Question about Garmin nuvi 350 GPS Receiver
Adapter for AC is broken
I ordered a Nuvi 350 last March and don't use it a lot. But I got it out this week and it wouldn't work. I noticed the end was gone off the adapter for the cigarette lighter. How do I find the correct one to order?
    Problem Solver:
  • 59 Answers
Go on google then click on shop it is te best way to buy items hope this helps.
Posted on Dec 31, 2008
  • Garmin Master
  • 2,130 Answers
Your post title says the adapter for "AC" is broken but your description mentions the cigarette adapter. The cigaretter adapter is DC. An AC adapter plugs into the wall outlet in your home.
If you are looking for a replacement car adapter, try Ebay:
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=150279323123
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=310072797582
Posted on Aug 08, 2008
I have a samsung r710 laptop which i have had for a few years. I started to have problems with the battery charge not lasting long which got worse until it wouldn't charge at all. The battery went to...
Here below are possible causes and troubleshooting steps of laptop that can't power on, hope it may help:
Possible causes:
1. AC adapter failure.
2. Power jack failure.
3. Motherboard failure.
Possible troubleshooting steps and repair solutions:
1. Test the AC adapter with a digital multimeter. It's possible that you have a failed AC adapter. If you don't have a multimeter, test your laptop with another known good AC adapter.
2.It's possible that power jack (socket where you plug the AC adapter) is broken. Remove the motherboard and take a closer look at the power jack. In some cases you can fix the jack by resoldering it on the motherboard. In other cases you have to replace the jack with a new one. Using a multimeter, test if the power goes to the motherboard through the jack.
3. If replacing the AC power adapter and jack on the motherboard doesn't help, most likely you have a bad motherboard. Replace the motherboard.
Replacement Samsung NP-R710 AC Adapter 60Watt 19V 3.15A
Replacement Samsung NP-R710 AC Adapter 90Watt 19V 4.74A
Nov 13, 2012 | Computers & Internet
Tip
Battery won?t charge and AC adaptor not recognized
I have a Dell Inspiron 6000 that just turned two years old.
After one year, my dell 6-cell battery started to falter, so Ipurchased a new 9-cell battery. This worked fine until a couple ofmonths ago when I noticed that my 65W adaptor was frayed. I bought anew 65W Dell Inspiron 6000 ac adapter andit worked well for about a week until I noticed that my battery wasn’tcharging at times. If I was patient, or unplugged the adapter andplugged it back in, the battery began charging and all was saved.
dell-inspiron-6000-laptop-battery.jpg?w=200
This lasted only a short time until my Dell Inspiron 6000 batterywouldn’t charge at all for long periods of time, and sometimes thecomputer wouldn’t turn on, even if plugged into the wall. I thought itmight still be the adaptor, so I borrowed a fully functioning 90W Delladapter from a family member to test the system. This worked better,but still not great.
When I removed the battery and started only fromAC power, the functionality was also intermittent. Usually, if thecomputer actually started, I received the start-up error “The Inspiron 6000 AC AdapterType could not be determined, etc. etc. etc.” After pressing F1, thecomputer booted, but if the battery wasn’t in, the computer didn’tusually last long before shutting off. Unsure if maybe the battery wasthe problem, I put the 6-cell Inspiron 6000 batteryback in, and it too wouldn’t charge, although (together with the 90Wadapter) my computer would at least start more consistently if pluggedin. The error remained however, and sometimes the system stopsrecognizing power and switches to my ever dwindling battery power untilthe adapter is recognized again.
The problem is with the jack on the motherboard inside our Inspiron 6000’s. This is the jack you plug your power plug into on the back of the laptop.
Somehow the jack gets worn and does not make correct contact withthe laptop so the Laptop does not see the power supply as a legit Dellbrand. So the powersupply will not charge the laptop battery and run the laptop at the same time.
DC power jack repair guide. Do-it-yourself instructions.
