Question about Sony KDF-E60A20 60 in. LCD HDTV
Wega gate settings not affecting tv picture
I noticed my screen was very dark and could hardly see it. I went into the wega gate settings for the tv and adjusted it to 100% brightness and it did not affect the picture at all. I went back in and played with the brightness, color, picture, etc... and no matter what I played with the settings did not affect the picture at all. From 100% on all of them to 0% on all, the picture looked the same. Please help.
  • aceman77 Jan 06, 2009
    I have the same problem and the service company says replacing the bulb will solve the problem. I have a service call scheduled for Wednesday, 1-7-09. I will let you know if it helps.
snakehead
  • 1074 Answers
SOURCE: Grey line horizontally across screen
yOU ARE HAVING A PROBLEM IN HORIZONTAL CIRCUIT OR IN YOUR POWER SUPPLY kindlyu take your T.V tO A QUALIFIED TECH to repair it.ypur problem could be a faulty capacitor ,flyback or horizontal output transistor.
Posted on Feb 25, 2007
  • 556 Answers
SOURCE: Picture goes dark
1 your problem is in video section 2 if it is ok then check power supply for any components defective.
Posted on Sep 16, 2007
ctf1800
  • 4402 Answers
SOURCE: dark picture
sony had a recall on this set see if this is one of yours
http://esupport.sony.com/perl/news-item.pl?news_id=24
Posted on Jan 02, 2008
viziks
  • 220 Answers
SOURCE: One half of screen sees darker than other
Problems described are related to Backlight.It is possible that backlights of affected area have become weak.
You may need to contact the company for repairs and Yes the Repairs may not be cheap.
Samir
Posted on Apr 08, 2008
jomabug76
  • 1148 Answers
SOURCE: Noticeable line through screen picture sony KDL-40V3000
TRY USING THE COLOR CONVERSION OPTION ,,ITLL FIX THE COLOR
Posted on May 15, 2009
Sony wega gate tv picture and sound going off and on.
Hello, it sounds like it's time to replace the lamp again, but you might check and see if the fan in back of the set is turning first. if the fan is running, replace the lamp....tks
Sep 18, 2014 | Televison & Video
RED LED FLASHES 5 TIMES PICTURE ON SCREEN DARK-CAN HARDLY SEE IT
Ur tv might need the picture bulb replace,how long this tv had it bulb been replaced?
Sep 29, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
Picture is dark
Adjust video settings:
  1. Press Wega Gate
  2. Select Settings
  3. Highlight Video
  4. Press + to select
  5. Adjust/increase the brightness.
  6. Press Wega gate to exit.
If picture is still dark, you need to replace the lamp again. Sony recommends that you replace the lamp:
  1. After approximately 8,000 hours of use.
  2. When the screen becomes dark or the color becomes unusual.
  3. When the lamp indicator on the front of the TV flashes.
Aug 22, 2009 | Sony Grand WEGA KF60XBR800 60" Rear...
Dark picture on wega lcd
Yes, if this TV has a bulb it is likely to be the bulb.
I am not familiar with this exact model, but other LCD Projection TV will show dim picture after some time. Expected life of the lamps is about 2yrs. After 2yrs the picture will become dim. After 5yrs I am suprised it is even working.
Dirt doesn't cause this problem unless your are a smoker or have the unit "literally" outside. DO NOT try to clean it or let someone tell you to do it because it will cause more problems than it fixes.
May 07, 2009 | Sony Grand WEGA KF-42SX300 42" LCD TV
Picture suddenly turned dark
hi the picture tube of ur tv has got damaged and it badly needs a replacement.. so its better to replace ur picture tube..
thank u rate me!!
Feb 08, 2009 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Sony WEGA KDF-55WF655
What you need is the owners manual my friend. In here it will show you where to get to the lamp and how to change the lamp. Go to http://esupport.sony.com/US/perl/model-documents.pl?mdl=KDF55WF655&LOC=3
to get a free copy of the OWNERS manual. Page 16 tells you how to do this. Good Luck
Jan 13, 2008 | Sony Grand WEGA KDF-55WF655 36" Rear...
Dark screen/picture.
This 30" flat screen TV set may have a problem in the high voltage circuit of the TV set. You may be able to adjust this by taking off the back of the TV set. Look for the block where the large red wire runs up to the top of the picture tube. On this block will be two controls. one will say screen and one will say focus. Try and slowly turn the control that says screen or S on it clockwise and see if you can make the picture brighter. Turn up the control till you just start to see faint lines in the picture, then back the control down till the lines go away. If the picture does not come up when you turn this up, and all you get is a blank screen, you will need to have this set repaired by a qualified repair person. Good Luck
Jul 14, 2007 | Sanyo HT30744 TV
Sony KDF-E60A20 60 in. LCD HDTV Logo
96 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
