Question about Tomtom GO 300 GPS Receiver
Wont turn on
Have tomtom 300 wont power on at all
  • tufia2000 Aug 16, 2008
    My Tom Tom 300 turns on and goes off immediately, Help
  • scottm29 Apr 18, 2009
    same problem with me - i used to wrong charger to charge it and now this has happend.
" I HAVE A TOMTOM GO 300, THE GREEN LIGHT COME ON WHEN PLUGGED
UP. BUT WILL NOT TURN ON. I HAVE DONE THE RESET PROCEDURE.
Posted on Aug 12, 2008
I turn on my tom tom go 700 and the screen appears with a picture of the tom tom in a green box and then it stops and i wont turn of
If your TomTom GO/ONE/RIDER is frozen, won’t turn on or does not behave as it should, it can be fixed by resetting or restarting your TomTom device.
A reset will not delete any data from your device, with the exception of SMS messages on TomTom GO500/700.
  1. Connect your GO/ONE/RIDER to the power charger. If you have a power charger, use it to power your TomTom GO/ONE/RIDER. If you do not have a power charger, make sure that the battery in your TomTom GO/ONE is fully charged.
    Note: You need to charge your GO/ONE for at least 2 hours using the 12-24V cigarette lighter adapter.
  2. Reset your GO/ONE/RIDER. To reset the unit, you simply have to push a straightened paper clip (or something similar) into the RESET hole on the device.
    • On TomTom GO 910/710/510, the RESET hole is located on the bottom of the device.
    • On TomTom GO 700/500/300, the RESET hole is located on the bottom of the device with the word RESET right next to it.
    • On TomTom ONE, the RESET hole is located on the bottom of the device, with the word RESET right next to it (just below the SD card slot).
    • On TomTom RIDER, the RESET hole is on the bottom of the device, behind the SD card door. When opening the SD card door you will see the RESET hole on the left, right underneath the SD card slot.
  3. Your TomTom GO/ONE/RIDER is now reset. Finally, press and hold the power button for 2 seconds.
Dec 16, 2009 | Tomtom GO 700 GPS Receiver
TomTom GO 300
Sorry to tell you its likely 2 IC's have been damaged inside the TomTom , click here for more info on another reply I made >>> click me
Please rate my response if it gives you more information or helps you . thanks.
Nov 12, 2008 | Tomtom GO 300 GPS Receiver
Tomtom go 300
before you start take out sd card. 1 turn tomtom upside down. 2 see reset button? 3 use paper clip to press (press for 15secs) 4 now turn on tomtom (hold power button for approx 5secs. 5 re insert sd card. after a few minutes you should have signal. hope this solves your problem.
Mar 19, 2008 | Tomtom GO 300 GPS Receiver
Tom tom 300
If the unit is still under warranty, send it back to Tomtom. Even if the unit is no longer under warranty, complain to Tomtom. There is a problem with the CLA (cigarette lighter adapter). It can cause internal damages to your Tomtom. What happens is that there are three wires in the CLA along with a voltage stepdown circuit board. The wire are +, -, and a signal wire. If the signal wire get disconnect the voltage could spike up to 12vdc. The unit is designed for only 5vdc.
If the unit is out of warranty then try the following website for repairs. They can fix the two chips which usually blows.
http://www.satnav-shop.com/
Jan 26, 2008 | Tomtom GO 300 GPS Receiver
Tomtom wont turn on
leave on charge for two hours, then with the SD card out hold down the reset button at the back of unit for ten seconds and then the 'on' switch for ten seconds.
Jan 11, 2008 | Tomtom GO 300 GPS Receiver
Tomtom 300
Have you tried resetting the unit?
small pointy object in the hole marked 'reset.'
failing that...
http://www.tomtom.com/support/index.php?Lid=1
Sep 01, 2007 | Tomtom GO 300 GPS Receiver
Tomtom GO 300 GPS Receiver Logo
249 people viewed this question
Top Tomtom GPS Experts
Martin Murray
Will Halftowaite
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
