Question about Emerson EWF2704 TV
EWF 2703 tube has a spot on the right side in the form of a round head after being dropped, is it worth fixing?
  • 40 Answers
Depends how much money cost the tube (try to buy a second hand one).
Posted on Aug 01, 2008
Water pump tubing leak on 2002 chevy diesel how do i fix it
replace the seal and clean mating surfaces apply form a gasket silicone
Sep 30, 2014 | Cars & Trucks
Where is the fuel pump located and is it hard to replace
in the gas tank if it is cold out side you have no charge take it in have in completed.
Dec 25, 2010 | 1995 Chevrolet Cavalier
Bowel cleaning
Check the ports under the rim and make sure they are not clogged. To do this you can use a nail or pin to clean them out.
Right under the rim of the bowl are these ports that allow the water to flow into bowl in a turning motion to aid in flushing and cleaning wall's of the bowl.
Inside the tank check the fill tube and make sure it is connected from the fill valve to the over flow tube. Also check the fill level in the tank and make sure water is up to the line on the fill tube about 5/8" from top of tube.
Jun 06, 2010 | Jacuzzi Bath Perfecta EZ33 959 White round...
How to change an exhaust manifold leak 7.5L
Right-Hand
Removal
  1. Remove spark plug heat shield (12A406).
  1. Remove distributor to spark plug wires (12286) using Spark Plug Wire Remover T74P-6666-A.
    1. Disconnect muffler inlet pipe.
    1. If equipped with secondary air injection, disconnect the secondary air injection check valve tube (9B480).
    1. Remove attaching bolts and right exhaust manifold (9430).
    1. Inspect joint faces for signs fo exhaust leaks, cracks or any defect that would make exhaust manifold unfit for use
Left-Hand Removal
1. Remove oil level indicator tube (6754).
  1. Remove spark plug heat shield.
  1. Remove distributor to spark plug wires using Spark Plug Wire Remover T74P-6666-A.
  1. Disconnect EGR valve to exhaust manifold tube (9D477). If equipped with air injection, disconnect the secondary air injection check valve tube.
  1. Remove attaching bolts and exhaust manifold (9431).
  1. Inspect joint faces for signs of exhaust leaks, cracks or any defect that would make the exhaust manifold unfit for use.
Installation
  1. Clean mating surfaces of right exhaust manifold or left exhaust manifold and cylinder head (6049). Clean mounting flange of right exhaust manifold or left exhaust manifold and inlet pipe(s). Clean mounting surface for air injection tube or right exhaust manifold. Apply light film of Premium Long-Life Grease XG-1-C or -K or equivalent meeting Ford specification ESA-M1C75-B to right exhaust manifold or left exhaust manifold.
  1. Position right exhaust manifold or left exhaust manifold on cylinder head. Install attaching bolts and washers, starting at fourth bolt hole from front of each right exhaust manifold or left exhaust manifold. Tighten bolts to 34-47 Nm (25-35 lb-ft), working from center right to both ends.
    1. Position inlet pipes to right exhaust manifold or left exhaust manifold. Install attaching nuts and tighten to 34-47 Nm (25-35 lb-ft).
    1. Position the secondary air injection check valve tube and the secondary air injection tube gasket (9C435) at rear of right-hand exhaust manifold. Install attaching bolts and tighten to 19-25 Nm (14-18 lb-ft).
    1. Attach the secondary air injection manifold tube (9B449) to left-hand exhaust manifold fitting (located under EGR tube). Tighten nut to 30-40 Nm (22-30 lb-ft).
    1. Attach the secondary air injection check valve tube to rear of right-hand cylinder head. Tighten bolts to 75-85 Nm (56-62 lb-ft).
      1. Connect EGR valve to exhaust manifold tube to left exhaust manifold, if removed. Tighten nut to 53-72 Nm (39-53 lb-ft).
