention to the brush ends. Clean the debris from motor pulley and drive belt areas.Grasp old drive belt and remove from motor pulley. Place new drive belt over motor pulley and stretch other end over rotating floor brush in the space between the bristles. Place the ends of the rotating floor brush down into slots on the sides. Turn the rotating floor brush by hand several times in the direction of motor pulley. If installed properly, drive belt will center itself on rotating brush. Reposition brush cover and screw back into place. I hope that this helps you!
May 26, 2011 | Bissell 3591 CleanView Bagless Upright...
I sucked up a shoe string. It pulled out easy, but now the brush wheel won't turn or suction.
take the brush roll sole plate off and make the brush roll is properly sat in its housing, also the belt isnt broken
Oct 03, 2009 | Dyson Vacuums
No suction
you still have a clog in there something is keeping the brushes from spinning. Be sure to remove any hair/string etc twisted around the brushes. Make sure the belt hasn't slipped off the metal pin behind the brushes, this is what creates the rotation. The brushes have a hard plastic molding on each end that fit into the sides of the vacuum. Make sure you have these on the right way or they will strip out and you have to replace the housing and the brushes. Have you cleared any blockages from the feed behind the brushes? Be sure to take the hose and extend it out and run a broom handle or something down it to be sure you do not have something lodged in there. Good luck .. if you need more detail post back. These can be rebuilt if needed, hopefully it is just something lodged further down the suction canal.
Nov 10, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Doesn't suck
you need too change the belt on the bottom where the brush is take off bottom cover and underneath is the belt if its broke replace it
Dec 22, 2007 | Kenmore 35912 / 35913 Progressive Upright...
My dirt devil vacuum won't suck up anything and its brand new!!
Take the vac bag off and turn on the vac , it should blow air out, if not unclogg the hose where the bag connects, also when you check the roller and belt, unclog the flex hose(located inside base near roller assembly) that sucks up the dirt. As long as the motor works fine the rest is just maint.
Mar 30, 2007 | Dirt Devil M085805 Upright Vacuum
Vacuums Logo
106 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
