Casio Exilim EXZ1050 Digital Camera Logo
Posted on Jul 31, 2008
Black spot in display
My daughter has the Casio EX-Z1050 and the display screen will not display anything...all that you see is a small blob of black. Any suggestions?
Michelle
Anonymous
Level 1:
  • Contributor 34 Answers
  • Posted on Sep 05, 2008
Anonymous
Contributor
Level 1:
Answers
34
Questions
0
Helped
13943
Points
37
If the camera operates normally and the only problem is no picture is visible on the lcd in record mode and playback mode,then the lcd needs to be replaced.
I need a manual for a casio ex-z1050 pink colour please
You can download the user manual for this camera from this link, just click HERE.
3helpful
2answers
Apparently takes pictures ... but black out the screen .... if you turn on and everything but can not see anything ... Sorry about my English
I see nothing on the monitor screen when I want to capture a picture. The screen monitor remaind black but I can capture new pictures. when I press the play button, I can't see the picture. When I retreive the picture from the camera to a computer, I realize the picture is black and I can't distinguish anything.
But when I introduce the good picture from my computer to the Digital Camera, from the Sceen Monitor, I can visualize only the good picture I introduce in mysefl.
The flash is working properly, the on/Off button is ok, the lens appear to be normal.
My Digital Camera is Casio EX-S880 EXILIM
Casio ex-z1050 when I turn on camera it reads "the card is locked" and can't do anything!
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
2answers
My LCD screen has cracked and doesn't display anything. Everything else works fine, so I am thinking a replacement screen is all it needs. They are available on ebay, but can anyone assist with how to...
You may be able to find a screen on ebay. Otherwise you can send the camera in to Casio, and they will put in a new one for $50.
To remove old screen, remove all screws to camera, slowly pull it apart, then you will see screen and ribbon cable that attaches screen to camera circuit board. The ribbon cable easily slides out of screen and screen can easily be pulled off
How do I get a driver for my casio exz1050?
try majorgeeks.com they have drivers , could be they have a mac driver for you.
Cracked screen
Hello Mari,
The products standard guarranty doesn't cover cracked screens. You have to replace it. Otherwise the black spot will grow and cover all the screen.
You can find a replacement screen for Casio Exilim Z80 in this link:
http://www.pantallas.biz/epages/wwwpantallasbiz.sf/en_GB/?ObjectPath=/Shops/160419/Products/%22Casio%20Z20%20Z80%22
It is not difficult to install. Just make sure that the battery is removed and the flash capacitor discharged before opening the screen.
Casio Exilim -Takes one pic then screen goes black
I think you should fiddle around with your setting check to make sure you dont have anything on u souldnt. Also u should pull out your batteries and erase the connecter inside the camera MAKE SURE U SAVE YOUR PICS FIRST.
Black spot on camera monitor
That is caused from dropping it. You could send it in and have it fixed or you could find a local repair shop to fix it for you.
Multiple Problems
The zoom and power button are all part of one small assembly/circuit on the EX-Z1050. It sounds like this piece is faulty.
Top Casio Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Bill Eager
Are you a Casio Camera Expert? Answer questions, earn points and help others
