Question about Microsoft Computers & Internet
Xp installation i already had the setup done but whet it was restarting, it demands me to press F1 to resume but when I did that it will run again another set-up. What shall I do to continue installing the xp
Thank you, i think that will help to my problem. I'll post a comment if it is succesful.
Posted on Aug 04, 2008
    Novelist:
  • 202 Answers
Once if the setup completes and restarts then u remove cd while it is restarting then it should automatically loads if it asks cd u put at that particular time thats it
Posted on Aug 03, 2008
Cmos checksum erroe defaults loaded
press del to enter setup.then choose default bios setup. then save and exit.pc will restart.
Nov 17, 2011 | Gigabyte GA-945GCMX-S2 Motherboard
Hello my son can't remember his code to his laptop acer aspire 3680 can you please help.
Hello Elizabeth
Place your Windows XP CD in your cd-rom and start your computer While booting watch for, and.. "Press any key to boot from cd" the first screen will indicate that Setup is inspecting your system and loading files. "Inspecting your system and loading files". When you get to the Welcome to setup screen, press ENTER to Setup Windows. Press F8 to accept the Licensing Agreement Select the option to repair. "If one of the following Windows XP installations is damaged, Setup can try to repair it" Use the up and down arrow keys to select your XP installation, press R to begin the Repair process. Let the Repair run. Setup will now check your disks and then start copying files which can take several minutes. Shortly after the Copying Files the pc will restart itself. During the reboot, do not boot from the CD again, setup will resume automatically. when you see the Installing Devices progress bar(Lower left), press SHIFT + F10. A command console will now open up At the prompttype NUSRMGR.CPL and press Enter. You now have access to your User Accounts in the Control Panel. Pick the account you need to change and change your password. After you've made your changes close the windows, exit the command box and continue on with the repair, you will need the product key. Once that is done you should be able to log in normally with your new password.
This is taking advantage of a security flaw in windows, your other option is to reinstall windows overtop of your current installation, or to format and do a clean install.
Good luck, hope this was helpful.
Aug 15, 2011 | Acer Aspire 3680 PC Notebook
How to install windows xp sp2 by using dr-dos
1. Check your BIOS to be sure your computer will boot from a CD. Enter the BIOS setup by pressing the "Delete" or F2 or "F12" key, or as directed at the startup screen, immediately after booting. Set the first boot device to "CDROM" or "DVDROM" instead of "hard drive" if it isn't already.
2. MS-DOS command prompt
Insert the Windows XP installation CD into your CD or DVD drive and restart the computer. When prompted, choose to start from the MS-DOS command prompt with CD support. The MS-DOS command prompt will appear in a moment.
3. Start SMARTDRIVE by typing "SMARTDRV" at the DOS prompt and pressing enter. You don't have to run SMARTDRIVE, but copying the files will be much quicker if you do. The computer will display the DOS prompt again.
4. Enter "CD I386" at the DOS prompt to change to the directory where the setup program starts.
5. Enter "WINNT" at the prompt to start Windows XP setup. The installation program will copy files to your computer and then display a message requesting to reboot.
6. Press the "Enter" key to reboot. The setup program will start again and check that your hard drive format is compatible with Windows XP. If not, it will guide you through partitioning and formatting the drive and then ask you to reboot once more.
7. Press "Enter" to reboot. The computer will restart in Windows XP mode and automatically start the Windows Setup Wizard to detect your hardware and finish the installation.
Feb 21, 2011 | Computers & Internet
System configuration data read error
If the flash bios installation was stopped, you might have to do it from dos, otherwise, go ahead and press f2 and correct any obvious errors (ie floppy drive listed and not present)
Mar 19, 2009 | Computers & Internet
My laptop shuts down and attempt to restart but unable to do so.
your bios battery is low but also you need to do a clean xp installation.
Mar 09, 2009 | Computers & Internet
Press F1 to resume at start up?
When you go into you setup screen,choose the setting that you want,then tell it to save the settings. If irt is loosing the setting then likely  the cmos battery is bad and needs to be replaced.
Mar 01, 2009 | EliteGroup ECS 945GCT-M/1333 Motherboard -...
Not starting up Compaq V2000
may be
but you try this methods
remove the cpu cover and remove the cmos battery then ,remove the hdd cable and replug ,make sure all input devices like keyboard,cd rom drive conneced properly,then run the pc,F1 appears -click F1,after os load ,turn off the computer and insert the cmos battery ,again F1 is appears u press F10 and again press F10 or save buttens ,
it is a possible solution not sure,but try it
thanks
Feb 28, 2008 | Computers & Internet
HDD Error
Restart installing windows xp again... in that way it could fix the problem... But make sure that you have inserted your mouse and keyboard the right way.... check it again it's color coded... Keyboard and mouse really doesn't work if interchanged.
Goodluck... Fixya me on this... thanks.
Feb 07, 2008 | Televison & Video
Original setup was interrupted
press F8 key (just after BIOS screen) at the next cold reboot and you will see a DOS screen with 3 or more options. Read each of them and I think you will see one option is to resume setup. This option places the system at a safe entry point to continue the setup. Another option may read "cancel setup and restore previous system"...this one may be used if you cannot get the "resume setup" option after repeated tries.
Aug 03, 2007 | Compaq Evo N610C Notebook
Computers & Internet Logo
44 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
