Question about Brother P-Touch 1180 Label Printer
Brother p-touch tape printer
It cannot cut the tape. I have cleaned the blade. Cannot sharpen. Can I get another blade? Or another blade cartridge?
Stephen.kingsley@viahealth.org
or 360 Fielding Rd; Rochester, NY 14626
Replacement blades can be purchased here:
http://www.ecomofficesupplies.com/ProductInfo~productid~TC5.html
Posted on May 22, 2009
I have taken the blade out and will (must) sharpen; until and unless I get the part made available. Seems it must be, but I cannot find it.
Posted on Aug 04, 2008
Label maker is printing blank labels when text has been typed in. Need fixed as soon as possible.
1st of all did you check and made sure the cartridge is working fine?
If not try to take the cartridge our of the printer and inspect if the tape is cut, if found to be cut replace it imdly. Take help of the user manual for replacement of the cartridge etc.,
Jul 14, 2011 | Brother P-Touch 1180 Label Printer
I have an Andis outliner II I purchased a year ago. I recently changed the blade but it won't cut my hair. Do you kow why?
Sometimes the new blades from Andis are not sharpen enough to get that clean cut. also all trimmers need to be readjusted for power and alignment, plus sharpening the blade, it look like you need a complete sharpen & service on your Andis trimmer. check out Manny's Sharpening they have a Mail Order service, the service they provide is fast and they will sharpen make all the adjustment and give your trimmer more power and the blade will cut clean. They will even adjust the blade at your request on how you want that blade to be set at. Line Ups or Fade Cuts and even shave set. Manny's Sharpening been around for over 20 years and they have a very good rating on the net. Check it out Manny's Sharpening
May 21, 2011 | Andis Outliner II Hair Trimmer
Brother mfc240c not detecting black ink cartridge. When I remove the cartridge and replace it with another it will not detect that the cartridge has been removed.
on the ink cartridge, midway between the two holes that plug into the printer, there's an opening. evidently, the printer senses ink level thru the little piece of plastic.
with printer OFF, take all ink cartridges out. cut small pieces of duct tape, small enough to cover the hole but not pass the catridge edge. use a small screwdriver or tip of a knife blade to work the edges of the tape into the slot, covering the little plastic window.
insert back into printer. worked for me. it's simpler than it sounds.
Jul 27, 2010 | Brother Multi-Function Center MFC-240C...
Printer sat unused for one year while my husband and I were both away on military duty. Returned to find that despite replacing all of the ink cartridges the black ink will not work. I performed self...
Jul 22, 2010 | Brother MFC 240C All-In-One InkJet Printer
My ps 1100 label maker prints only on black side of tape
This depends on the TAPE CARTRIDGE you have in your label printer. Apparenlty, you have a TRANSPARENT TAPE on it, and the printer prints in BLACK only.
Just replace the tape cartridge
Apr 01, 2010 | Brother P-Touch (PT1100SBVP) Label...
Too much lead on each label. Wasting tape. How do you adjust?
You can't adjust the lead since it is just the tape from the printhead to the cutter, the best way to save is to print several labels without cutting and use scissors to cut them apart after all are done. Otherwise it will advance to cut each time and leave the blank space from the head to the cutter blade.
Feb 05, 2010 | Brother P-Touch 1180 Label Printer
Doesn't cut. we sharpened, we cleaned, it's
Most likely, the blades were not adequately sharpened. To effectively sharpen these type blades, you need a special sharpening wheel designed for this task. If you have attempted to sharpen them on a sharpening stone or other device or you are not sufficiently knowledgeable in sharpening these blades, you probably have not satisfactorily sharpened them. Often, attempting to sharpen without the correct equipment makes them worse than when you started.
If you require professional sharpening, please see clipperparts.com
Feb 04, 2010 | Oster Golden A5 1-Speed Universal Motor...
Tape on Brother PT-65 wraps on roller
If the end is already messed up you may need a new cartridge, if you can remove the tape and feed the end under the guide on the cartridge and re-install it should work properly again.
Sep 15, 2009 | Brother PT-65 Personal P-Touch Electronic...
Brother P-Touch 1200 label printer doesn't feed whole label
Take out your cartridge and look at the end of the tape, it should be under the guide, the skinny bar, before going into your machine. Make sure you tuck it in under that bar and it should be OK.
Aug 28, 2009 | Brother P-Touch PT-1200 Label Printer
BROTHER P-TOUCH 1100
My Brother p-touch 1100 is feeding the white tape through but not printing black ink on it.  It has a new cartridge.  Can anyone help please?
Jun 19, 2008 | Brother P-Touch (PT1100SBVP) Label...
Brother P-Touch 1180 Label Printer Logo
215 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
