Question about Kenmore Elite 45986 Front Load Washer
Kenmore Elite H3 Error Code F71
I loaded my washer and as I pressed the Start buttom an error message appeared (F71). The washer door cannot lock, start or doing anything. What does the error message mean?
  • CRL3 Aug 01, 2008
    I unplugged my Kenmore Elite H3 and plugged it back in. The error message F71 is not longer flashing. It looked like it was fixed but the door is not locking. What should I do now? Everything else looks fine but the door not locked.
  • CRL3 Aug 01, 2008
    i unplugged to reset and it worked!
  • 876 Answers
The computer needs to be reset most likely. You might try turning it off, uplugging the washer, leaving it off for a bit and starting over. They are touchy little machines, I've found, not just your brand either. Mine comes on everytime the power blinks on and off in a storm :0) Best of all have a look in your manual and if you don't have it go to the manufacturer's site and download a new one or look for support there. Good Luck to you.
Posted on Jul 31, 2008
  • Gayle Ashbach
    Gayle Ashbach Aug 01, 2008
    This same problem happened to mine when it was new and I had a warranty service call. All he did is reset the computer so I was hoping it would work for you. You might be able to get online support at Kenmore.com. It wouldn't hurt to try resetting again. Will the door close when the washer is off? If it will, I would close it hit cancel adn unplug again and leave unplugged for say thirty minutes. Then I would try bringing it on again. I wish I could help more, but if this doesn't work, do look for online support and check to see if your washer is still under warranty. You will need the MODEL # of your washer for either one. Good luck!
My washer is showing a f32 ,f71 codes what does that mean
Sd Error Suds Detected (Stored Error Code F71) Did you use regular detergent?
Regular or hand-washing detergents are not recommended for this washer. Use only High Efficiency ("HE") detergent.
Did you add too much detergent?
Always measure detergent. Follow detergent manufacturer's directions. If excessive suds are detected, the washer will display this code while running a suds reduction correction routine at the end of the wash cycle. The suds reduction routine removes extra suds and assures proper rinsing of your garments. If the code remains and the wash cycle dial is ?ashing after the recovery routine has stopped, re-select your desired cycle using cold water. Press START. Do not add detergent.
Ld Error Washer is taking too long to drain water from the washtub
(Stored Error Code F32) Check the following:
Is the drain hose or pump clogged?
Is the drain hose higher than 96" to reach the drainpipe?
Is the Drain Pump Running?
Is the pressure transducer hose kinked, disconnected, or punctured?
Press PAUSE/CANCEL to clear display.
Mar 02, 2015 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore Elite washer service code CLL SrU
Re: Kenmore Elite 417; error CLL SRV We have well water and I think my error message and locked door were because the machine was trying to plump water and not getting any. I heard the error beeping and sent to check it out. There was another noise that didn't stop even after unplugging the washer, although the beeping did, which finally stopped after I turned off the water valves. Press and Hold the power button down to unlock the door and retry. If you still have trouble, call for service.
Sep 25, 2012 | Washing Machines
Kenmore Elite HE 3t steam washing machine shows a code of F71
The F71 error code means "User interface heartbeat failure" to put that in simple terms what it means is,the touchpad/cycle selector is not talking to the main control board. To check to see why that code is being displayed ya would need to make sure that all the wire plugs between the selector and the control board are tight and in fully pressed in and making good contact at the respective connection point on the circuit board.
If ya find the wire connections to be good and tight,ya would need to start the washer and if the drum rotates the cycle selector would have to be replaced. If the drum does not rotate the main control board would need to be replaced. oldtech2332_146.jpg
Oct 20, 2011 | Kenmore Elite 45986 Front Load Washer
I notice F22 error message on washer. Door seems to be jammed and will not unlock
This is a door lock failure code and it means the door lock is broken or just failed to unlock. Click on the links below for the detailed instructions for manually unlocking the door and replacing the door lock and switch assembly if it has indeed failed.
Manual Door Unlocking of Whirlpool Duet and Kenmore Elite front-Load Washing Machines
Replacing the Door Lock and Switch Assembly on Whirlpool Duet and Kenmore Elite front-Load Washing Machines
Mar 12, 2011 | Kenmore HE2 Plus Front Load Washer
I have Kenmore HE5T Error code F71 Pls advise handling. Thanks.
F71 points at a connection error between button pad and control board.
Please read the indications in this article: F70 and F71 are two logic board error codes...
Regards.
Nov 07, 2010 | Kenmore Elite HE5t Washer
I have gotten F70 and F71 messages and the door will not open. What do I do about this?
Hi.
Please read the tip below, explaining how to fix F70 and F71 problems. The comment applies to Whirlpool built kenmore washers like the one in question.
F70 and F71 are two logic board error codes that point at a communication error between the main log...
Regards.
Ginko.
Jun 23, 2010 | Kenmore Elite 45986 Front Load Washer
My H3 washer has error code F02.
unplug for 40 minutes to reset the ECU.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 28, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore elite h3
I have an H3 washing machine and the rubber bellow lip that seals the front door from leaking has torn causing water to leak out. Can this bellow be repaired or easily removed and replaced without calling a service repairman.
Nov 25, 2007 | Kenmore Elite 45986 Front Load Washer
Kenmore elite HE3t
I am getting an F35 code on the washer has anyone had this problem
Sep 21, 2007 | Kenmore Elite 45986 Front Load Washer
Kenmore elite he3 - door lock
If sound like a lid switch issue. Open the top of the washer to get an access to the lid switch(located near the doorframe). Look for a loose wire or a broken switch. In case there is no loose wire or broken switch, you should replace the switch. Good luck!
Sep 05, 2007 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
732 people viewed this question
Sal De
fordexpert
Robert Rankin
