Question about Acer Aspire 3000 Notebook
Need to restore acer to factory settings
Have back up disks but do not know how to restore factory settings
  • 3 more comments
  • jeanreson Nov 01, 2008
    aspire3050
  • Anonymous Mar 12, 2014
    I want to disable pop ups and restore my laptop back to just factory settings.. Kinda like starting over.
  • Anonymous Mar 14, 2014
    want to go back to factory settings
    how to restore back to factory settings for Toshiba Equium L10
  • Anonymous Mar 19, 2014
    restore back to factory settings and programs
    Sergeant:
    Champion:
  • 244 Answers
Just boot from your backup disk. it will guide you to reload the Operating system (factory default).
FYI, if you haven't delete the recovery partition, you can use alt+f10 to reload. just press alt+f10 during boot.
Posted on Aug 01, 2008
Hello out there i am trrin to reset 2 factory but alt f10 is somethin else how do i fix it?
Posted on Oct 27, 2008
4 Suggested Answers
SOURCE: I bought the Acer 6920 factory restore CD's to set
This is what happened to me, but I have a 6930. The hard drive crashed and I bought a new one then I bought the recovery disks and when I went to install it I got the same error code. Acer says that my hard drive needs to be formatted, I am not sure if that is true or not, but they have me a goose chase telling me one thing then that does not work, to finally saying I need to format the hard drive, not I have to figure out how since all the formatting links they send is for different computers then mine.
Posted on Apr 07, 2010
chudd1
  • 18 Answers
SOURCE: ACER NETBOOK MESSING UP NEED TO RESTORE IT BACK TO ORGINAL FACTORY MODE
reboot and hit the alt and f10 buttons at same time and follow the prompts
Posted on May 03, 2009
  • 52 Answers
SOURCE: acer aspire 6920 back to factory settings
Acer sent me these instructions.
The other way before Vista starts up is to tap ALT + F10 (at the same time repeatedly) when the computer is first switched on.. The window of opportunity is very small, so this may take a few attempts
Once you have tapped both the ALT and F10 repeatedly, you may see a screen showing:
“Edit Boot options for Microsoft Windows Vista”
If you see this, unfortunately, you have missed the window of opportunity, and you need to restart, and try again.
If you see this:
“Edit Boot options for Windows Setup” OR “Edit Boot options for Acer eRecovery”
Then it indicates that you have tapped the ALT + F10 correctly, and all you now need to do is press “Enter” and the Recovery program should load on your screen after a short pause..
In some cases, you may need to remove the battery (for notebooks only) and run the machine directly from the mains.
The Disk2Disk recovery feature allows you to recover the system without recovery CDs.
This will return your system to factory settings and will delete everything stored on the machine.
If possible we strongly advise backing up anything important on your machine before starting the recovery process.
Posted on Jul 12, 2009
How do i set a recovery programe to go back to factory settings
Your going to need the factory disks to do this. The factory disks have drivers and all the original software that came with your laptop computer when purchased. Some companies are turning to the web to provide factory disk downloads at a certain web site to save money or shipping of factory disks for their computers. In any case you will have to have the factory disc to restore to factory settings and software on your laptop.
Once you obtain that then it is simple from there. Place the disk in the tray and boot it will begin the process of installing your machine all over again. If you have files and things you wish to save do it before you load the disk for its factory restore. "You will loose any unsaved information"
That is mainly the right process to do this. "Obtain a Factory Restore Disk" John
Apr 17, 2012 | Apevia Lithium Ion Battery Pack 4400 mAh...
I need to restore my acer to factory settings
You can restore the computer back to factory default,to do so, follow the below steps: Turn OFF the computer, now as soon as you hit the power button, keep on holding "Alt" key & keep on tapping "F10" key, i.e Alt+f10, it will open the recovery console, select full factory restore and follow onscreen instruction. NOTE: This will erase all the datas on the computer.
