Loads of noise from the drum on my hotpoint machine like something is grating inside. Washes ok
    Sergeant:
  • 225 Answers
Hi, This isn't much of a fix, more of a diagnosis, but it does sound like the drum bearings have failed. If you open the door and grasp the inner drum, you might be able to lift the drum up and down more than before.
You may be able to obtain new bearings from a local supplier or Ebay, but this will only be of use if you have the tools and experience to fit them. As a "repairman" job, it is likely to be quite expensive.
One other possibility is that the springs and shock absorbers that locate the drum in the casing have come off or failed, but in that case the whole outer drum would likely have slumped forwards or sideways.
I'm a bit reluctant to advise on matters like this as the poster sometimes wants to shoot the messenger!
D
Posted on Jul 31, 2008
Hotpoint Wt540 1400 wont spin
check the machine washes ok if it does not turn the drum on wash check the motor brushes if drum action is ok on wash check the drain pump for blockages
Mar 06, 2014 | Hotpoint Aquarius WD63 Front Load...
(washing machine )when spinning a large banging noise like the drum coming out
Spin the drum by hand from inside, if it feels rough or is rumbling or grating, then the main bearings have failed, a major repair involved.
Nov 28, 2010 | Hotpoint Washing Machines
My Hotpoint WF645 washes ok but is very noisy, especially during the final spin. Any suggestions why this might be?
sounds like it could be a bearing going out, or simply might be something stuck around the drum
Aug 13, 2010 | Hotpoint WF645 Front Load Washer
Drum has stopped moving
Hello, these is usually the drive belt,the drive belt is the easiest parts to replace.
Thanks
Jun 10, 2010 | Hotpoint WMM39 Front Load Washer
Hello i have a hotpoint wma40 the machine will go
Hi, i have a wma40s had it for 7 ears now same thing happended would start a cycle but then stop halfway through make the noise but the drum would not spin etc. i bought some carbon brushes of ebay for 7 quid and it works better than its worked in years bit nosiey for first few washes but after it settles it is as good as new.
Jul 06, 2009 | Hotpoint WMA40 Front Load Washer
Washes but does not spin
I AM NOT A MECHANIC, BUT IT SOUNDS LIKE YOUR MOTOR COUPLING NEEDS TO BE REPLACED.
May 13, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint WD 865- washes ok, dryer won't work makes loud popping
sounds like the dryer heater element has worked loose perhaps and shorted out against the metal dryer box which sits on top of the drum.
best to get an engineer out i'd say.
Jan 14, 2009 | Hotpoint Aquarius WD63 Front Load...
Hotpoint Ultima WMA61 loud knocking noise in spin cycle
Hello I think that the drum bearings have gone on the machine..
To open the door and spin the empty drum quickly by hand and you should hear the noise or say a less amplifed one.. Also another way to check is to move the inner durm up and down to see if there is any play in it..
If you need any further advice then dont hesistate to ask....
Jan 14, 2008 | Hotpoint Aquarius WMA52 Front Load Washer
Hotpoint WMA42 - Noise!!
appliance sounds like it has bearing failure.common on this machine.advise looking for a new machine.sorry
Dec 30, 2007 | Hotpoint Aquarius WMA42 Front Load Washer
Washing Machines Logo
127 people viewed this question
Top Washing Machines Experts
