Question about Toshiba DKT-2010 Corded Phone
LCD display On all the phones in our office it displays our phone extension, the date and time. Well one co-worker changed it, now it just says 11 on the display. He was trying to call out but didn't dial "9" to get an outside line. This is what he did to change it, picked up the phone and dialed 1877 is there a way to reverse what he did in one step or am I going to have to input all the info again
  • Michael Bowen May 11, 2010
    Does the 11 display on all the phones orjust the one he was using at the time ?
    Does the 11 display on all the phones or just the one he was using at the time. There are a couple of commands to use depending on your clarification of the problem. Please repost and I will try to help.
  • 31 Answers
If you go to the phone where the problem press intercom#621 then press the # key then press 1 to erace everything on the screen the press speaker or hangup.
Posted on Oct 11, 2008
How do I display my own name on the new Mitel 5320e IP Phone that my office just installed?
You must log into the controller to program it. If it is a MiVoice Office, Mitel 5000 there is a way to change your display name but it does not change the description in the system. If you do not have the programming software contact your qualified dealer.
Partner Finder
Oct 24, 2014 | Mitel 5320e IP Phone 50006474
Tip
Avaya Partner Phone System Programming
Programming Without Button Overlays: <br />Although it is advisable to have a Partner programming manual and overlays when performing changes. Here are the basic steps for changing system time, day and date. The "Feature" key is self explanatory while other keys need a reference. "System Program" key is the left intercom key on the phone. The "Central Tel" key is the right intercom key. The "Next Data" key is the third key from the left with an LED on the top row of an 18 Button display set. Numbers # and * are simply entered as numbers of the dial pad.<br /><br />Avaya Partner System Date Program #101<br /> <br />Use this program to set the month, day and year. The system displays only the month and day on display telephones when the telephone is idle: the month, day and year also print out on SMDR call reports when used.<br /><br />Considerations: <br />The System Date date-stamps the back up files when you use Backup Programming.<br /><br />Programming Without Button Overlays:<br />The "Feature" key is self explanatory while other keys need a reference. "System Program" key is the left intercom key on the phone. The "Central Tel" key is the right intercom key. Numbers are simply entered as numbers of the dial pad.<br /><br />Programming: To change system date: Press Feature, 00, System Program, System Program,#,101 at extension 10 or 11. Enter today's date in the form of "mmddyy" (Month, day, and year), including leading zeros for single digit months or days. For example, to enter April 26 2003, press 042603. A display similar to the following appears: System Date Data 042603. Exit programming mode by pressing Feature, 00 or lifting and hanging up the handset.<br /><br />Avaya Partner System Day Program #102<br />Use this program to set the day of the week that appears on system display telephones.<br />Programming: To change system day: Press Feature, 00, System Program, System Program,#,102 at extension 10 or 11. Change the day by pressing "Next Data" until the day you want appears:<br />1=Sunday<br />2=Monday<br />3=Tuesday<br />4=Wednesday<br />5=Thursday<br />6=Friday<br />Exit programming mode by pressing Feature, 00 or lifting and hanging up the handset.<br /><br />Avaya Partner System Time Program #103<br /> <br />Considerations: <br />Enter the time in 24 hour notation. In this scheme, the hours of the day are 0000 (12 midnight) to 2459 (11:59). Since each time must have four digits, use leading zeros when necessary. The time appears on system phones as A.M. or P.M., not 24 hour notation.<br /><br />Programming: <br />To change system time: Press Feature, 00, System Program, System Program, #,103 at extension 10 or 11. Enter a new time in 24 hour notation. For example, to set time to 2:15 P.M., press 1415. This time will appear on the phone as 2:15 P. Select next procedure or exit programming mode by pressing Feature, 00 or lifting and hanging up the handset.
on May 27, 2011 | Lands Phones
Phone line doesn't ring
First, lets get rid of the static. Try Feature #86. This will turn off background music. When a music source is not attached you get static.
Enter programming by using Feature XXX66344 password 266344. The display should show "Terminals&Sets" press the top right button with an indicator in the display. The display should show "Show set: ____ enter the extension number that you want to check or program. The display will show ***:name. Press the top right button three times. The display will show Show Line:____ with options to Scan or List. If you select Scan it will show the lines assigned to that phone. If you select List it will start with the first line in your phone system showing one of four states 1- Unassigned, 2- Ring Only, 3- Appear&Ring, 4- Appear only. Change the selection on the line by using the CHNG soft button. This is where line assignments are changed from the four states for each extension.
The only other thing that will keep an extension from ringing is "Do Not Disturb" or DND. Feature 85 and #85 will turn this feature on and Off.
Jan 31, 2014 | NorStar Meridian M7310 Phone
How do I change the display in the LCD? I would like it to have the date and time displayed instead of my name and extension.
On an idle phone, press either * or TRANSFER to step the display to show 3 different pieces of info.
Carl
Sep 09, 2011 | Panasonic KX-T7730 Corded Phone
I need the directions to set the time and date on Partner 18D phones and how to set up extentions
Changing the time on a Partner system is done on either ext 10 or 11. At one of those ext's press the feature key and "00"
next press the left hand intercom twice
the display should say system programming
enter in "#103"
the display should say system time and the current programmed time
enter the new time in 24 hour format
To change the date enter #101
the display will say system date and the current programmed date
enter in the new date in MMDDYY format
press feature "00" to logout
As far as setting up the extensions, I'm going to need a little more specific info to help.
Aug 26, 2010 | Lucent PARTNER18 Corded Phone
Panasonic KX-T773 reads "102:" instead of date/time
Your extension reads 102 because that is the extension #.
Press either the tranfer key or the " * " star key and your display will change to time and date or just the date.
Oct 28, 2009 | Panasonic KX-T7731 Corded Phone
Panasonic KX-T7730 Corded - change display
On mine I press the asterix to toggle display options
Mar 31, 2008 | Panasonic KX-T7730 Corded Phone
Panasonic KX-T7456 Corded Phone - Date & Time Display
The display on the phone ... to change back and forth between the date and time, and the extension information, press the "star" (or asterisk) key while the phone is on-hook, this will toggle the display back and forth.
Hope this helps, David B.
Mar 10, 2008 | Panasonic KX-T7456 Corded Phone
Set Time DTH-16D-1 (BK) TEL
Here's how you adjust the time:
1. Press <TRANSFER>
2. Press <CONF>
3. Press *
4. Press <TRANSFER>
5. Press <CONF>
6. Press #
7. "CAT MODE" displayed on LCD
8. Press <REDIAL or LNR/SPD>
9. "COMMAND" displayed on LCD
10. Press 02
11. Press <RECALL>
12. Press 2
13. Press <RECALL>
14. "02>2>Current Time" displayed on LCD
15. Input correct time using military time (HH MM SS)
16. Press <CONF>
Dec 28, 2007 | NEC Electra Elite DTU 16D-2 Corded Phone
Fixing message isssue
You can also press #409 on the phone to clear the message waiting indicator.
Mar 29, 2007 | Toshiba DKT3010SD Corded Phone
Toshiba DKT-2010 Corded Phone Logo
109 people viewed this question
Top Toshiba Lands Phones Experts
Oloyede Monsuru
Are you a Toshiba Lands Phone Expert? Answer questions, earn points and help others
