Hi limit device possibly tripped off. look for a reset button, usually located at the back of the unit and reset it.
I am sorry, But this device is not as easily repaired just by a push of a button. Instead it is automatically reset using a piece on the circuit board. So I am thinking that this is Indeed a power failure but there is no actual repair that can be done to fix this device. I have also had this problem as well (Both the red light and the green light are on and the green light that tells you when the device is warm enough to start frying food Will not shut off and the fryer stays cold) and have opened the whole machine cleaned it out and have checked the machine for manual resets but the device was not very well made nor was it a fancy fryer with easy part replacements because the only solution I have is to find a new front panel to the fryer and replace it.
