Question about Samsung SYNC SGH-A707 Cellular Phone
Front LCD display
Can it be stay on all the time?
No it shts off about 5 seconds.
cant change.
Posted on Aug 08, 2008
Samsung st600 front lcd stays white
The best thing would be to have it checked by a camera shop so they can advise you on exactly what the problem is and the cost to fix it.
Dec 28, 2012 | Samsung ST600 Digital Camera
Sony kdl-46xbr4 turn on and shuts off try 10 times
If the problem is with the LCD display unit, Sony is now extending the warranty on the LCD display and will fix the problem for free through September 30, 2012. See: http://esupport.sony.com/US/perl/news-item.pl?news_id=378&mdl=KDL46XBR4 Call their customer service number and they will give you a case number. Then call one of their authorized service centers and they will fix it free, in home.
Dec 30, 2009 | Sony KDL-46XBR4 46 in. LCD Television
I have exactly same problem
Sound like your display is having issues with the inverter board. When the power supply detects a short circuit, it turn off by itself. When you try several times, you may be able to "bypass" the circuit protection but the damaged parts still having problems. This issue may be related with the DELL display issues.
The display needs to be fixed by someone with experience in electronics repair.
Sep 29, 2009 | Microsoft ChiMei CMV938D 19" Widescreen...
Front display stays dark after boot sequence
you must forget to re install the magnetic piece which located in the lower left corner of the lcd frame cover try to check it
Jun 18, 2009 | Nokia E90 Cell Phone (Unlocked) - Black
Dark display
You most likely have a defective CCFL backlight, it may have the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display.
  • Picture flickering on and off.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Apr 11, 2009 | Computers & Internet
Reset the time function
To set the clock time
1 Press the KB/CAL key, to switch the LCD display into calculator mode,
then type the new time, in 24-hour format display.
2 Press Prog+Send key once will set the new time to clock display.
Examples for time format:
231105 = 11:11:05pm display 23-11
102359 + 10:23:59am display 10-23
Sep 05, 2008 | Focus Electronic Focus FK 8200 Keyboard
No playback on DCR-TRV103
In playback mode the lCD displays the battery time, hi8 symbol and the tape counter. all the functions work the tape will play, rewind, fast forward. The screen stays blank on playback and the tape counter stays at 0:00:00 eventhough I can see the tape turning. I also hooke the camera to my tv and I got no picture.
Dec 23, 2007 | Sony Handycam DCR-TRV103 Digital Camcorder
Longer time display.
unfortunately, the time display cannot stay on for loger time and constantly. it only works for a few seconds..
Dec 06, 2007 | Sony Ericsson Z610i Cellular Phone
Wont stay on
IF there is no display even with a flashlight, the P/S board is malfunctioning. Bad capacitors or LCD driver board circuit. Mine did this and it was bad caps, 4 of 8 were bad and a burned out chip on the P/S board.
Oct 20, 2007 | Proview PL913S 19" Flat Panel LCD Monitor
Samsung SYNC SGH-A707 Cellular Phone Logo
29 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
