Question about Sony VIAO P4 PCV-RS712 3.0GHz 512MB 200GB DVD RW DVD BRAND PC Desktop
Sony PC My computer shuts of by itself after it as been running for 15 min then when i try to restart it says that my computer was interupted and gives me a choice to start normally or in save mode and all it does is keep cycling to the same start procegor
    Genius:
  • 1,011 Answers
Is it fixed 15 mins or its a round figures. does i happen without any fix time. the options are normal like save mode, normally etc...
have u checked ur processor's fan. is it normal or resists to run. it can happened b'coz of it also. also check ur ram too.
regards,
Posted on Jul 31, 2008
94 olds cutless supream 3.1 starts runs then stops running after 15 mins
Have you had the computer checked for trouble codes,that would be the first step.If you have then start testing separate componets,coil, ignition module,etc.
Jul 02, 2012 | 1994 Oldsmobile Cutlass Supreme
I have a dell inspiron 530 with the quad core an everytime i start it up it goes into windows for about 10-15 mins an the monitor screen just goes blank an the keyboard lights go off an when i push the...
it sounds like your motherboard is shutting itself off to protect itself from overheating or some other system failure. you should verify all your fans are running at the correct speed. if it seems like everything is running fine, you can probably turn that off in bios. obviously if there is something wrong with the fans, then you need to replace them. Another options is maybe the processor is getting too hot which is why it's shutting down. open the case and remove the heat sync from the board so you can see the processor. clean the thermal paste off the processor and apply a new generous layer. put the heat sync back on and then try and restart. make sure before you do ANY of this you unplug the computer! good luck and let me know if it works!
Jan 27, 2012 | Dell Inspiron 530 Desktop Computer
15 to 20 mins screen will go blank and will have A black screen reboot and it will work 10 or 15 mins. RELOADED XP AND THIS DID NOT HELP, SAME PROBLEM
Your Dell OptiPlex GX260 PC Desktop computer is overheating. It is shutting itself down to prevent component failure.
Ensure that the Processor heat sink is clean of dust so sufficient air can flow through the heatsink and cool the processor.
Install additional fans in your computer 120mm are best but 80mm fans will do fine.
Clean the computer chassis of dust as well.
Thanking you
damnor01
Feb 02, 2011 | Dell OptiPlex GX260 PC Desktop
94 chrysler con.3.3 eng.runs for about 15 min. shuts down,engine
suggest change crank sensor-rear of engine pas side
Oct 05, 2009 | 1994 Chrysler LHS
Computer keeps restarting itself after about 10 - 15 mins.
Start the PC, Click Start > Right Click on My Computer > select Properties > Advanced tab > Settings (in the Start up and recovery section) > Unckeck the box next to "Automatically restart" under "System failure". > click "OK" > click "OK" again. Restart your PC and give it a go.
Apr 20, 2009 | Acer-Veriton-M410-US3800P AMD Desktop PC -...
Dell inspiron 9300 getting hang or restart after every 15 min
Sounds like your hardrive is starting to fail-backup all files!!!
Apr 12, 2009 | Dell Inspiron 9300 PC Notebook
Tv powers off after 15 mins to 2 hours
what is the model # and brand
May 02, 2008 | Televison & Video
My laptop turns on itself, i don't know what's causing it. my windows(service pack 2) is fine and running smoothly....
Go to control panel. Power options and there u can see hibernate. enable hibernate and click apply. and come out and go for shut down and there u can see stand by shutdown and restart. then press shift button on keyboard the standby turn on to hibernate. then click hibernate it will shut down the entire system within 10 to 15 Sec try this. and Mail me on this mail ID
Abhilash_Aditya25@yahoo.co.in
Dec 19, 2007 | Compaq Presario X1000 Notebook
Computers & Internet Logo
44 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
