Question about Sub-Zero Refrigerators
Subzero 632 error code 37 - Sub-Zero Refrigerators
  • 1 more comment
  • alisoncl Jul 31, 2008
    Tried what is probably a soft reset via the on/off switch on the panel. Is overnight really necessary?
  • Anonymous Mar 13, 2014
    Where do I buy handles for subzero 632 with wood panel?
  • Anonymous Mar 16, 2014
    How do I move a subzero 632 away from wall. It is ion levelers not wheels.
  • 2,071 Answers
WHAT IS WRONG WITH YOUR REFRIGERATOR?
subzero 632 error code 37 - small_4_1.jpg For a detailed Refrigerator illustration, click below.
redarrow.gif Side by Side
redarrow.gif Fresubzero 632 error code 37 - redarrow.gif/a>
Freezer on Bottom
redarrow.gif Under counter
Warning!To avoid personal injury or even death, always disconnect yourappliance from its power source--that is, unplug it or break theconnection at the circuit breaker or fuse box--before you do anytroubleshooting or repair work on your appliance. Also, because somecomponents may have sharp edges, use caution while working on yourappliance.
It's stopped completely
It's not cool
Cooling is poor
It's noisy
It leaks
The freezer compartment is icing up
The food in the refrigerator freezes
There's water dripping inside the refrigerator
The refrigerator never cycles off
The ice maker has a problem
There's an ice- or water-dispensing problem
Posted on Jul 31, 2008
    Genius:
  • 1,011 Answers
Check this site. hope it will be cured.
http://www.subzero.com/BuiltInRefrigeration/632Refrigerator
regards,
    Master:
  • 505 Answers
Could you tell me what brand it is
    Guru:
  • 1,894 Answers
Have you tried to do a hard reset by plugging off the unit from wall power for one night
please try it.
  • dewan nafees ahmed Jul 31, 2008
    also can you describe the problem that is happening due to this?
    keeping it plugged off for one night will clear the errors in many cases.
    so please try that first
2 Suggested Answers
  • 71 Answers
SOURCE: subzero 632 cycles from 37 to 50 degrees
few things to check... condenser coil clean. dirty condenser fluctuate temp. clean condenser. evap fan motor work? open the fridge. press the switch. heard the fan? feel the frame around the fridge an freezer is hot? or cold? cold ok. hot dirty condenser coils OR condenser fan motor. or seal system problem. call a tech>.. good luck... LEAVE YOU COMMENT IF IT WAS GOOD FOR YOU... thanks
Posted on Apr 02, 2010
When was the subzero 632 made?
Are you asking when was the first one made, they were in production for several years you can use the serial number to tell the date of manufacture
Sep 05, 2014 | APW Wyott SubZero Refrigerator Freezer...
How do you reset the subzero unit after cleaning coils
Hold the alarm pad for 15 seconds. Then when it comes back call an authorized servicer.
Jul 02, 2014 | Sub-Zero 632 / S
Defrost Overheat Fault EC23?
this subzero had the same error code. when i tested defrost components find out that defrost thermostat is bad, so i replaced it, and it does work just fine now.
May 28, 2014 | Sub-Zero 632 / S
My 632 is flashing EC 40. What is the problem?
Here's a list of all error codes for the 600-series Sub-Zeros.
http://fixitnow.com/wp/2006/06/29/error-codes-for-the-sub-zero-600-series-refrigerators/
EC40 = Excessive Freezer Compressor Run
Mar 24, 2011 | Sub-Zero 632 / S
My door on my subzero refrigerator squeaks really bad. How do I fix? Model 632
Spray a bit a WD-40 on the hinges and then wipe off the excess...give it a couple of days to work into the hinge...
heatman101
Sep 11, 2010 | Sub-Zero 632 / S
My Sub-Zero is flashing error code 36. What is this?
Diarmait --
Technical Service Manual for the SubZero 600 series can be downloaded at:
[https://docstore.fedex.com/subzero]
Username=subzero
Password=subzero
Write back if you still need help.
-- SWT
Aug 23, 2010 | Sub-Zero 650 / O Bottom Freezer...
Ice in the bin on subzero 632 freezer is in clumps
if the ice maker leaking it's easy to replace, or may be just a water supply tube has been moved to the side
Oct 03, 2009 | Sub-Zero 632 / S
We have been getting service code 50 for our SubZero -- it;s a 690 model fridge/freezer. I cleaned everything however over last three weeks the error repeats. I reset the board by pulling power from the...
Error code 50 means excessive refrierator section compressor run. Possible causes include: dirty condenser, stopped condenser motor, faulty termistor or an evaporator refrigerant leak. If it is a refrigerant leak it usually shows up as frost or water driplets half way down on the back wall. Clear codes by holding the alarm button in for 15 seconds.
Aug 26, 2009 | Sub-Zero 632 / S
Subzero 632/s won't cool also frost build up in fridge
you have a leak in the evapator you will have to call a subzero tech to get it changed..
May 03, 2009 | Sub-Zero 632 / S
Subzero 632 cycles from 37 to 50 degrees
Mar 07, 2009 | Sub-Zero 632 / S
Refrigerators Logo
183 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
Sal De
John Tripp
John Tripp
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
