Question about Canon PIXMA MP210 Photo All-In-One Printer
Remove protective material on right side - can't remove it
Step 3 of directions for installation states "remove the protective material on the right side" The only thing I can find on the right are two white ribbons curved out with rows of tiny print (KFC AWM.......). I pulled on this and one end of the ribbon tore lose. I've either just ruined this new printer or the protective material is really stuck in there. Help.
Sandy
  • GA1974 Aug 01, 2008
    This shouldn't be rocket science. Aaach and thanks for confirming what I'm thinking.
    Guru:
  • 1,049 Answers
In all likely hood you just ruined the printer. Take it back to the store and tell them you bought it that way. ;)
Generally all protective objects for removal are colored neon, obviously labeled as such, or are simply tape. The protective material they indicated is most likely either a piece of tape across the print head or a plastic plug, which may or may not have even been there depending on if the printer was a return, it fell loose, etc. before you got it home or took it out of the box.
Posted on Aug 01, 2008
Removing starter nissan pick up 4 cylinder engine
Okay , i will give you step by step, the book calls for .9 for time.
1) First remove the front right tire.
2) Remove neg battery terminal.
3) Remove starter wiring.
4) Remove the right front splash shield.
5) Remove the exhaust manifold heat shield.
6) Remove the exhaust manifold.
7) Remove the oil filter.
8) Remove the oil sender connector.
9) Remove the starter bolts and remove starter from cylinder head side.
Hope this helps, let me know how it goes, good day.
Dec 24, 2012 | 1991 Nissan Pickup
Tip
How to remove password from PDF?
Sometimes we may come across some PDF materials which were download from the internet or sent by others. They are easy to read by free Adobe Reader yet some of them were password protected from opening, copying and printing. It is really tough if you urgently need to copy or print some PDF files. So is there any method to remove PDF password? The answer is yes. But first we need to know some definition about PDF password.
Generally speaking, there are two types of password provided by Acrobat PDF standard security. They are "user password" and "owner password". "User password" is also called open password, it is the password defined by the people who create the PDF file which is used for protecting the PDF files from opening by others. Only people who enter the password can open the protected PDF files. "Owner password" is the password that set to protect the PDF files from changing by others. With an "owner password", the owner can protect the PDF files from printing, editing or selecting text and graphics.
So it turns to know how to remove password from PDF. Here is a small and easy-to-use PDF password remover which can help us do this work. Of course first you need to download this PDF password remover and install it on your PC. Then we can get start.
Step 1 Launch PDF Password Remover Double click the start icon to launch PDF password Remover.
Step2 Import PDF files
Click Add and browse the local PDF files need to be decrypted. It allows you to import 200 files at one time. After the files are imported, the file information will be shown in the panel.
Here you need to note that this PDF Password Remover can remove "owner password" directly. While for the PDF files with "owner password", you cannot remove the password unless you know the password. The "owner password" protected PDF files is shown in the pane with a lock beside. If you need to remove the "owner password", just click on the lock beside the file in the pane and key in the correct password in the pop-out small window box and click OK to confirm the password.
Step 3 Decrypt PDF filesClick the Start button, and soon you can get the decrypted PDF files.
Also there is a quicker way to remove PDF password with this PDF Password Remover, just right-click the protected PDF file and choose Decrypt with AnyBizSoft PDF Password Remover in the shortcut menu, you can remove the password from protected PDF file without launching the program!
Sincerely hope this tip can do you much favor to learn how to remove password from PDF.
on Jun 30, 2010 | Computers & Internet
Tip
How to Enjoy DRM Protected Music
To enjoy DRM Protected Music, you should remove DRM protection from the music files first. This article contains three parts:
Part 1: What's DRM
Part 2: Why need to remove DRM
Part 3: How to remove DRM from protected music
Part 1: What's DRM
DRM, Digital Rights Management, refers to a range of access control technologies that limit usage of digital media or devices.
Part 2: Why Need to Remove DRM
DRM protection has been used by some big companies to protect their intellectual property rights, such as Sony, Apple Inc., Microsoft and so on. Music bought from different companies will have different DRM protection that can restrict you from playing songs on incompatible players. So you just can't copy your DRM protected music or share DRM protected music with your friends. There comes the headache of removing DRM protection before you enjoy DRM Protected Music!
Part 3: How to Remove DRM from Protected Music
Following is the step by step guide to help you remove DRM protection then you can enjoy DRM protected music freely!
Step 1: Add files
Free download Aimersoft Music Converter and run it. Then click "Add" to load your DRM protected music files.
