Question about Maytag PYE2300AY Electric Dryer
Dryer is taking a lot longer to dry than normal is it the heating element. Air is flowing out of the dryer vent that goes outside.
  • 943 Answers
Hi iF YOUR DRYER IS NOISEY WHILE OPERATING ,yOU THEN HAVE A BAD BLOWER wITH a BAD BLOWER THE AIR FLOW GOING OUT SIDE IS REDUCED CAUSING A LONGER DRYING .CHECK VENTING AND VAVUUM OUT THANKS FOR THE QUESTION THE APPLIANCE DOC
Posted on Sep 12, 2008
Dryer works fine except it does not seem to heat properly. Wondering how the element is installed and where I could find replacement heating element.
I would need a model number to look up your heating element.
I can tell you that chances are if the dryer heats, but just takes to long to get things dry the heating element is probably ok.
Poor air flow is what causes dryer to take longer then normal to dry.
You will want to check your vent for restrictions such as kinks or lint build up. Don't forget to check the outside hood as it has a flapper or even a screen that can catch lint.
If your vent is ok then you need to take the dryer apart and check for lint build up around the blower housing and fan.
Aug 02, 2011 | Dryers
The dryer doesnt get hot enough to dry clothes
Pull the dryer out and remove the lint hose . Turn on the dryer and feel if there is good air flow and if you feel heat . If there is good air flow and heat , dry a load of clothes , to see if they dry normally .
If there is not good air flow , then the blower wheel is probably stripped and needs to be replaced . If there is good air flow and heat , then the problem is in the vent ducting , between the dryer and to where it vents to the outside . Dryer could be pushed back too far , causing the hose to " kink " , restricting the air flow to the outside .
Remember , a dryer either heats or doesn't heat . If no heat , then a dryer problem exists . If heat , but dryer does not dry , then a vent problem is the cause ( except for maytag , which the blower wheel sometimes strips out ) .
Nov 08, 2009 | Maytag PYE2300AY Electric Dryer
DRYER TAKES LONGER TO DRY
you could have restricted airflow from the lint screen not being cleaned, a bad blower wheel, or a bad thermostat. take the vent hose off the back and check to see if the air flows out the dryer with good force, if so your vent is probably clogged or not open in the wall. the vent hose may also be picned off from puching the dryer back to far.
Sep 17, 2009 | Whirlpool LER4634J Electric Dryer
Dryer spins, air flows through vent but isn't hot
Check the following areas thoroughly to address this issue.
1. Venting
Make sure the dryer vent hose, as well as the rest of the vent duct, is not clogged.
Unless regular maintenance is performed, chances are there is a lot of lint accumulated inside the dryer. This might affect the drying time and could be a fire hazard. Make sure to have your dryer cleaned regularly. Because this might involve taking most of the dryer apart, it is recommended to have a qualified appliance repairman perform this task.
2. Thermostat
There are a couple of cycling thermostats inside the dryer. If one of them breaks down, it might affect the dryer's performance. Replace the defective thermostat.
3. Heating element
A heating element might only be partially burned out, in which case it would still work but will take longer time to dry the clothes. Replace the element if found defective.
Sep 15, 2009 | Whirlpool LER7646E Dryer
Dryer is heating but taking twice as long to dry clothes as it should. What could be the problem. Clothes that should take no longer than an hour is taking two hours or more.
Since you know for sure the dryer is heating, the problem most likely is lint in the dryer tube. You will have to remove the back panel of the dryer, and then remove the dryer tube. (Not the vent hose, although you may want to make sure that it and the dryer vent itself is not clogged). Remove the dryer filter and normally the 2 screws that hold the vent tube in. Remove the screws from the vent tube and get the lint out of the tube. There may also be lint around the fan. Get it all out. Be careful though, all the edges are sharp and will cut you if you slide your hand along it while "sweeping" out the lint.
Aug 20, 2009 | Dryers
Whirlpool dryer....heats
You could have heating element going bad, or a plugged dryer vent. Start with dryer vent, make sure all lint is out of it, all the way through it, even if it goes to the roof, or out the wall. Also vacuum out back of dryer and inside vent tube. This should help with problem. If not then replace heating element its getting weak.
Jul 19, 2009 | Whirlpool LER4634J Electric Dryer
Laundry not getting dry
It normally takes about 45 minutes for a dryer to dry a full load. If your dryer is taking more than an hour, check these.
Vent
Heating element
Internal ductwork
Cycling thermostat
Vent Frequently there's an obstruction in the vent duct from the dryer to the outside of the house. For the dryer to heat properly, the duct must be clean and clear of lint or any other substance.
Heating element Your dryer's heating element may be partially burned out. If it is, your dryer still heats, but at such a low temperature that it takes three or four times as long to dry the clothes. If the element is partially burned out, replace it.
Internal ductwork Your dryer has some internal ductwork. If it gets clogged, your dryer can't dry properly. In most dryers, to get to the internal ductwork to clear the clog, you have to substantially disassemble the dryer. A quick way to check for internal clogs is to remove the lint filter and use a flashlight to inspect the inside of the duct. If it looks clogged and you can't clear it using your vacuum, contact a qualified appliance repair technician.
Jul 18, 2009 | Dryers
Clothes won't dry
Check the following to address this issue.
Note: Normal drying time for a dryer is about 45 minutes (some may take up to an hour).
1. Venting
2. Thermostat
3. Heating element
Jun 01, 2009 | Whirlpool ET8CHEXSQ Dryer
The problem is the dryer was taking too long to dry. Ive taken off the front and started the dryer, the heating element glows red ang ignites the gas, then goes out after about 45 seconds. The ignitor and...
If you run the dryer with the front off, the air is sucked in the open front and out the vent. The combustion air (and heat) is not drawn away from the burner, which causes the burner to short cycle. You may also have this same condition with the front on if you have a poor vent. Don't use any flexible venting. Use rigid aluminum pipe and adjustable elbows if needed. Clean the vent out and make sure the outside vent is clean and air flows out the vent with a strong flow. The outside vent should be a 4 inch vent, not a 2 inch vent flap. That normally will solve your problem. Rarely, a gas valve may cause these symptoms, but make sure the vent is good first.
Dec 15, 2008 | Dryers
Dryer is heating but not get clothes dry...
make sure you have a strong air flow from the dryer it self take hose off and run the unit it should force your hand away if not your dryer is stopped up you will have to take fan casing off and clean (the metal going to hole for vent hose) if you do go outside and make sure you vent outside is opening and free of lint also wash your lint filter with warm soapy water fabric sheets stop them up and cause longer drying time
Nov 12, 2007 | Roper REX4634KQ Electric Dryer
Maytag PYE2300AY Electric Dryer Logo
64 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