Modern laptops are all sold with built-in wireless laptop ac adapter.Some power notebooks used by corporate road warriors will have powerfulcellular adapters that connect the laptop to the Internet via the cellphone infrastructure
A bad connection between DC-IN power jack on the system board and the system board is a very common problem with dell pa 12,dell e1505 and Dell Inspiron 6000notebooks. If your laptop is out of warranty, then you can fix theproblem by resoldering DC-IN jack on the system board. If it’s stillunder warranty, it would be fixed at no charge to you. Problem symptoms:
  • Laptop randomly shuts down without any warning.
  • Power LED and battery charge LED start flickering when you wigglethe power cord or the AC adapter tip on the back or your laptop.
  • The battery will not get charged.
  • When you plug ac adapter for laptop, the laptop appears to be dead and there is no LED * activity at all (DC-IN jack on the system board is broken).
To fix the problem, you have to take your laptop apart, remove the system board to resoleder or replace the DC-IN jack. dell pa 12 and Dell Inspiron 6000 disassembly guides will help you to remove the system board. Take a closer look at the power jack on the system laptop board witha magnifying glass. In most cases you get the power problem because ofa bad connection between the DC jack and the system board, you’ll see acrack between the DC jack connector and the system board.
on Jan 22, 2010 | Computers & Internet
Hello, I have the garmin nuvi 750 modle and the screen has broken I need a replacement screen.What is the cost? where I can get it? Thank you.
it would cost a lot more to purchase a new screen and have it fitted than it would to replace the unit i suggest you buy a new unit .
Oct 14, 2010 | Garmin nuvi 350 GPS Receiver
I received a Garmin GPS Nuvi model as a gift for retirement that I haven't used since last year in July. When I cut it on, the screen didn't come on. My question is when I try to charge it up, is it...
you can use the house adapter to charger the GPS.
The GPS should be charged for more than 10 hours because the battery cell must have been weak and it needs a lot of charge for the battery to wake up.
Last year July is really a long time. The battery needs a lot of charge.
Take care.
May 17, 2010 | Garmin nuvi 205 GPS Receiver
Manual for 350 chain saw
Hello. Try this link to Ebay,I saw lots of them there. If the link don't work just go to Ebay.com and do a search for the manual. http://shop.ebay.com/?_from=R40&_trksid=p3984.m38.l1313&_nkw=husqvarna+350+manual&_sacat=See-All-Categoriests
Jan 12, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Is my AC Adapter for HP Deskjet F380 out of order?
You can contact PRASHANT 9820930880.
I found this on the net while searching for the adapter. Placed the order just now. Not sure how genuine he is
we have hp all in one adapters model f/310/325/335/340/350/370/378/380/385/388/390/394 @400RS. CONTACT : PRASHANT 9820930880
Jan 05, 2010 | HP DeskJet F380 All-In-One Printer
My Garmin Nuvi 360 will not work properly when the cigar adapter is plugged in. When unplugged, it works fine.
I strongly suspect that the noise-limiting capacitor on the cigar adapter is broken (burned out).
You can try to locate and replace it - or you can purchase an inexpensive power inverter - and then plug your AC charger (house power charger) in to it and off ya go... It will filter out the noise that the capacitor used to fix. Best price is either Harbor Freight (on line or store), or Tiger Direct - AKA Circuit City.
Dec 09, 2009 | Garmin nuvi 350 GPS Receiver
Garmin Nuvi 350 can't see maps after update
Did you contact Garmin tech support? They are pretty good at it.
Mar 30, 2017 | Garmin Nuvi 350 Car GPS Receiver
Nuvi 350 wont charge with car adaptor. But charges with ac charger in usb port of Nuvi. Any thoughts? I have another Nuvi 350 that does charge with this ones car adaptor.
Are you using the same port on the Nuvi to connect the car adapter and the ac charger, or two different ones? If not, then the jack could be broken (solder joint, pin?).
Aug 10, 2008 | Garmin Nuvi 350 Car GPS Receiver
AC charging problem
okay if it charges with your DC, and it gives you plomebs with the AC, i would only charge in the car because your AC charger must not be changing the current to volts and you can easily blow it up... you can buy another charger and that should solve your problem
Dec 24, 2007 | Garmin nuvi 350 GPS Receiver
Garmin nuvi 350 GPS Receiver Logo
79 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