Step 2: Output settings
Click the "Setting" button to set the music output format as you like:
Step 3: Start to remove DRM from protected music
Click the “Start” button to start to remove DRM from protected music files, that's all.
OK! You have finished to remove DRM from protected music files and now you can enjoy DRM protected music freely!
Note: With this music converter, you can also convert M4P to MP3, M4P to WMA, WMA to MP3, AAC to MP3, etc.
more information: music converter media converter
Connected information : dvd to ipod touch dvd to iphone video
on Jun 03, 2010 | Computers & Internet
Error code 5C00 what is this and how do you repair this erroe
This error is shown when there is any kind of foreign material or packing material stuck inside the printer which restricting the printhead to move freely. To resolve this issue, please follow the instructions mentioned below:
1) Confirm that the printer is powered off.
2) Disconnect the power cord from the printer or at the wall outlet or both.
3) Open the paper output tray and then lift up the scanning unit cover until it locks into position.
CAUTION: The orange protective tape may prevent you from opening the paper output tray. If that is the case, please refer to the illustration in step 3 to ensure the white foam piece is removed along with the protective tape. skumar_sreen.gif
4) Pull the orange protective tape (A) and remove the white foam (protective material) (B). skumar_sreen.jpg
5) If the the white foam was not removed along with the orange protective tape, check for it on the right, inside the printer. a) With the printer powered off and unplugged, slide the print head carriage to the left. b) Looking inside the printer from the left, locate the white foam in front of the purge area. Note: It is recommended to use a thin latex glove as there may be ink mist on the white foam or surrounding print area. skumar_sreen_0.jpg
c) Cautiously remove the white foam with your hands. Be careful not to touch any other components in the printer.
6) After removing the packing material, look for and remove any other paper debris or foreign objects from the extreme left and right sides of the carriage area.
7) Close the scanning unit cover.
8) Reconnect the power cord and then power on the printer.
Aug 30, 2011 | Canon MP560 All-In-One InkJet Printer
Our new Canon PIXMA MX870 is showin a 6A80 error before step 3 of the setup. The printer cartridge holder won't move into the loading position (to the right), and we cannot clear the error (tried pressing...
Remove the Protective Material Before turning on the machine, remove all the orange tapes and protective sheets. If the machine is already on, press the ON button to turn off the machine before removing the packing / shipping materials.
Let me know if this corrects the problem. Thanks.
May 03, 2011 | Canon PIXMA MX870 Wireless Office...
Genx usb flash 128 Mg is write protect how i can remove write protect
1.Look for a switch or button on the side of the micro SD card or adapter. It might have a lock/unlock symbol on it. 2.Move the switch to the "Unlocked" position to remove write protection. This position may also be labeled "R/W" for read/write. If you have no switch, continue to Step 3. 3.Download and install Sony EzRecover (see Resources for link) and attempt to use it to format the card (this will erase all content). If this doesn't work, try Step 4. 4.Delete and repartition the micro SD card using Windows XP. Select "Control Panel" > "Administrative Tools" > "Disk Management." Select the micro SD drive and click "Delete." Right-click on empty drive and select "New Partition."
Dec 27, 2010 | PNY 4GB USB 2.0 Flash Drive - Grey/Black
How can I change the rotors and brakes on a 2006 Cadillac?
Front brake
Step 1: Identify Front Disc Brake Components
Front Wheel Drive Brake Assembly
Most front disc brake components include: brake rotor, brake pads, brake caliper, caliper mount and brake flex hose. Brake service usual occurs between 20,000 and 40,000 miles depending on driver habits, road conditions and brake pad/ rotor materials used.
Step 2: Remove Brake Caliper to Replace Pads
Removing Brake Caliper Mounting Bolts
Locate primary caliper mounting bolts; apply wrench pressure counter-clockwise (When looking at the head of the bolt) to remove the bolts, upper and lower. Make sure the bolt threads are in good shape and replace if necessary.
Step 3: Remove Front Brake Caliper
After removing the primary caliper mounting bolts lift the brake caliper off of the rotor and then tie or secure to the side, being careful not to bend or kink the brake caliper flex hose. Thoroughly inspect brake caliper and brake hoses for leakage, cracks or chaffing and replace as needed. Next remove the brake pads (If not mounted in the caliper) and secondary caliper mounting bolts. Notice how great protective gloves work, most technicians use them on the job today.
Step 4: Remove Brake Pads
Remove Front Brake Pads
Once the brake pads have been removed, make sure if there is anti rattle hardware to transfer to the new brake pads. Some brake pad manufacturers will include the proper lube (Caliper slides) and anti-rattle hardware to ensure proper performance of their product.
