My HP Officejet 7310 All-in-one printer was unplugged and now the fax machine dials loudly then makes a beeping noise for about five minutes then spits out a sheet that says "No Answer" no matter what number I am sending it to. Help! I can't send or receive faxes. What should I do?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,362 Answers
You need to go and redo the set-up. If you don't have the manual check here
http://www.retrevo.com/
Posted on Jul 31, 2008
A am not getting any sound when faxing or when faxes are coming through and my volume is on loud why is that.. I disconnected plugged it back in changed some settings and i still get nothing
Your HP all-in-one provides three levels for adjusting the ring and speaker volume. The ring volume is the volume of the phone rings. The speaker volume is the level of everything else, such as the dial tones, fax tones, and button press beeps. The default setting is Soft.
1 Press Setup.
2 Press 4, and then press 8.
This displays the Basic Fax Setup menu and then selects Ring and Beep Volume.
3 Press to select one of the options: Soft, Loud, or Off.
Note If you select Off, you will not hear a dial tone, fax tones, or incoming ring
tones.
4 Press OK.
Sep 15, 2010 | HP OfficeJet 7310 All-In-One InkJet...
My printer will not dial a number to fax sheet to.
Go to menu option and choose the option fax and set the parameter like auto receive or manual set the ring auto answer mode after certain ring. If it is in auto receiving mode it will receive the fax after the ring which you set. Make sure the phone wire which you insert in fax machine getting proper dial tone and getting out going calling facility.
Have a nice day and do not forget to rate please...!
Mar 17, 2010 | HP OfficeJet 7310 All-In-One InkJet...
Hp j3680 fax/printer is loud
Press on Setup--> then scroll down and select Basic Fax Setup--> then scroll down and select Ring and Beep Volume and reduce it.
Apr 08, 2009 | HP J3680 Officejet All In One Printer
Officejet 7310 HP
Follow the steps below to perform a fax diagnostics test. 1. Set up the all-in-one for faxing according to the setup instructions found in the product's User's Guide. 2. Make sure you have inserted the print cartridges and loaded paper before starting the test. 3. Press Setup, 6, and then 6. This displays the Tools menu and then select Run Fax Test. The HP all-in-one displays the status of the test on the color graphics display and prints a report. 4. Review the report. * If the test passes and you are still having problems faxing, check the fax settings listed in the report to verify the settings are correct. A blank or incorrect fax setting can cause faxing problems. * If the test fails, review the report for more information on how to fix any problems found. 5. After you pick up the fax report from the all-in-one, press OK. Then turn the printer off, and then on again. If necessary, resolve any problems found and rerun the test. If the test passes and you are still having problems faxing, check the fax settings listed in the report to verify the settings are correct. A blank or incorrect fax setting can cause faxing problems.
Aug 07, 2007 | HP OfficeJet 7310 All-In-One InkJet...
71 people viewed this question
jasbo
jasbo
