Question about Linksys Wireless-N WRT150N Router
What's the address for the Linksys Products GUI ?
  • suyop live
    suyop live Jul 31, 2008
    thanks again
  • 1,879 Answers
Linksys.com/ui
Posted on Jul 31, 2008
My wireless connection is running super slow AND I cant access the router via 192.168.1.1
You can try to reset your router
Reset the Linksys WRT150N wireless home router if you are experiencing connection issues or have forgotten your customized router login information. Resetting the Linksys WRT150N will erase your Internet connection settings, wireless security preferences and all other personal settings from the router. This procedure will restore the WRT150N back to its factory state.
Instructions
1 Locate the "Reset" button on the back panel of the router. The button is situated to the right of the Ethernet ports and to the left of the power port.
2 Press and hold the "Reset" button.
3 Release the "Reset" button after approximately five seconds. The device resets
Tips & Warnings
Use the Linksys WRT150N setup CD-ROM to run the setup wizard and reconfigure the router after the reset.
Dec 29, 2011 | Linksys Wireless-N WRT150N Router
Linksys wireless N WRT150N Router showing limited or not connectivity
Hi.
If you have a cable modem or DSL modem, try to unplug power on it and your router too. Then plug the power back to the modem and wait until you see almost all the lights on. If your unsure just wait about 1 min and it should be ok. Next plug power back to your router. This will create an new IP address which could resolve your problem.
Feb 08, 2011 | Linksys Wireless-N WRT150N Router
WRT4G2 VI wireless router. I was upating the firmware when the power flashed. I have no access to the router's gui and the router is not broadcasting. I am not getting a dhcp address
do a hard reset for the router by pressing the reset button for 10-20 seconds...
check whether its getting a dhcp address...
if it is still not getting an ip address, then try to assign a static ip address in the range of your router on your computer...
for example...
The default ip address of linksys is 192.168.1.1.............
then assign
IP address 192.168.1.5
Subnet mask 255.255.255.0
Default gateway 192.168.1.1
Also assign a static DNS
Primary DNS : 8.8.8.8
Secondary DNS : 8.8.4.4
Now try to open the GUI of your router...
Dec 10, 2010 | Linksys WRT54G2 Wireless Router
How to hook up the Linksys Wireless-N WRT150N Router to DSL?
Connect the dsl modem to port on the router that says Internet
connect 1 pc to any available port on the router(1,2,3,4).
Open your browser and type 192.168.1.1 in the address bar
It will prompt for a username/password window. leave username blank,password admin. Press enter
Normally if you have dsl, you need to set the internet connection type to pppoe and put in your username and password that your ISP provided you. then save the settings.
Oct 04, 2010 | Linksys Wireless-N WRT150N Router
I cannot configure my Linksys WRT150N router and my network is unsecured. Can you provide assistance?
Hi ther I ve attached the Picture Just follow the Instruction
OPEN IE and Enter 192.168.1.254 in address and select the 22e01d1.pngsame option which ive added .
Aug 26, 2010 | Linksys Wireless-N WRT150N Router
Linksys wrt150n security light off
Is there any computer connected to the router ?
If not then you will need to connect the computer to the router.
Do not change any wireless settings on the router with the wireless computer.
you will need to connect the computer to the router with the Ethernet cable.
check the IP address of the computer.
open the router set up page of the router.
Here you can change the wireless settings of the router.
Now once you change the network anme and security on the router, you will need to connect to the wireless network on your wireless computers.
Click Here for step by step instructions
Mar 26, 2010 | Linksys Wireless-N WRT150N Router
How do i secure my linksys WRT 150N?
To set-up and secure the wireless router from unauthorized access, follow these steps: -
1. Connect the wireless router to your computer with a LAN cable.
2. Start your browser and enter the router's configuration URL IP address.
3. Enter the router setup, login and password
4. Change the admin password
5. Go to the wireless settings and change the default SSID and turn off SSID broadcast.
6. Setup encryption key the strongest is WPA2 (if not then WPA).
7. For further security measures - turn on MAC address filtering and enter the MAC address of the wireless cards on the computer/s you want to connect to this wireless router.
8. Record the settings you have made and keep it in a safe place and Save the settings.
9. Configure the wireless cards on the computer/s with the SSID and encryption settings of the router.
10. Remove the LAN cable between the router and the computer then the computers should be able to connect to the router wirelessly.
Nov 09, 2009 | Linksys Wireless-N WRT150N Router
Slow internet for my hardwired computer
its because ur belkin routers MTU is not properly configured in the products ... u need to lower doen the MTu speed ..
Sep 25, 2009 | Computers & Internet
Linksys WRT150N
I only have 3 suggestions.
1st one is to make sure the ssid is not similar to other routers you are using on your profile. ie.(change it to a unique name)
2nd is to make sure you check the box that says broadcast your ssid.
3rd check to make sure you select the router as an access point and not adhoc or infrastructure option. Finally you can try to change the channels eg. i like channel 3 b/c it doesnt interfere with any phone lines.
good luck
smeags.
Jan 06, 2008 | Linksys Wireless-N WRT150N Router
Linksys Wireless-N WRT150N Router Logo
55 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
