Philips 32pw9527/05 tv does not start
Hi, I have philips 32pw9527/05 widescreen crt tv. The screen just flashes a coloured blob in centre of screen and makes a clicking sound then turns itself off, power light flashes red.
  • Andy Wh Sep 09, 2008
    I have the same model with the same problem. It is currently in for repair but the technician does not know what is wrong. He has ordered a diagnostic cable from phillips and is awaiting this to make more progress. If he finds out what the problem is then I will post his diagnosis.
    New Friend:
  • 76 Answers
Generally these type of problem occurs due to atmosphere contains moisture content. Even if it happens in warm area i suspect fbt leakage. Since this is high voltage transformer it can be serviced by qualified technicians only. Red light flashes indicates the tv in protection mode to avoid severe damage due to some short circuit. I think it is helpful to you
Posted on Aug 15, 2008
My IBM c170 crt show differents colours(yellow,pink,red....) on display plz help me
omg, a CATHODE RAY TUBE not Crushed yet.
raise the flag, get a medal of honor.
my guess, ?
( I did crt from 1965 to first flat screens) even RADAR !
you are lucky its still glows at all. no , really !
no photo , no guess. sorry, the examples of bad presentations
on any screen, made is near infinite. only photos work.
some CRT had a color bar test mode.
so turn off the test switch.
you never said what it was plugged into? Windows 3.12?
if its a mushy blob of colors? a blob like of stated 3 colors
wel, that is the newer TV stars, riddled with ugly nasty tattoo's.
find a new Youtube channel.... LOL
Oct 02, 2013 | IBM ThinkVision C170 17 inch CRT Monitor
Philips 60PW9363 60-Inch Widescreen HDTV-Ready Projection TV discolored. possible crt fluid issue??
Thats sounds like the classic sign of CRT coolant needing to be replaced you can get the phillips CRT coolant kit from www.tvrepairworld.com and it comes with the coolant for all 3 CRTs and the instructions
Nov 08, 2012 | HP Philips 60Pw9363 60-Inch Widescreen...
Hitachi 28" flat widescreen (crt) screen has circular "rainbows" (blue red green) from centre to the outside on starting up the tv. These slowly work their way to the outside of the screen....
Hi.
Sounds like the degause thermistor is either faulty or the legs that are soldered to tv circuit board from the thermistor are dry jointed (require resoldering to pcb)
Easy job to repair your self or get repair shop to do it.
If your in the UK will cost £30.00 to £40.00 for repair shop to repair.
Jun 29, 2008 | Televison & Video
Colour misalignment and focus
Inside of the tube assembly, there is a cooling liquid. This could be a job to change, and then re-adjust everything. It is also possible that on top of this, there are problems with the convergence and bias control circuits.
Typical repairs can run in the area of about $400 to about $800 depending on the amount of work and type of parts required.
Personaly, I would go out and get a good Plasma or LCD TV at this point!
Jerry G.
May 21, 2008 | Philips 60PP9202 60" Rear Projection...
White horzontal lines on the top of screen
Typical symptom of a faulty screen voltage capacitor. You'd need a schematic to locate the cap and then change it out.
Geno
Mar 10, 2008 | Philips 32PT6441/37 32" TV
TV will not turn on
check the resistors and capacitors in vertical section of the television..or change the vertical ic.
Dec 29, 2007 | Televison & Video
Sony TV help
sounds like it needs demagnetizing, also make shure you dont have any unshielded speaker close to the set, demagnetizing is performed with a demagnetizing coil, you can purchase one at any tv parts dealer for about 30dollars
Dec 06, 2007 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Washed out colours and thin red lines across the screen
your problem is in red video circuit. please get it done with skilled tech.
Oct 05, 2007 | Panasonic CT-32SL15 32" TV
Philips Plasma Flashing Red
every plasma tv ive come across with this symptom eneded up beeing a new panel. what i do is replace the x and y sustain boards and if that dont work youll need a new panel.
Sep 08, 2007 | Philips 37PF7320A 37 in. HD-Ready LCD...
Circlular discolouration on screen
Im sorry My friend I dont have a clue what your saying .. I need a picture or more detail as I dont have a clue where to start get back to us.
May 28, 2006 | Philips 28PW6006 28" TV
Televison & Video Logo
295 people viewed this question
Top Televison & Video Experts
Electro Med Services...