You can also create a set to Recovery disk from the recovery partition, to do so
Start Menu> All Programs> Acer erecovery management> Click Create Factory Default Disk, if you receive any error code or unable to burn the disk, please contact Acer Technical support at 1 800 816 2237 and order for an Recovery Disk.
Thanks and regards,
Jitha
Nov 17, 2011 | Acer Aspire Computers & Internet
Reset Acer Aspire X3200 To Factory Setting
Assuming the restore partition is intact, boot the machine and press and hold F10 and ALT at the same time. If the partition is intact, you should be brought to a restore menu and given the option to restore to factory settings. If this doesn't work, you may have corrupted the restore partition and will need disks to install an operating system. If you created Rescue Disks in Vista, simply load the 1st disk and reboot.
Nov 14, 2011 | Acer Aspire X3200 PC Desktop
Hi, i have an acer aspire one with windows xp home edition 2002, i need to reset it back to factory settings, but i have now disk to put it on there. how do i restore it to factory settings without a disk
have an acer aspire one with windows xp home edition 2002, i need to reset it back to factory settings, but i have now disk to put it on there. how do i restore it to factory settings without a disk ?
Use system restore and add/remove program to use system restore go to start ---> all programs
---> accessories ---> sytem tools ---> system restore .. restore your computer in earlier time...
to go to add and remove program click start ---> control panel and find add/remove program
remove the program you did not have when its new...
hope it helps god bless
Jun 28, 2011 | Acer Aspire One Netbook 8.9" Notebook
I want to take my acer aspire back to the factory setting but dont have a cd how do i do it
Acer are cheap and they don't provide you with a factory restore disk. You need to make this factory disk yourself. I know how to do this, but it is to much for me to type and here is a really really good reference site for you to visit to get instruction to make your own factory restore disk. After making that restore disc,  pop the disk into your laptop and turn of your laptop and restart and the factory restore program should start, if it should not start then go into your bios menu and have it boot from your Dvd-Rom and save, after full restoration, make sure you turn your boot priority back to where your Os is being installed, exm hard drive.
http://www.ehow.com/how_4478845_restore-acer-computer-factory-settings.html
Jan 14, 2011 | Acer Computers & Internet
Restore to factory settings
all HP made computers (acer is owned by HP) dont come with backup disks anymore, they require you to make them when you first get the computer, so if you made your restore disksyou should be able to pop them in and boot off of them and it should restore to factory settings, if you didnt make the disks the closest thing you could do is reinstall windows completely.
Sep 16, 2009 | Acer TravelMate 2441WXCi (LXTCZ05081) PC...
Need Acer Aspire 5720G Recovery disk (CD)
visit the web site has> (http://www.acer.com)> to get what you need to recovery
Jul 22, 2009 | Acer Aspire 5720 Notebook
I want to restore my Acer Aspire M1100 desktop computer back to factory settings. I have the disks from Acer, one is a System Disk and one is a Recovery Disk. Is there any way to restore/reinstall Vista...
If you used the restore disk on your computer it will erase all files, and all your programs. the restore Factory settings means "ALL" settings the time you created the CD for the restore.
If you have an individual Vista Installer CD with the Serial you can use it and use restore option.
Thank you for using Fixya
Hope this helps.
May 06, 2009 | Acer Computers & Internet
contact acer you can get there number from the website and they will let you purchase a restore disc for 15bucks
Aug 20, 2008 | Acer Aspire™ T180 PC Desktop
Restoring acer aspire to its factory settings
From Acer customer support:
1 Ensure all Data is backed up, all data will be deleted.
2 Restart machine
3 When your unit switches back on hold down alt & tap f10 repeatedly...(on Acer icon)
4 Please wait a moment until prompted, -How would you like to restore?-
5 Please select –Restore system to factory default-
6 Enter your defined password or enter six zeros ‘000000’
7 Click ok
8 Please wait until process completed, this will take 45min – 1hour
Oct 03, 2007 | Acer Aspire 5100 Notebook
Acer Aspire 3000 Notebook Logo
2,625 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
