Question about Sharp AL 800 Copier
Partial print when used as a copier, it prints only 3/4 of the page. The manual only gives support if this happens as a printer. It happens to me when using it as a copier at 100% setting.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Sharp Master
  • 1,362 Answers
Are you sure you have the paper aligned correctly?
should be left top or center.
Do you have the correct sive paper (Letter instead of A4)?
What happens to the rest of the copy : cut off, blank, black?
Is the scanner light staying on when scanning the whole page or does it die out when it scans 3/4 of it? ( bad scan cable or board)
Posted on Jul 31, 2008
Why does it print only partial words?
Are you sure the cartridge is good? And is the paper that you use wrinkle free? Try printing out a test page and see what happens.
Aug 26, 2015 | Canon PIXMA MX892 multifunction printer
HP2040 prints 2 pages, then all blank pages. What gives ?
What you have omitted to say is how many more pages are expected.
Did you click on the printer icon or go into file,print (control,p)? If you clicked on the printer icon then you may get one blank sheet after the specified number of pages. if you use File print then you will get what you want.
So lets surpose you are printing 5 sheets and you get two printed and 3 blanks.
Use another program on your pc and see what happens with that. If all is ok then that rules out the printer and the program is probably corrupt in some strange way.
If however the same thing happens in another program then its possible the driver is corrupt and i suggest to download the latest version and use the brother printer driver removal tool to remove the old driver first.
I wonder if you are using Vista. Vista is well known to give printer problems.
lastly if all these fail to resolve the problem try the printer on another pc and if it still does the same then the laser is failing and would need replacing. (Not cost effective though).
Aug 23, 2011 | Brother HL-2040 Laser Printer
I use my MF6530 Laser Copier Printer to print checks and it will frequently print on the reverse side of the paper.
hai I give print to printer 2 side in single page, first two page print well but another two page print in opposite direction in the same paper (example1,2 page one side and 3 ,4 pages in other side but reverse direction. it mean you turn the paper to next side, you see opposite direction ) please help me to avoid this problem.
Jul 22, 2011 | Canon imageCLASS MF6530 Monochrome Laser...
Only printing partially
first of all it require servicing like cleaning of steel rod inside in the printer on which print heads move ,that you can do with lubricant oil and second thing you need to change the cartridges they may be dry if you can do this entire thing well otherwise I advised you to show it service center.
Dec 22, 2009 | HP PhotoSmart 7760 InkJet Printer
I try to print a card or bank statements and nothing is printing just put in new ink, it only prints the 1st page of a quarter fold card, it should all be on one page and it prints only partial card
IF the Kodak AiO printer is printing partial ther are two main device of the printer that have issue on the scanner [where you put the document for copying] or the printhead of the printer.
Step that you can do
1. Try to print a test page in this way you can check if the printer prints whole page. How to print test page press copy button and photo button on the printer for atleast 10 sec. or until the printer starts printing. Reminder Test page doesn't need a document on the scanner glass. It will print an advertising doc for the printer. Now if the test page is half/partial it is the printhead that has an issue. If it print the whole page it is the scanner that has issue contact kodak for printer repair
2.Clean the printhead twice and reseat the printhead it
How: press menu button then select clean printhead then select basic/deep clean. To reseat printhead open the printer access door; remove the ink cartridges; remove the printhead; close the printer access door then open the printer access door insert the printhead then the ink cartridges.
3. Try to print again [For futher support call Kodak support line at 1 800 421 6699]
Nov 21, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Partial printing
it may happen that toner is low or it may also happen that OPC drum is faulty.
Oct 08, 2009 | HP LaserJet 2840 All-In-One Printer
Printer problem
The HP DeskJet printer will not print, it prints only partial pages, or produces ... remove the scanner, remove the printer driver, and reinstall the printer driver with all programs and ... the paper out of the printer after printing is finished. If one, or ... the kicker feet on your printer are broken, have the printer serviced. ... In tray only when the printer is not printing. Adding paper while printing can cause paper jams. Do ...
Jan 17, 2009 | Office Equipment & Supplies
Printer prints partial page and then stops
We have had the same problem. I have found that if I close all windows not being used on the computer, then try to print the document again the entire document prints. This happens on an older computer we have that doesn't have alot of RAM.
Dec 04, 2008 | HP OfficeJet V40 All-In-One InkJet Printer
RX620 inconsistently only prints part of the page
The epson printer RX 620 only prints partially for my photo while I want the whole picture. How do I get it to print the whole thing instead of it printing it partially?
Apr 13, 2008 | Epson RX620 All-In-One InkJet Photo...
Sharp AL 800 Copier Logo
76 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