      1. Install spark plug heat shield and distributor to spark plug wires.
      1. Install oil level indicator tube to left exhaust manifold, if removed. Tighten nut to 13-24 Nm (10-18 lb-ft).
      2. Start engine (6007) and check for exhaust leaks.
Hope this helps you...WF †
Mar 10, 2010 | 1996 Ford F250 Crew Cab
Valves tapping and bike is running rough
No there is a cover that slides up on the pushrod tube. Cut a tube in half lengthwise, and you'll have the shape. It's held in place by spring action. (Lift up)
After you remove it, mark the pushrod threads where the adjustment lock nut is. You'll have a ballpark place to refer back to then.
Loosen the adjustment lock nut, turn the adjustment until the pushrod is small enough to tilt to one side, and remove.
Mark each pushrod for where it/they came from. (That is, place them in a holder of some sort, and identify where each one came from, on the holder. I use a square piece of wood with holes drilled in it. Front head- Intake. Front head- Exhaust. Rear head- Intake, and so on)
You'll have new lifter/s, but each rocker arm will be worn to THAT particular pushrod. This is why it's best to keep them in order.
Next is removing the four small bolts that hold the lifter block in place. (Square block that two lifters will be in) There is a gasket under the block, so it may not just lift right up. You may have to use gentle persuasion.
(GENTLE! That wasn't a joke. Don't mar the aluminum case that the lifter block goes into! You'll have an instant oil leak from now on)
Be sure to put some prelube made for this, on the lifters round body, and on the roller on the lifter. A tiny little dab in the center of the lifter where the pushrod sits, doesn't hurt either.
1.New gasket for the lifter block.
2.New pushrod tube seals
Don't replace these, and you'll have spots all over your driveway. (Replace even if the pushrod tube seals look good)
Sep 02, 2009 | 2003 Harley Davidson XL 1200 C Sportster...
Screen gets hot and turns black on the bottom right
There are many causes of this. On cause can be the Cold cathode fluorescent
tube itself. This is a grossly misnamed device as the cathodes get very hot
indeed. One of the tube failure modes as they wear out is that the cathodes
can get much hotter than normal, and this affects the screen near it.
Jun 24, 2009 | Dell Inspiron 6000 Notebook
GE Monogram refrigerator/freezer problem/ice dam in ice maker
I have had the same problem with ice forming. I found the problem is from the ice maker. The water fill tube delivers water to a plastic piece that acts like a funnel. The water goes through this plastic piece into the ice maker. Ice forms in the plastic funnel piece causing the water to overflow into the ice bin and freezer.
Mar 26, 2009 | Refrigerators
Emerson EF 2703 - Infrared Beam is not functioning
John,
I am having this same issue with an Emerson EWF 2702. Did you find any resolution to this. Do you know of a way to change the video input on the tv when you cant use the remote?
Thanks,
Jack
Jun 26, 2008 | Emerson EWC27T3 27 in. TV/VCR/DVD Combo
No Ice From Kitchen Aid
Mark, your water valve has screwed the pooch. Replace it. The part number is 2199838.
What's happening is this... the valve that fills your ice maker is by-passing a small amount of water. This water has to flow through that tube, right? When very small amounts (drop by drop) go through the IM fill tube, they flash freeze. Eventually they (the frozen drops of water) form a big block of ice inside the fill tube. This ice creates a blockage which creates back-pressure whenever the IM "calls" for water. The back pressure eventually blows the tube off of the connection behind the fridge.
You say that this happened over night... no way. If you look closely at the ice cubes that you IM has been making, you'll see that they are hollow. Hollow cubes means that your IM isn't getting enough water... (because the fill tube is blocked).
Tracy
Mar 15, 2008 | KitchenAid Superba Architect KSCS25INSS...
Black spot on picture
My Nikon was having the same problem with the stationary black spot. I used a can of Dust Off ( the original compressed gas duster). I just removed the lens and held the camera upside down (lens facing the floor) and blew my compressed air inside and my black spot disappeared. Just a thought you might like to know !! Good luck.
Aug 08, 2006 | Casio EXILIM ZOOM EX-Z600 Digital Camera
Emerson EWF2704 TV Logo
37 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