Step 5: Remove Caliper Mount
Remove Caliper Mount Bracket
Finish removing secondary caliper mount bolts and remove caliper mount. Note: clean and lube caliper slides and pad friction surfaces of all foreign material or build-up.
Step 6: Remove Brake Rotor
Remove Brake Rotor
With the caliper mount out of the way you can now remove the brake rotor. Sometimes it can get stuck so you may need to tap it with a hammer or use penetrating oil to free it up. Some manufacturers use small screws to hold the rotor on as well. Clean and inspect wheel studs, replace if any are damaged. Also clean bearing hub rotor mount surface to ensure the proper mounting of the new brake rotor. Inspect the ABS sensor wheel for cracks or damage and replace as needed.
Step 7: Depressing the Brake Caliper
Resetting Brake Caliper
To install the new brake pads you must retract the brake caliper piston. Remove the master cylinder lid or open the brake caliper bleeder screw to allow excess brake fluid to be released if necessary. Install C clamp tool and gently tighten clamp until caliper piston is fully depressed. Note: use old brake pad to protect the caliper piston. Close the bleeders once the piston is retracted completely
Step 8: Installing New Brake Rotor
Install Brake Rotor
Install new brake rotor, the new rotor is manufactured with a protective film over the rotor to keep it from rusting, remove protective film with brake cleaner before installing; also after the brake job is complete you may experience a small amount of smoke from the rotor when first used. This is normal and will go away after the first couple of uses.
Step 9: Installing New Front Brake Pads
Installing New Brake Pads
Reinstall the front brake caliper mount, and then install front brake pads. Make sure the pads are seated properly in the caliper mount; it must be a close fit to work properly..
Step 10: Reinstall Front Brake Caliper
Re-Install front Bake Caliper
Reinstall front brake caliper and reinstall caliper-mounting bolts, recheck all mounts and mounting bolts. Check the caliper slides to be sure there is no bind and that the caliper moves freely back and forth on the caliper slides. Bleed brake system per manufacturer's specifications to relieve any air trapped in the system. Before driving the vehicle, push the brake pedal down and let it up slowly, repeat until normal brake pedal operation resumes, this operation is forcing the brake pads to travel to the brake rotors.
Dec 18, 2010 | 2006 Cadillac STS
Change water pump
1 disconect neg.battery cable 2 drain the cooling system 3 remove air intake tube from filter housing to throttle body 4 remove top half of fan shroud 5 remove the serpentine belt 6 use a strap wrench to prevent the waterpump pulley from turning while turning the fan clutch in the counterclockwise direction. 7 remove fan and set aside 8 remove belt tensioner 9 remove hoses from water pump 10 remove 6 bolts, 3 on either side and remove the water pump. 11 remove the thermostat housing from the old pump and install on the new one. 12 re assemble in reverse order. make sure the mating surface of the engine block where the pump bolts on is clean and free of old gasket material before installing new pump and gaskets. When assembled fill cooling system, start engine and let idle untill thermostat opens and engine reaches operating temp.KEEP WATER LEVEL FULL. After a test drive recheck the coolant level, and you are done.
Mar 14, 2010 | 2000 Chevrolet Silverado 1500
I have a lenmarx x5150 printer and have no manual with instructions.How do I use it and replace ink?
  • Press the "Power" button to turn on your Lexmark
  • Step 2 Open the top portion of the printer to reveal the ink cartridges.
  • Step 3 Lift the gray plastic cover on the left. Remove the empty black ink cartridge. Next, lift the purple plastic cover on the right and remove the empty color ink cartridge.
  • Step 4 Remove the new black ink refill cartridge from its packaging. Tear the protective strip of paper from the cartridge's sensor. Now, remove the new color ink refill cartridge from its packaging and tear the protective strip of paper from the cartridge's sensor.
  • Step 5 Turn the cartridges so that you can read the label. This is the way the cartridges should face when being put into the printer.
  • Step 6 Slide the black cartridge into the slot on the left side and push it down. Slide the color cartridge into the slot on the right side and push down.
  • Step 7 Push the gray plastic cover down over the cartridge until it clicks closed. Push the purple plastic cover down over the cartridge until it clicks closed.
  • Step 8 Close the top portion of the printer. Your new ink cartridges are installed, and your printer is ready to use.
Nov 19, 2009 | Office Equipment & Supplies
Canon PIXMA MP210 Photo All-In-One Printer Logo
61 people viewed this question
old marine
old marine
