Question about Panasonic Televison & Video
Can you tell me if a panasonic pt-47wx42f has a service ajustment or code for fine tune convergence, thats not available from the main menu
  • Panasonic Master
  • 8,617 Answers
Yes, but if you cant correct it with the regular convergence menu, you will need to replace both Convergence ICs they are STK392-110 you can get replacements at the following link with free instalation instructions with pictures. If you adjust the convergence through the service menu you will have a real bad problem ever getting it right again. the ICs are cheap and very easy to install. Heres the link.
http://servicemanuals.vstore.ca/
Posted on Jul 31, 2008
RED ARCH ON LEFT BOTTOM CORNER
This is a very common failure on Projection TV sets.
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
You can see some example photos and find a solution here...
http://www.fixya.com/support/r2861627-updated_convergence_problems_amp
Jul 16, 2009 | Panasonic PT-47WX53 47" Rear Projection...
Center Target Blue Convergence and Contrast Adjustment
Yes there is a Service Code you have to have to get into Alinement menu and its a Dog following step by step to get in! (1) Turn set on cable (2) Turn sleep timer on 30 min (3) Press Action Twice exit menu 4) now tune to ch 124 (5) adjust vol half way down (6) Now Press vol- on front of TV ,now you should see a RED chk appear in upper corner (7) Now Power on remote hand unit and you shiuld be in menu Press cursor to move Mute locks where you want to aline ADJUST with vol-,Vol+ ch- ch+ for up&down back and forth.If you need anymore help let me know .
Press R-tune to change R-G-B
Dec 25, 2008 | Panasonic PT-53WX42 53" Rear Projection...
Panansonic rear projection TV Convergence needed
Go to this web site and Print out information on How To Enter Service Menu http://www.freelist.org/archives/techassist/09-2005/msg01111.html Read this very carefully when trying to get into service menu its no easy walk in the park, i hope i never have to set convergence on another myself. (1) Switch to cable (2) Set sleep timer 30min ,exit menu , now enter channel 124, Press vol- on tv ,at zero volume a Red Ck should appear , Re enter menu turn sleep timer off ,Now Press power untill you see oVoo using ch+ Adjust to OV1 ,now Press vol+ You should now be in convergences---- Mute locks- cursor to move- vol-&vol+/ch- ch+ to ajust lines---- Press R-Tune to switch color to adjust When done Press (7) to save then Press Then Press and hold power and action for 5 sec . GOOD LUCK.
Dec 15, 2008 | Panasonic PT-51HX41 51" Rear Projection...
Convergence for Panasonic 47"
Yes it is that set uses the same IC STK392-110 You can get the new ICs at this link and they will provide free installation instructions with pictures as well as free on line tech support instant messaging while you do the repair. heres the link.
Apr 14, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Panasonic- 47wx42f
the convergence ic's are at fault need replacing,call a service shop and ask for estimate to repair .should be under $ 300.
Dec 09, 2007 | Panasonic PT-47WX42 47" Rear Projection...
Panasonic 47wx42f projection
Joe,
It sounds like your may need to replaced your convergence ic's loc# ic7001 and ic7002 stk392-110. That should take care of your alignment problem.
Dec 03, 2007 | Panasonic PT-53WX42 53" Rear Projection...
Panasonic- 47wx42f
Changing the convergence amp IC's is usually the first step..
Then let us know.............T.
Dec 02, 2007 | Panasonic PT-47WX53 47" Rear Projection...
No voltage to convergence chips
There are usually 2 micro fuses that resemble 1/4 watt resisters around the power supply, and are usually all green,tan or yellow, and in most cases will have a + or - voltage marked right near these fuses 20 to 25 volts dc typical.
Jun 25, 2007 | Panasonic PT-47WX49 47" Rear Projection...
Televison & Video Logo
109 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
