Compaq Keyboard Logo
Posted on Mar 09, 2011
I have a macro key on my packard bell 0420 keyboard, how do I use it as a macro? Having trouble figuring it out.
Anonymous
Level 1:
New Friend:
  • Contributor 16 Answers
  • Posted on Mar 13, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
16
Questions
0
Helped
8600
Points
22
Go to this web site and download the manual
http://safemanuals.com/brand-user-guide-instructions-owner-manual/PACKARD%20BELL
How i unlock my keyboard. lts packard bell easynote TE11 BZ
Hello
Does the whole keyboard not work or only some keys?
Try the following shut down the computer , disconnect the power cable and remove the battery from underneath then press power button for about 20 seconds then reconnect the battery and the mains power and switch on the laptop again.
Did you spill any liquid on the keyboard?
I have a packard bell touch screen moniter and computer all in 1 and the keyboard just stoped working whats wrong and how can i fix it
add via USB an external keyboard, like me, because some keys are no more working on the bad Chinese used keyboard.!!
Packard bell easynote hotkeys don't work after reinstall windows 7
Well it seams you did not download the software for the hot keys.
12helpful
3answers
I buy PC packard bell easynote_TS11HR-032FR and the touchpad does not work, when i use my pc for the first time.
Check this:
Many laptops with touchpads have a switch or a keyboard combo that will disable the touchpad. Look to see if there is a little button you can push located near the touchpad. Alternately, there is normally a Fn-special function key combination you can use. You press the Fn key and also the special function key that has a little symbol on it that looks like a touchpad. That can turn the touchpad on or off.
I am unable to use the hot keys on a Packard Bell keyboard (SK-2300H) installed on a generic PC running Vista. The PC sees the keyboard as a standard PS/2 keyboard. Some of the buttons are active. e.g the...
Your Packard-Bell keyboard was designed to work specificaly with your PB system. The old computer came (probably pre-installed) with software and drivers that map the extra keys to functions like e-mail, calculator, volume control etc. It may be possible to make the keyboard work like it did on your old system by locating and installing the Packard Bell keyboard driver and software. Go to the PB website and select UK-Irish support location. From there go to support section and follow the automated support by filling in info such as model number etc. No guarantee it will work but worth a try.
23helpful
2answers
Fn key is constantly on
i just solved this problem today on my packard bell easy note all you have to do is hold the FN key and press NUMLK and then it should work
3answers
Non working keys on laptop
You should just need to replace the keyboard.
However finding a keyboard for a packard bell in the US can be hard. That brand hasnt been sold here in years.
If you are in europe it should be less of a problem though.
Made sure to get the exact model of the laptop to get the right keyboard.
Top Compaq Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
ExpressFiX
ExpressFiX
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
